Wiring diagram grundig p45-440 - Televison & Video
Need owner's manual and wiring diagram for grundig model 5590 radio. Thanks.
U can maybe get the manual from the Grundig web site but I do not know about the schematic.
Aug 22, 2016 | Grundig S350 AM/FM/SW Radio
Could you send a circuit diagram for Grundig SO 362
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Schematic diagrams for many popular devices are given
Type in the brand name of your device, in the search box [at the top right] of the display window, and press enter to get all related posts. It will make surf easy.
Jan 05, 2015 | Grundig Televison & Video
Could u please send me a diagram of all wiring in the back as all connections have fallen out thanks d bundy
I do not have the wiring diagram but I can tell you that for the last 10-15 years (if not more) all TVs are designed so that you can't easily confuse connectors when assembling them.
Connectors are purposefully made different.
Hope this helps.
Oct 18, 2010 | Grundig GU22DVDPX 22 in. LCD TV
Circuit diagram of grundig 5441 tv
Dear Sir,
According to your request i am providing download link
Circuit diagram for Grundig 5441 tv. If you have any problem regarding this issue come back with more information about the problem,we will glad to assist you
Preview
in PDF format download High resolution complete Circuit Diagram
Download Circuit Diagram
Thank you for choosing fixya
Good Luck
Aug 21, 2009 | Televison & Video
Grundig yacht boy 400 radio does not work with mains operations
I had the same problem. Examined the wire from the transformer,and found a break. Repair of the wire solved the problem. WLD
Mar 01, 2009 | Grundig YB 400PE AM/FM/SW Radio
Grundig S350DL needs a am aerial to bring in the
1. run 18 gauge wire (buy in auto parts shelf), after stripping plastic (about 1/2 inch) away from wire inside. Clip where RED clip is, on back of radio. Need about 6 to 10 feet. Run wire in upwards direction from radio. At other end of wire, strip enough to make small loop back onto itself. (terminates the wire.) Run another length of same wire from BLACK clip on back of radio, strung along floor of room - 6 feet, maybe. Yes, hide it if it does not please somebody's eyes. Now, you have an AM external antenna.
2. Go to E-Bay, "slinkyantennas". They have a very good-looking, and performs for DX'ing antenna. Use same wire from RED clip, stripped, for alligator clip from 'slinky' shop's antenna to grab hold.
--With s350dl (NPR version-before major t-storm did kaputs, learned good lesson ... always use batteries, not A/C), and slinky pvc-style antenna with ground wire, was able from Central Louisiana, to pick up KOA from Denver!
Feb 28, 2009 | Grundig S350 AM/FM/SW Radio
Circuit diagram
Can you help me please?
I need a diagram for Panasonic CT 20G 11U TV.
My e-mail: f_trejos_gonzalez@hotmail.com
Best regards.
Jul 19, 2008 | Televison & Video
Who fixes a Grundig YB400 antenna disconnection?
I can fix it that your grundig receivers.But the problem is that im here in the philippines.That is very easy you open it carefully and find the wire for the antenna and connect it and better you solder it, grundig product is customer friendly its not hard to repair .message me whatever the result
Jun 17, 2008 | Audio Players & Recorders
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
