Question about Hotpoint RVM1425 Microwave Oven
My hot point countersaver microwave popped and the lights underneath went out and won't work even with new bulbs
4 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: Hotpoint RVM1425BA-003 Microwave Oven Stovetop Light Does Not Work
The problem is almost certainly on the control panel, which we repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This often can affect the exhaust fan operation, too. The lights and fan can be inopoerable or stuck on.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Posted on Oct 22, 2007
  • 441 Answers
SOURCE: How do I remove my Hotpoint countersaver plus
In the cabinet above the unit you will find 3 screws, 2 on the right side one on the left. As soon as these are removed the micro will free to fall, you need to lift the back of the micro up about 1/2" to lift it off the mounting plate on the wall.
Posted on Jan 07, 2011
  • 8909 Answers
SOURCE: i unpacked my new hotpoint
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Posted on Mar 23, 2011
Bulb on ge microwave keeps burning out
Hi anything is possible being that you even replaced two different brands of bulbs. I don't think the wiring harness is the problem but like I said anything could be the problem. Might I make a suggestion. Why not replace both the left and right side bulbs with LED bulbs with the same base configuration. Maybe that just might be able to solve your problem. I would like to know if it does. It also seems that a lot of others are having the exact problem. Good luck.
Marty
Apr 14, 2014 | GE Profile Spacemaker 1.8 Cu. Ft....
Jvm1440I went to change a light bulb, light bulb pulled out of threads. Tried to remove threads without turning power off and shorted something out. Underneath lights and fan will not work. The microwave...
Blew a trace off of the back of the board by it shorting out when the bulb was unscrewed, Either have to find someone to repair the main circuit board or order a new one. But $$$$ always unplug the Microwave to replace the builbs, It doesnt seem like a big deal but I have seen this a lot over the years and it really does some damage to the main PC board.
Oct 06, 2017 | Microwave Ovens
The lamp of won't work
follow the steps and fix it. God bless you
ight Bulb
If the microwave light bulb is not working it is usually located behind the upper grille and behind an access panel, and above the lower panel. On counter top units you will need to remove the outer cover to get to the bulb. If that doesn't solve the problem check the on-off switch, and control board
Main Control Board
If the microwave light bulb is not working check the light bulbs, sockets and wiring. If they are good the main control board might be defective.
Light Bulb Socket
If the microwave light bulb is not working and a new light bulb doesn't solve the problem, the light bulb socket might be burned out and need to be replaced.
Jun 11, 2013 | Neff H5642 Convection / Microwave Oven
The second under cabinet light went out with a pop, and the vent fan went out with it. Is there a fuse for both somewhere? The turntable motor and light and fan still work. Will th vent fan come back on if...
There is a varistor or thermostat switch mounted on the wall behind the control panel. I unpluged the leads and shorted them together. the fan and lights started working again. I got another microwave off freecycle.org for parts. I noticed a lot of sites tend to point to the control panel for a $36 to $100 board repair. Don't fall for it. H.G.
Jan 03, 2010 | GE JVM1660 Microwave Oven
Yesterday while using the stove top to cook some chili the lights under the microwave blew out with a loud "pop". It tripped the breaker switch so I reset it and everything works like it should except the...
Well I'm reaching here---if the bulb did not fracture/break then it sounds like a capacitor popped--check your owners manual for reset button but I don't think there is one for the lighting---In addition if you can see the circuit board--look for burn spot or wet spot. GL
Sep 18, 2017 | Kenmore 80412 Microwave Oven
All the light blew out, the electric still works, but the oven won't heat food
Hi, my living room light has stopped working, When i turned it on one of the little bulbs went pop and light stopped working although all electric and other lights still work. I tried the bulb in a different light and it still works as well?? I also took light off to check for loose wiring etc but all seems to be fine. Can you help? Thanks!
Oct 04, 2009 | Whirlpool Accuwave Microwave Oven
GE spacemaker microwave model #JVM1650SH
Allways unplug when your working inside a microwave, you will most likely have to replace the bulb again and also the fan, or anything else that is damaged, you will need to inspect the microwave for broken parts.
Il get you a few links to repair parts.
Sep 27, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Lighting Problem
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 06, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Hood lights
first remove mains cord from main power. and remove the microwave oven top cover and check the bulb and crefully remove the old bulb and put new bulb. at high voltagae section dont touch any thing ,that area very dangerous ,thats why very carefully work inside the microwave oven ..
Sep 09, 2007 | Goldstar MV-1320W/B Microwave Oven
Burning smell and light switch does not work
The controller needs to be repaired. We regularly repair these control board assemblies for only $32.50 nationwide, and that's much cheaper than replacing the board. For safety, disassembly and other info see http://tinyurl.com/yzjozk
Jan 14, 2007 | Whirlpool MH7135XE Microwave Oven
Hotpoint RVM1425 Microwave Oven Logo
Top Hotpoint Microwave Ovens Experts
William Miller
William Miller
Jim Thurston
Are you a Hotpoint Microwave Oven Expert? Answer questions, earn points and help others
