Question about Maytag Skybox Beverage Vendor
Won't dispense there is no jam and child lock off
How do you lock the ice dis spencer
Hello Simon;
My name is Peter. I am a retired field service refrigeration technician.
You did not provide a model number so I do not know what unit you have.
No matter; Either you do not have a lock on your dispensers or you have a child lock out on the dispenser key pad. This lock will lock out both the water and ice dispense.
Mar 07, 2015 | Refrigerators
Lost child lock code and it's asking for it...,.HELP?
If the previous user never used a child lock function, how do this now activated? Anyway, to reset this set, you have to know about the child lock code. There is some details about, how to unlock the child lock, its repair manual will have the procedure. Check this link. It has details about these matters to many brand TVs. http://electronicshelponline.blogspot.com/ Pull up older posts there, either by its left side bar, or see it in Timslide option.
Jun 22, 2013 | Daewoo DTQ-13P2FC 13" TV
My back doors wont open
If your back doors won't open from the inside then the child proof locks maybe turned on. Open the door from the outside and look at the edge of the door near the lock for a small lever or screw setting for the child proof lock. Tun off the child proof lock and then you can open the back door from the inside.
May 09, 2012 | Dodge Cars & Trucks
No water and ice dispensing
most dispensers have a hidden lock button that may be set the lock button is a child safety feature,despite that could be the door switch since they wont dispense with the door open or perhaps could be the switch on the dispenser cradle
Jul 18, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Back passenger door won't open
if it won't open from the inside, it's your child lock in the door jam....
May 21, 2011 | Ford Escape Cars & Trucks
Ice dispenser stuck on
Either the paddle for the ice/water dispenser is stuck or you have a bad microswitch behind the dispenser.
To stop the ice/water from dispensing open the freezer door and press or hold the child lock button down. Once the unit is in child lock mode you can shut the door without energizing the dispenser.
Another option is to remove the upper freezer door hinge cover and disconnect the wire connector up there. This will remove voltage from the dispenser as well. Then either replace the paddle or switch. Sometimes the paddles/switches will get stuck because of splash up from ice dropping in sugary drinks.
May 05, 2017 | Amana ASD2328HE Side by Side Refrigerator
Ice dispenser/water dispenser in side by side fridge not working
Your dispenser is child locked. Hold the child lock button for 4 seconds and the key should disappear, if you do not know which key to press I will need the model number from the tag located on inside of the fresh food section top right corner.
Apr 18, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Door lock accent 2000 rear door lock jammed
door handle on the out side has never worked. And my wife moved the child saftey lock to the locked position and closed the door, now we can't open it. How can I move the child saftey lock back to the unlocked position when the door won't open?
Jul 02, 2008 | 2000 Hyundai Accent
Cannot get soda to dispense
Sounds like the child lock is turned on. Have you checked that?
Dec 27, 2007 | Maytag SkyBox MBV1976A Beverage Dispenser
CHILD LOCK
did you try holding it for 3 seconds.the same way that you locked it.
Jun 21, 2007 | GE Profile PFS22 33" Artica French Door...
Maytag Skybox Beverage Vendor Logo
19 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
