Question about Rock & Ice Climbing
How to install rifle sling ?
How does one attach this sling
Needthe rifle sling
    Sling setup for the Marlin Model 60 22 auto - THR
    www.thehighroad.org > ... > Gunsmithing and Repairs
    Dec 31, 2009 - 5 posts - ‎3 authors
    Just bought a model 60 about 3 months ago and I'm very happy with it performance. I notice it did not come with ... You need a standard set of sling swivels like this. ...Check out slings for muzzleloaders or a tube fed lever gun.
  1. Marlin Sling at Amazon‎
    Adwww.amazon.com/Sports‎rating for amazon.com
    Free 2-Day Shipping w/ Amazon Prime Buy Marlin Sling on Amazon
Jan 18, 2016 | Marlin Model 60 .22 Long Rifle 19 Inch...
Instructions to mount scope
PDF]OWNER'S MANUAL - Crosman
www.crosman.com/pdf/manuals/M4-177-515.pdf
Translate this page There are two different rear sight options for the M4-177 depending on which model you purchase.) Option 1- ... the airgun in any way inconsistent with this manual may make your ... Adjust the rings on your scope to match the measurements of the top rail. ... Toattach the sling at both ends push the sewn webbing loop end.
Crosman M4-177 Multi-pump .177 Pellet Air Rifle Table Top ...
? 24:29
https://www.youtube.com/watch?v=s_0grKCOmX0
May 18, 2012 - Uploaded by Replica Airguns
ReplicaAirguns.com - Crosman M4-177 Pellet-BB Multi-pump Air Rifle ... -Single shot - bolt action with manual advance magazine.... I particularly like the removable iron sights and full rail formounting a scope or red dot sight.
Crosman M4-177: Installing and Adjusting the Sights ...
? 8:38
https://www.youtube.com/watch?v=x8XKOmb41QA
Aug 28, 2012 - Uploaded by Crosman
A detailed look at installing and adjusting the sights for the M4-177 and sighting ... Crosman MK-177 Pellet-BB Multi-pump Air Rifle Table Top ...
Crosman M4-177 shooting rev
Dec 20, 2015 | Crosman M4-177 Air Rifle
I have a remington 870 wingmaster with barrel code CsH, sn.# so50664v tring to date it , and wind out if its a special mdl.
Hi James,
Here is a link for Remington Dates of Manufacture. It is highly reliable for rifle identification. Note to shotguns. It is possible a barrel may have been swapped. So authenticity could be questioned. One needs to be certain of matching to receiver This will be helpful. Remington Dates of Manufacture
From the site conversion:
C=April , S=1925,H=1939
Go and verify the provided results James.
Fare. Well.
Dec 10, 2014 | Remington Sports Remington 12 Ga...
What sort of gun I will get in the range of $200 and $300?
The guns that are available in this range are usually the Classic Army M14 and M16s. These look like the good old army guns and are quite popular. This category of price actually marks the beginning of the good quality guns. From here, the higher you move up the price graph, the better guns you buy. You can do airsoft upgrades to make your gun much more real.
Continue reading : Welcome to Airsoft Club
Sep 16, 2014 | Ics MP5A5 Airsoft Gun
Cannot find serial # on a Marlin model 55 20 gauge shotgun
If it's pre-1968 model, it doesn't have one.
The law didn't require serial numbers before the gun control act of 1968, so manufacturers would usually leave the numbers off of the low end guns.
1962-1967 = walnut stock, no serial number, full choke, 36-inch barrel
1962-1963 = no sling swivels
1964-1967 = sling swivels
Feb 18, 2014 | Marlin Model 39A .22 Long Rifle/Long/Short...
How do you load the ruger m77 rifle
Open the bolt and carefully put in your ammo one on top the other. They should "click in" and hold in the magazine. Be sure to put each shell in as far back toward the bolt as possible to ensure good feeding. If you have a magazine release door on the bottom of your rifle, be sure it is properly closed and locked. Good luck with your Ruger rifle.
Oct 13, 2010 | VauDe Rock & Ice Climbing
Point of impact shifting 3-4 inch groups at 100 yds rifle shot exc. prior to this. tried a good tip hump, tried free floating, and problem still exists.
Basic things to check:
Scope base screws - make sure they are tight. 30 in/lbs or so.
Scope rings - make sure they are tight and grip the scope securely. 15 - 20 in/lbs for steel rings.
Scope attachment screws - tighten securely.
Change in ammunition?
Change in rifle rest technique? you should be resting the stock on your rest, not the barrel.
started using a sling? this can change POI.
Is your bore clean? Use a copper remover after your normal cleaning process.
Check the barrel crown for damage.
Check the action mounting screws for proper torque.
Hope some of this helps!
Mar 30, 2010 | Nikon Optics
Repair model 770 forward sling attachment broken
Take it to a gunsmith and have him repair it, he'll have to file down the original molded sling mount and install a metal sling swivel stud.
Hope this helps, Mark the Gunsmith
Aug 04, 2009 | Rock & Ice Climbing
Robot coupe maintanance
That plastic piece is a sling disk or sling blade and made to sling product to the discharge chute. Believe it or not, the motor shafts wear out and could be the cause of premature failure. When you install the new sling blade, check to see how much slop/ play there is by moving this back and forth on the shaft, a small amount is ok (1/16th to 3/32nds). The other thing to look at is forcing or overfeeding the unit. You can contact them at Robot-coupeusa.com
Nov 15, 2007 | Robot Coupe CL50 Food Processor
Rock & Ice Climbing Logo
107 people viewed this question
Top Rock & Ice Climbing Experts
RatanbssBD
Level 1 Expert
Bill Boyd
Are you a Rock and Ice Climbing Expert? Answer questions, earn points and help others
