Question about Nordic Track C900 Pro
Why cooling fan starts & stops working - Nordic Track C900 Pro
PTAC stops running after a short time
Sounds like a voltage or amp draw issue. So how about if you only try to run the blower??
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 05, 2017 | Heating & Cooling
My car overheated and cooling fans not turning on
therr are two cheap sensors for both the coolin &AC fans,( i had same problem) take the wires off of one switch at a time while car is runnin & put jumper on wires n tie them together, if fan cmes on switch is no good
Nov 13, 2012 | 1995 Honda Accord
AC and Cooling Fans Not Working
Try installing a jumper across the N/O terminal at the relay socket. Temp sensor in the radiator or in the thermostat housing supplies the signal for the relay the other relay signal is supplied by A/C in on position. both fans will run continuous with A/C on. One fan runs intermittent relative to water temp. Be careful not to blow a head gasket. If you leave the jumpers in place, the fans will stop when the ignition is turned off, save the engine until you isolate the relay signal problem. then simply remove jumpers and reinstall the relays
Feb 28, 2017 | 1989 Toyota Camry
Black & decker refrigerator bna17b runs all the time. never shuts off. keeps thing cool, but always running.
If, the refrigerator, was working well at first, start and stop cyclically, when was new, the solution is to clean the internal fans, because having poor air circulation leads to the temperature sensor to a wrong reading
If not turned off since new, that's one was made in China and the control board has a bad factory solder, so the refrigerator starts to cause problems when the fans, that are working 24 hours at day, falling on wear or dirty then stop working , causing a lack of cooling and cracking the Peltier modules.
Aug 29, 2011 | Refrigerators
The starter on my 1995 saturn sl2 stopped working i can still push start the car but in the same day the heater fan and cooling fan stops working but then starts working again when the fans don't work the...
You have a electrical power shortage, when componets demand power it's not there [ that's why some componets slow or stop working ]. Start by cleaning the battery terminals and testing the battery to see if it holds a proper charge [ after fully charging, let the battery sit for a few hours and check the voltage = it should be at least 12 volts. If not, replace. Then check the output of the charging system = mininum of 13.8 volts to maxinum of 15.3 volts, & up to 78 ampress when @ maxinum charing. Then check the starter draw = should be around 260 amps, if it's higher then 300 amps. then replace.
Feb 21, 2011 | Saturn SL2 Cars & Trucks
When i am ueing the lop top it get hot and shut down i have to wait antill it cool down before it start up again
it sounds like your cooling fan has stopped working therefore the cpu is getting too hot to work and will shut the system down have the cooling fan looked at
Oct 29, 2010 | Compaq Presario CQ60-220US PC Laptop
What powers the cooling fan motors my ac is not cooling properly the motors come on, but they are not turning fast enough. got straight power to motors, they both work ok.
you may find that the cooling fans only run at half speed when the a/c is on they might be set that way & run at full speed when the engine starts to overheat (in stop & go traffic) the a/c may need regassing that's why it is not cooling properly.....hope this helps...... cheers..
Aug 08, 2010 | 2005 Kia Spectra
I have a 2002 Dodge Ram Quad Cab 4x4. The a/c runs great as long as the truck is moving, but as soon as you come to a stop it starts blowing warm air. Please help.
Generally if the a/c works fine at highway speeds but kicks out or slowly begins to blow warmer and warmer air as the vehicle is driven at slow speeds or is stopped the a/c condensor cooling fan is usually at fault. At highway speeds there is enough air being forced through the radiator, condenser, and oil coolers to keep everything working and cool but when the vehicle is moving slowly or is parked the electric and mechanical cooling fans have to be working to pull enough air through to keep things working. If the cooling fan isn't working or can't pull enough air through the a/c condensor the system will kick out once the internal pressure reaches a certain point. Once the vehicle is moving again the system can get rid of the heat that it has gathered from the passenger cabin, the pressure drops back to normal and the system cools again. I would start by looking for a blown cooling fan fuse in the fuse panel under the hood. Usually they are 25 amps or larger and run only the cooling fan.
Jun 14, 2010 | 2004 Dodge Ram 1500
Fan stopped working causing engine to overheat.
Which one is working?... the one on the right or the left? The one on the right is for the Air Conditioning (primarily).. the one on the left (driver's side) is for cooling the engine (coolant). If the one on the driver's side isn't working, check to see if there is power (battery voltage) and ground to it (the ECU turns it on when the coolant temp is above 208 degrees). If you have power & ground at the cooling fan connector, then the cooling fan motor is bad.
Oct 18, 2009 | 2001 Hyundai Tiburon
Engine cooling fan just stopped working
Fuse, Coolant temperature Sensor or fan relay possible problem, for proper fix, or wire in your own $5 switch, and mount to dash, then you turn it on & off.
Jul 03, 2009 | 1988 Ford Taurus
Nordic Track C900 Pro Logo
56 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
