Question about Karcher 2500 PSI Pressure Washer
Testmark cjc 1001a gas pressure washer lopes when washing
Manual for pressure washer Neiko tools cjc-1001 3,000 psi where can i find it.
You will need to order this from the manufacturer, it is not available online as of this date.
Sep 07, 2016 | Psi Garden
What kind of soap is used in a pressure washer
Any water soluble washing agent ... depending on what you are washing. Some are not good if you are washing siding and will get the windows wet.
Oct 10, 2014 | Simpson PS3200 Powershot 3200 Psi Direct...
Pressure washer started up fine after it hadn't been used for a while. after it warms up and gets all the air out of the line the engine lopes, never does kick in and run strong. Do I have dirty gas...
There could be a few reasons why this isn't working, most likely fuel related.
1. Change your fuel if it is more than 6 months old.
2. There could be a partial clog in the the fuel filter or line. This has happened to me before. it will run fine, but when more fuel is needed it is starved. If the fuel can had debris in it the tank may have gotten contaminated.
Check these items first, then if then if that doesnt work we will try some other ideas, but this will solve it 90% of the time.
Jul 01, 2011 | Garden
Hose on cjc-1001 pressure washer is leaking. Need to buy new one but cant find a distributor
http://www.watercannon.com/c-11-hoses-pressure-washer.aspx here a link to a site that sells high-pressure hoses. almost all hoses are similar when it comes to pressure washers, just by the right attachments and you'll be good to go.
Apr 05, 2011 | Garden
My air compressor(TestMark) is a 6 gal and only fills to about 20psi. i can't find any leaks. It is electric and uses oild. what do you think the problem is?
Your valve plates are broken or chipped. They are located on a plate on the top of the air pump between the cylinder and head cover. If you are getting 20 psi it is most likely the output valves that are letting the air the piston compresses into the tank but not stopping it from getting back out into the cylinder so the piston keeps pumping the same air back and forth. Sorry, I couldn't find parts for TestMark compressors so I can't tell you if it's worth fixing it or if you should replace it.
Oct 11, 2010 | Air Tools & Compressors
I have a Premium Pressure Washer CJC-1001 2.3 GPM. I do not have a hose and wonder how this is attached to the engine. Is there instructions I can obtain for this? Thanks
Hello sir, my pr. washer is runing but with high quantity of dark fumes from the exahaust and high temprature in the engine.
Apr 21, 2010 | Garden
2200 psi husky briggs and stratton pressure washer used 2 years never used soap dispenser trying now is not drawing soap no longer have manual to see how to connect adjust can you help?
After a long none use, I tried to wash my driveway and powered on the washer,it did, but when i tried to engage the power washer by pressing the wand lever, it did not engage. What can I do to get the power washer working?
Jan 16, 2010 | Briggs & Stratton Gas Pressure Washer...
Karcher 2500 PSI Pressure Washer Logo
65 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
