Question about Cisco RVS4000 Router
Where is wps button on Cisco RVS4000 router - Cisco RVS4000 Router
3 Suggested Answers
  • 88 Answers
SOURCE: My cisco router won't talk to a d-link switch
Make sure you have DHCP setup. Check the settings on your router and make sure everything is configured correctly.
Posted on Apr 06, 2010
  • 3287 Answers
SOURCE: I have a CISCO Basic Wireless Router. Can this
The router is capable of at least Wireless B (11MB) and possibly Wireless G (54MB) or Wireless N standard speeds. The HP Photosmart will do at least Wireless B speeds (and depending on which model - even possibly the faster "G" or "N" standards, too), so yes; it can be connected wirelessly.
You'll have to set up the the HP Photosmart printer the same way you set up other wireless devices to connect to the router. You'll need to input the SSID, Security Encryption Type (WEP or WPA) and associated security "Key" to match those settings that are in the router.
If you can't remember those settings, or never set up the wireless options, you'll have to access the Cisco Router's built in web set up page. Since you didn't include your particular model number, you'll have to look up this info at Cisco's web site yourself.
If you have trouble, include the model of your router and I'll see what additional info I can get for you.
Please rate this reply - thanks!
Posted on Jan 11, 2011
How i reset to factory defaults without passwords?
That depends upon the brand of the router. It would be wise to google for the particular brand.
There often are software means to perform a reset but here are the hardware means.
For Netgear:
  1. Press and hold the Wireless On/Off and WPS buttons until the Power LED blinks red (about 6 seconds).
  2. Release the Wireless On/Off and WPS buttons and wait for the router to reboot.
For Linksys:
1. Press the red reset button on the back.
2. Unplug it from power for 30 seconds. Plug the power back in.
For Belkin:
1. Find the reset button (depends on the model).
2. Depress the reset button for 15 seconds.
3. Wait one minute for the router to restart.
Here is a tutorial for Cisco routers:
http://www.networkworld.com/article/2343961/cisco-subnet/how-to-reset-a-cisco-router-to-factory-default--removing-the-startup-configuration-file.html
Here is one for TP-Link:
http://www.tp-link.us/article/?faqid=496
For D-Link:
Push a paperclip into the hole marked reset on the back and keep it depressed for 10 seconds.
The default user name is usually admin and there is no password (password is blank).
May 11, 2015 | Computers & Internet
WPS button
I have a WRT54G router and there is no WPS button.
This is a cut and paste from Cisco engineer:
Wi-Fi Protected Setup or WPS is a somewhat new feature on most routers. However, I believe that the WRT54g was release prior to this feature. The installation disc for your wireless adapter is trying to circumvent network discovery and the process of entering a wireless password by using the WPS feature. Without using the installation disc to setup the adapter should still be able to connect to your Wi-FI network. Only use the disc to install the drivers for your wireless card and the wireless access utility. After you have done this:
1.Open the wireless utility and you should see available networks
2.Select your Wi-Fi network
3.If the network is open (not password proctected) you should be connected immediately
4.If the network is secured (password protected) then you will prompted to enter your password or preshared key
5.After entering the key you should be granted access to the network
Apr 19, 2014 | Linksys Wireless-G WRT54G Router
I need a password to reach the interneton my ipad...it asks for a cisco password
If your wireless router was setup using the default configuration, the password, also called a security key should be on the bottom of the router. Alternatively you should be able to specify on your ipad that you want to connect using WPS, and your router will have a WPS button on it. Pushing it for 2-3 seconds would allow your ipad to connect without needing the password. You should be able to google "connecting ipad to wifi using WPS" and if necessary include your router model to get specifics about the location of the WPS button on your router.
Jan 16, 2014 | Computers & Internet
Where is wps button on cisco router?
There should be only one button on the front of the router, just push it and the WPS should look for new wireless devices,
Nov 20, 2013 | Office Equipment & Supplies
Where is the was button
I'm guessing you mean the WPS button - "Wireless Protected Setup" - As far as I can see from the User Guide this router doesn't have an actual WPS Button - You need to log onto its admin web interface and browse to the WPS setup page - Press the WPS button on your client device (laptop, printer, etc) then Click the WPS button in the router's web interface and let them talk to each other to establish a secure connection - The WPS light on the Front Panel should then light up when connected - You can find a user guide at the following url:
http://downloads.linksys.com/downloads/userguide/1224642967100/WRT54G2-EU_V10_UG_combination_NC-WEB.pdf
Jun 14, 2013 | Linksys WRT54G2 V1 Wireless-G BROADBAND...
Does my WRT160N have a WPS button and if so, where is it?
The Linksys WRT160N has WPS (Wi-Fi Protected Setup). If you are using WPA-PSK encryption (recommended), then you can easily connect the C4780 to your wireless network using WPS:
1) On the Linksys router, press the WPS button that is top of the case just under the Cisco label. When the LED on the button starts to blink, then the WPS process has started.
Jul 06, 2011 | Linksys WRT160N Wireless Router
Client does all the handshacking with the router
forward these ports for your VPN client ip address on your router...
TCP&UDP 50
TCP&UDP 51
TCP&UDP 500
TCP&UDP 10000
TCP 1723
UDP 1701
also disable firewall...
Jul 25, 2010 | Linksys RVS4000 Router
Feb 13, 2010 | Cisco RVS4000 Router
I am trying to telnet through a Linksys RVS4000 from the wan side of the router to a fixed device on the lan side of the router. Both networks wan & lan are operational and I can ping the Wan side...
run netstat on the lan pc to see if telnet server is listening on port 23. look at logs on the router and pc to see if it is blocking any traffic. make sure lan pc has route back to wan
May 14, 2009 | Computers & Internet
Cisco RVS4000 Router Logo
44 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
brian soufane
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
