Question about Sharp CVP10NC Air Conditioner
Sharp cv-p10nc remove back cover - Sharp CVP10NC Air Conditioner
2 Suggested Answers
  • 736 Answers
SOURCE: Sharp CV-P10NC AC unit it has a puddle of water coming down.
earlier models had a pan you had to empty .. your model has a small pump that is supposed to pump the water out the hot air vent (that goes thru the window} .. since its leaking it is likely that the pump inlet is clogged ... you might have to remove a panel to get at that ... it will be near the bottom of the unit (near the drainage nozzle) ... also check the hose that goes out thru the outside vent .. make sure its not cracked, clogged or smashed ... temporarily you can use the drain nozzle to drain off the water to a lower area (it cant drain up without the pump) ...
Posted on Aug 17, 2009
.I have removed the end of drive shaft out of the hub[rhs] ,other end of shaft is still attached.will the cv joint come off the end of the shaft so i can fit the new boot?
Which vehicle are you working on?
Some of these CV-joints are designed with an outside circlip. An example of such a setup would be on an Opel/Vauxhall. On cars like these with an outside circlip it is possible, after cleaning the grease to actually see the circlip and with a good quality circlip pliers, it is possible to expand the circlip sufficiently to remove the outer CV- joint with a sharp tap while keeping circlip expanded all whilst the CV- joint is still attached to the vehicle on the inner side.
On other designed CV- joints the circlip sits on the inside of the CV joint. In other words you cannot see the circlip at all. If it is such a design then the compete CV- joint unfortunately has to be removed.
Why it has to be removed if it an inside designed circlip?
Well in most cases it requires a rather sharp tap of a rubberized hammer on the outer CV to remove it from the drive shaft. This is not possible whilst the CV-joint is attached as damage to inner CV flange is very likely.
Apr 22, 2015 | Cars & Trucks
What is the meaning of all three lights blinking
That means you need to drain the tank. The manual tells you how to do that.
Jul 28, 2014 | Sharp CV-P10NC Portable Air Conditioner,...
How do I remove plastic housing from Sharp CV-P10MX portable air conditioner to clean dust from inside.
It should be clipped on with a type "S" clip. If there are no screws visible, gently work all sides and pull towards you.
Apr 29, 2014 | Sharp CVP10MX cvp10mx 9 500 btu portable...
I am looking for the two circuit boards for the Sharp Portable Air condition Model CV-P10NC
These units are not economically viable to try such repairs out of warranty.
Mar 15, 2013 | Heating & Cooling
Mold in sharp cv-p10mc water reservoir
Dominic,
My only solution is to take the unit in for warranty service. The cooled air has a musty smell to it, too. Does yours? And did you get this issue resolved?
Sep 08, 2012 | Sharp CV-P10NC Portable Air Conditioner,...
Got cv-p10nc, exhaust pipe was lost, replaced with other one wich gets hot. The problem is different, the power of blowing after 10-20 minutes becomes low, and overall performance is much less than it was...
According to your problem, your new exhaust pipe may not compatible with your air conditioner. First check that the pipe is clean enough. You may have to clean the machine or it may need a repair. Contact with nearest service centre.
May 31, 2011 | Sharp CVP10NC Air Conditioner
I have a Sharp portable room air conditioner model CV-P10NC. The power plug RESET button and TEST button will not click in order to check out the power plug as the unit will not turn on. They did test O.K....
the fused9G.F.C.I.) cord you speak of is probably the G.F.C.I. built onto these units by design, can you or someone you know get access inside the unit and :Hot-Wire" the units cord and,bypass the power cord ( Just To Test the Unit)and see if it stays operational then replace bad unit cord if this is it.
Sep 12, 2009 | Heating & Cooling
Aug 17, 2009 | Sharp CV-P09FX Air Conditioner
Sharp CVP10NC Air Conditioner Logo
210 people viewed this question
Top Sharp Heating & Cooling Experts
Oloyede Monsuru
AJMAL KHAN
Tim Whalen
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
