Question about Fisher and Paykel Aquasmart wl80t65c
Why has our washer stopped working through a cycle and why wont it turn on again
  • Fisher and P... Expert
  • 555 Answers
The most common problem with AquaSmart is the pump.
The pump has gone bad and blown the motor controller board.
Some AquaSmart machines display the wrong Error code (49)
witch is not the correct code for this problem.
Pump and motor controller board need replacing.
Maybe cheaper to buy a good secondhand machine.
Posted on May 18, 2014
Door wont unlock once a wash cycle has begun
that is correct ,. pump water out then the door will open.
May 20, 2011 | Kenmore Elite 45986 Front Load Washer
WATER IN WASHER WONT SHUT OFF
Hi and welcone to FixYa. I am Kelly. When water wont shut off no matter what you do the problem is inside of the water valve assy. Usually there is a small bit of debris in the diaphram center hole that is holding the water passage open.
Here is what you can try to do to clear if BEFORE replacing the eater Valve.
1. Get a bucket
2. Turn off both water supply hoses momentarily
3. Set the water temp to warm
4. Remove ONE hose from the wall connection and place the hose in a the bucket.
5. Turn on the remaning connected hose/
6. Start machine fill cycle and tap the hose connection at the water valve on the back of the machine with either a screw driver or hammer handle.
Timer OFF
REVERSE HOSE CONNECTIONS ON THE WALL CONNECTION.
7. Place the other hose in the bucket
8. Start Fill cycle.
9. Again tap the hose connection at the water valve
10. Stop timer.
11. Reconnect both hoses and test for water flow with timer off.
12. Start fill cycle
13. Rapidly select hot and cold wash water.
14. STOP fill cycle.
15. Remove each hose individually from the water valve one at a time.
16. Use a knive blade and remove the inlet screen from the water valve. Wash screen under slowly running water rubbing it clean with your fingers. Re install screen. Reconnect water hose.
17. Repeat step 16 for opposite hose and screen.
18. Turn on water supply.
19. Test for proper filling and water stopping by starting and stopping fill cycle.
If it works you got lucky. If you still have the problem you will need to change the water valve. Either one of these water valves will work on your machine:
http://www.repairclinic.com/Appliance-Parts?s=t-PAV2300-%3d%3dc292d509361
Thanks for using FixYa.
Kelly
That is about it
Jun 05, 2010 | Maytag PAV2300 Top Load Washer
I have a Legacy SAV405DEWW machine wont run
I just had the same problem. The washer would stop about 2/3 through the spin cycle and not start again. Replaced the timer. That did NOT solve the problem.
Jul 20, 2009 | Maytag Legacy Series Top Load Washer
Washer Pauses and Shuts down Repeatedly
Check the cold water line into the unit. Remove the hose from the washer and clean the screen. flush the line while it is disconnected into a bucket or small garbage can. Your washer wont advance without a fill and most fills/rinses are with cold water
Dec 01, 2008 | Frigidaire Affinity ATF7000E Front Load...
Winsheild wipers wont park or work properly
you will need to chage the relay for the washer wipe once cycle
Nov 25, 2008 | 2001 Honda Accord
Washer stopped in the middle of the cycle
sounds like motor if nothing stuck between tubs or in pump ,check these first if ok you have bad timer
Nov 12, 2008 | Kenmore 22422 Top Load Washer
Kenmore Elite HE4t Washer - "Control Locked"
Press and hold 'dry' & 'spin', shd unlock OR
Try holding the "end of cycle" button down for 5 or 6 seconds. You must hv done it accidently, it is the child lock device. Pl. rate if helped.
Dec 29, 2007 | Kenmore Elite 45986 Front Load Washer
Washer stops after wash cycle
the timer is bad you could try cleaning the points by taking it apart very hard to do though
Aug 27, 2007 | Kenmore 23822 Top Load Washer
Fisher and Paykel Aquasmart wl80t65c Logo
208 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
