Question about Poulan Pro Chain Saw 46cc 20"
What grade of fuel works
Wrong gas put in. won't start
  • 743 Answers
Use Hi-test always...get some Brake cleaner at Advance Auto Weaver brand...I like this because it evaporates quick...then take the filter out of the tank and disconnect it from the line and spray the fluid until you see it come out the filter. Put it back inside the tank and it should start right up. This can be done as often as needed.
Posted on Dec 03, 2014
Wrong fuel in cherokee
Answer depends upon what "wrong fuel" you added. If it's a similar fuel
(gasoline but wrong grade etc) you can just keep using it and just use the right grade when you fill up. (same applies to diesel) But if you have used gas in a diesel or diesel in a gas vehicle, you have to drain the tank and purge the system to remove it. (tank needs to be taken down to drain). If you added under a quart of the wrong fuel, most times you can leave it alone and just fill the tank with the proper fuel and keep topping it off as you drive it to further dilute what was added.Your engine will usually tell you how unhappy it is with what you're feeding it.
Mar 05, 2013 | 2008 Jeep - GRAND CHEROKEE
Tundra won't start after ran out of gas
Your fuel pump is packed up and you should change you fuel filter as well its clogged
Oct 30, 2012 | 2007 Toyota Tundra
2002 Ford Explorer ran out of gas put gas in and won't restart. replaced fuel pump and fuel filter still won't start. Cranks but won't start
Most Fords have a fuel reset button. When you ran out of gas you tripped the circuit. Most of the time the button will be on the passenger side by the kick panel. The exact location should be in your owners manual or your local library or auto parts store will have a copy of one for your specific vehicle.
May 08, 2012 | 2000 Cadillac Seville
I just bought my lincoln ls yesterday and it was working really good but i put regular gas in it not the premium and it started acting up on me, it started backfiring really bad. what can it be? the...
all you need to do is to use the right fuel gas grade for your car check the manual it will tell you not all cars take any tipe of gasoline youll be fine just use the right grade.
Feb 24, 2011 | Lincoln LS Cars & Trucks
It ran out of fuel. we put fuel in and now it wont start. it has spark and fuel is going into engine. what else could it be.
Have you stride the old school wAy. Push and turn on the ignition. 20% of success. Maybe try runing it more and With foot on pedal. Don't last it too long or it could range starter. How long is too long. You'll know.20-30 sec If that work add some fuel injection cleaner and valves cleaner. Check air intake clean with carburTor cleaner if dirty. Keep on pushing the gas all there's to it. Unless if you amadd the wrong grade of gasoline. Regular should work.
Dec 29, 2010 | 1993 Geo Storm
Just put 60 worth of gas in my truck and now its puttering and trying to die out... what is the issue
It sounds like you got some bad gas or water in the gas. Pick up a can or two of dry gas and put it in the tank. When you get down to half a tank add some mid-grade or premium gas to help boost the octane.
Try to go to stations that sell a lot of gas that way the gas is fresh and doesn't usually get much of a chance to get water in it.
Jul 01, 2010 | 2006 Chevrolet Trailblazer
1. What happens if you put the wrong fuel in a car
Well it can majorly mess things up
If you put diesel in a gas engine it will die allmost imediately.
if you put gas in a diesel engine, a little wont hurt, but if you filled up, then it could damgae the engine horribly.
If you simply put in the wrong grade ie. 87 octane instead of 93, then dont worry it wont hurt a thing.
Nov 16, 2009 | 2007 Fiat X1/9
Couple of days ago car started choking like I was running out of gas my gas guage could be broken but can someone tell me where the carburator ? is so that I can put gas in it.
Your 95 Blazer does not have a carburetor (correct spelling too) It is fuel injected so injectors are used for each cylinder instead of a carburetor. If you run out of fuel and your vehicle is facing uphill when that happens you should have some fuel in the tank left. When leveling at a level position the vehicle will start again. You see the fuel pump is in the fuel tank and fuel is needed at all times to prime when starting. If on a grade the fuel goes to one end if only a gallon or two is left and the pump will **** air only causing a stalling problem I added all this in just so you remember this incase it ever happens to you
May 25, 2009 | 1995 Chevrolet Blazer
Gas Tank Float causes stoppage during fueling
change the gas o grade . .. did you change anytime the fuel filter . maybe is clog,. also when you upgrade the gas, way until the thank is empty . when you fill up . dont give wrong but put some transsmicion oil in the gas tank about 2'o3 Tblspoons that helps the fuel pump
Feb 26, 2009 | 2002 Hyundai XG350
Poulan Pro Chain Saw 46cc 20" Logo
48 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
