Question about Handy Living Furniture Bed Frame Full
I need a pair of replacement plastic side slat brackets who do I talk to?
Where can I purchase replacement slats, side rails, and bolts for rail slot brackets?
I would think almost any good home improvement store has all that stuff .Home Depot ,Lowes,Menards etc
Sep 08, 2015 | Coaster Briana Black Leather Like By-cast...
How to fix laminate floor tiles gaps?
First, you need to get to one edge on the narrow side. (Where the slats run toward)
Second, you need a mallet and a hook tool.
Essentially, you need to put force on the edge to push the slats/planks together.
The mallet is used to put a lot of force on the slats to push them together.
The hook tool is inserted at the end of the row of tiles/slats/panels. The mallet is then used on the other part of the tool, so every hits force is transferred to the tile.
The slat/tile then will slightly shift toward the next one. Eventually this will put them together. Probably 4 to 8 mallet strikes should do on each row.
If this is an already installed floor, you may need to take the floor trim board off to get access to the edge of the tiles.
Jan 25, 2015 | Building Materials
How to remove and replace a printer roller on HP Laserjet p3005
Hi Adam,
I suspect that you are talking about the tray 2 pick up roller. Here are the directions for that:
1.)Remove paper tray
2.)Unlock left locking tab and rotate forward untill bushing slides off
3.)Remove black plastic roller retaining bracket
4.)Slide roller to the left untill right side of shaft clears the bushing
5.)Lift roller out of printer
6.)Place spring loaded end of roller shaft into left housing
7.)Slide roller to the right and rotate until roller locks into pickup shaft
8.)Reinstall black plastic roller retaining bracket. Left side first.
9.)Reinstall left bushing and lock into place
Let me know if you where sucessfull,
Printer Piete
www.allprotech.com
Dec 28, 2010 | HP LaserJet P3005 Printer
I need a replacement handle
I had to replace all the wood on my grill. I used a wooden clothes dowel rod for the lid handle (planed one side flat, routed a grove for the insert and kept the old wooden insert), replaced the shelves with 5 in. redwood fencing slats (2 per side works better than the original 3 in. slats), and used a smaller dowel for the bin handle. It is now better than new.
Jun 28, 2010 | Patio Classic 2000 Series Grill
How do you replace the driver side brake light
This is fairly easy,just open the trunk of the car go to the side you need to change,pull away the covering,there maybe plastic pins so use a flat point screw driver to remove gentle,you will see the wires and plastic bracket around it,twist the entire bracket anti-clockwise and you should be able to pull the bracket out with the bulbs inserted.gentle pull the bulb out and replace as needed
Aug 14, 2009 | 2004 Nissan Maxima
Mamas and Papas Murano cot bed problem
fully dismatle the cot, keep all the bits.. Take the two slatted sides to bits and put the base pieces of wood from these to one side.
pull the headboard and footboard (is that whats its called) apart take the feet from the footboard and add to the headboard (they are now the sole head and foot boards) screw the 4 nuts with blanking plates to the top 4 holes on the new head and footboards
take the two long slatted size bases and screw them to the lower holes on the head and footboard put the base brackets (L shapped screws) into the corners put the cot base onto the L shaped screws done
May 18, 2009 | Baby Gear
Side rails
I have a similar problem, but a different Simmons crib. I called the company that momof4girls unrecommended and they were VERY helpful, but they were not able to ship me the parts as Simmons discontinued this type of hardware in the early 90's. My crib has a headboard and footboard - the 2 side boards are able to slide up and down on aluminum slats (almost 3 feet long.) The aluminum slats are connected to the headboards with 8 bolts; what I needed to order replacements of are the plastic sliders that allow the sidewalls to go up and down on the aluminum bracket. Not only do they allow it to go up and down, but without them you are not able to assemble the sidewalls to the crib at all. I solved the issue buy purchasing L brackets at Lowes and permanently attaching the sidewalls to the headboard and footboard, but it made it so the sidewalls did not raise or lower. I am ok with that! However, if you do NOT have the aluminum slats, you may be out of luck. The spring for the bed attaches on the aluminum brackets, so even if you were able to bolt the 4 sides together, you still have to figure out a way to attach the spring for the mattress (which connects by sliding a hook into holes on the aluminum bracket... no room for bolts here.) I am rather surprised that the hardware for this crib is plastic and aluminum; the bed is HEAVY and it is very difficult to put together as the aluminum slider is easily bent and the plastic sliders are flimsy. I actually broke the plastic pieces during assembly. No wonder this hardware was discontinued! I called Simmons and asked if they had an "updating' kit... they do not. Good luck!
Aug 25, 2008 | Bassett Baby Gear
Crib sturdyness
If it feels as though it wobbles, a likely problem is that the screws have not been fully tightened. They may feel tight, but give them all one good torque turn or two, until you cant anymore, pretty much. It should solve most of the wobble.
Jun 04, 2007 | Childesigns Shelby Crib
Handy Living Furniture Bed Frame Full Logo
495 people viewed this question
Top Handy Living Furniture Medical Experts
Electro Med Services...
Rhonda Webster
Rhonda Webster
Are you a Handy Living Furniture Medical Expert? Answer questions, earn points and help others
