Question about SewShop.com GAMMILL SUPREME STATLER STITCHER 36-14
Has anyone conerted a older gammill quilting machine from AC to DC motor and speed control?
Were looking to convert the motor and speed control over from AC to DC anybody?? please help. Speed is very inconsistent and was advised to convert over to AC motor and speedcontrol.
Thread on top keeps breaking
Buy a pressure pack of 'dust off' open the machine and blow out any lint. Check oil for level and clecleanliness.
Mar 02, 2014 | SewShop.com Gammill Vision 18-8
My shark vacuum is blowing out dirt
i think that somehow the motor is running in reverse for whatever reason ,could the motor be DC and somehow the rectifier has gone wrong ,what voltage is this machine i wonder ,like 220c AC input but with a DC motor for some strange reason so it can run on a camper van as 12v ??
Oct 27, 2011 | Euro-Pro NV22 Shark Navigator Bagless...
The tension of the thread on top and bottom is not equal. How do you adjust the bottom thread to make it equal to the top?
Hello
First locate the sewing machine tension gauge. Sometimes its called a knob or a button or found on your Touch Screen if you have a computerized machine. Refer to your manual if you can't find it.
Either your needle thread is too tight or your bobbin thread is too loose.
First check that your bobbin thread hasn't slipped out of its tension spring in the bobbin case.
If the bobbin thread is correctly threaded through the tension spring, then decrease your needle tension by 1 number. Test by stitching several inches on your small quilt sandwich. Keep decreasing the tension until no needle thread is visible on the quilt top.
If sewing machine tension problems occur during the middle of a quilting session, again, first refer to the checklist above. Once you're satisfied that your sewing machine is threaded properly and your needle is not the culprit, then adjust the tension as outlined above.
If you have just started testing your quilting thread choices and you are using different threads for the needle and bobbin, you will in all probability make adjustments to your tension.
Make a small quilt sandwich from the materials used in your quilt to make this sandwich. It doesn't have to be pretty or even pin basted. It should be just big enough to test some of the stitching you plan to do on your quilt.
Jul 11, 2011 | Vacuums
I bought my drill from the US and as we know its 110v AC there, i want to make the charger into a car charger 12v DC. is there any way of doin this and if so can someone please help me
You cannot convert an AC charger into a DC charger for a cordless tool, no matter what you do. The charger has a transformer that operates only on an AC current only. You did not state what battery your drill has, but a range of chargers are available for cordless tools, as long as the batteries are 12v or less. Speak to your hardware outlet.
May 03, 2011 | Vacuums
I have replaced the circuit board twice on my hayden 2400 and after working for 24 hours the circuit board then fails, with no signs of it tripping. Everything is wired in correctly the supplier is unsure...
Disconnect the wiring from the unit, and go back and plug in your hose.
Get a volt tester and test the voltage coming from the lines at the machine. It should read 0 volts. Check both AC and DC voltage.
Also, check the same setup if you have a security system. Arm the security system (or have someone do it for you) and test the voltage at the line again. Again it should read 0.
If both come up 0 volts, the security and the hose I mean, unplug the hose and try one more time again AC and DC volts.
The only other thing i could see it being is a problem with the motor, if the unit is 7-10 years or more, it may need a set of motor brushes for the motor.
Let me know how this goes.
Mark
Nov 08, 2010 | Hayden Industries SuperVac 2400 Central...
Replacement motor wiring-not exactly like the old one
yes but make sure the motors are exactly the same.check the voltage on both of them and see if they are both ac motors and not dc motors.if the new motor is dc it won't work.i have a hoover savvy that has a dc motor that i want to replace with a ac motor
Apr 28, 2009 | Vacuums
Was using the SteamVac and it just stopped doing
Bad news! The humming is the pump so it is still good, but that means either the ac to dc converter is bad or the motor went up. The good news, neither would be your fault.
Apr 16, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover steamvac f5899-100 died, will not come on. is there an internal fuse i can check?
There is no fuse on a hoover steanvac, but it may have a ac/dc converter. I do not have a model list in front of me but if it does then this probally went bad. Another option is it may have overheated give the machine 12 hours to reset internally and try it again.
Apr 14, 2009 | Hoover F5899-910 SteamVac Vacuum
The vacuum turns on, but the thing with the bristles doesn't spin. Help?
no it can't be bypassed the motor is dc.the circuit board converts it from ac to dc
Apr 12, 2009 | Hoover U8145-900 Savvy Bagless Upright...
DeWalk DC500 wet/dry vaccum doesn't work
Vacuum works with the battery but does not work with 120 volt. Every time I plug it in it blows the internal fuse. I have replaced the fuse inside the vaccum several times and every time i plug it in it blows. What do you think it could be?
Feb 21, 2009 | Dewalt DC500 Canister Wet/Dry Vacuum
SewShop.com GAMMILL SUPREME STATLER STITCHER 36-14 Logo
Top SewShop.com Vacuums Experts
Ron Lake
Andrew Taylor
Andrew Taylor
Are you a SewShop.com Vacuum Expert? Answer questions, earn points and help others
