Question about QUEMEX Auto Islamic Azan Clock With Qibla Direction Qac-801 Silver Color
My power drive 750 inverter charges just fine but the alarm is always going dew to a pop spill on it. How do locate the wire ?
    Loyalty:
    Visited the website for 30 consecutive days.
  • 374 Answers
Unplug it and give it a bath in 90% rubbing Alchohal, blow it dry and try it again.
Posted on May 18, 2014
My Shumacher 750 air compressor want come on now. When I put the gauge on it only tells how much air is in it but will not cut on.
Make sure that the motor is receiving power. If there is a starting capacitor make sure it is good. If all else fails you could have a bad motor or a frozen pump, either of which will cause your dilemma.
Nov 18, 2015 | Schumacher/Charge Express SCHPID-750 12V...
How to stop alarm on inverter?
dont have anything plugged in when you power it on,if the buzzer still goes off,then you dont have enough power going into it,if it always buzzes,then you damaged the inverter,read more about how inverters work.
May 22, 2015 | Electronics - Others
I have an aftermarket alarm system that has drained my battery
Dear Mary. All car alarm systems drain the battery after one week of the car not being used. Also, car batteries are not always fully charged on short trips because to start the engine on each short trip it drains a tremendous amount of power and a short trips do not recharge it fully. Have the car battery checked because the alarm is always on and on standby once installed, they usually have a small back-up battery in the alarm in case of car wires to the alarm have been cut, but that battery is always kept charged by the car battery, so, that is only causing a fraction of car battery discharge. However, to stop it from draining the battery you have to disconnect the alarm, and that is not a good idea. No car alarm that I have known have caused any car battery discharge, but of course if the car is not being used, or it is driven for short periods you are likely to experience a drained battery. Some batteries last more than 5 years not stop while cheaper ones have a lesser life expectancy, but again that depends on a lot of factors, heat from the engine, not enough charge because the alternator has a burnt diode, interior lights left on, too much cranking of the engine to start it and not enough miles done to recharge the battery. Try to get the battery checked and if you do not do any driving for a week, there are a number of solar powered battery charging panels that trickle charge it on sunny days but in winter I suggest you buy a charger that you can connect to the battery to keep it charged. Once charged the charger automatically cuts off and stays on stand-by until the car alarm has discharged it a bit, then the charger sensed the voltage drop and recharges it again, repeating the cycles until you need the car to go out. These small car battery maintenance chargers are inconvenient if you're not using the car too often. Some car alarm with go off when the car battery is disconnected. It's part of the protection the alarm offer. They may not be disconnected from the car battery unless you have a key that shuts off the alarm. But remember, the key shuts off the alarm but it doesn't mean it has disconnected the power from the battery. Check the pilot light status. If it flashes after the alarm key has been turned to off, it means the power is always there. Other alarms remain silent when the car battery has been disconnected from the clamps. If you garage the car at night, you can have a switch installed in the car that switches on the power to the car alarm or you can have the switch connected to a special relay activated Kill Switch that disconnects the battery altogether, but if your car alarm starts to squeal, then you don't need this switch. so try it first, disconnect the car battery and see if the alarm goes off. If not, then the Kill Switch is an option. If it goes off, then there is nothing you can do but to try and have the car battery checked and if you're not driving much or drive short trips, either a solar charger or a Mains powered auto charger can be used to keep the battery trickle charged. But before I go, you say you got an after market car alarm. Looks like it has been wrongly wired, who know. Have it checked by whoever installed it. Good luck.
Mar 17, 2015 | Jeep 1999 Grand Cherokee Laredo
Powerpack 400 plus When 115v switch is turned on AC light is on but alarm sounds and has no output
Hi, I bought a new Black & Decker one of these and when I got it home and charged it, it acted the same way. I assume it has an internal battery. These gel-cell spill-proof lead acid batteries will dry out and one cell will loose power for a load, but will indicate "full". 99% of these batteries have replacements available on line under S L A (spill-proof lead acid) batteries, or if you have a friend with a WW GRAINGER account, they stock them.
Mar 02, 2012 | Xantrex Technology Xpower Powerpack 400...
I have a vector 750 watt inverter (vec1047bd). The charge controller in my photovoltaic system went bad and I had it repaired. When I got the controller back, my inverter did not work. The inverter has a...
If you have a manual for the inverter check and see ifDin there are diagnostic codes with the LEDs.
http://documents.dewalt.com/documents/English/Instruction%20Manual/Vector/VEC1045.pdf
I looked through this and your description of the problem was not listed in the document, but you may be able to contact the manufacturer and get more information. Basically this is a DC to AC power conversion device, which takes the 12v DC input and converts it to 115V AC
and in does so at a maximum peak power of 750 watts at 115V AC. since your charge controller went bad, it is possible in the process it overloaded this device or the battery system put out too low of a voltage when the charge controller died and low voltage input is not something this unit was able to tolerate. Check your remaining components to be sure they are good, then look at the inverter's board and transformer to see if anything was damaged. I would want to verify the charge controller was good and the batteries in good condition - and perhaps consider replacing this inverter with one more suited to your actual load wattage requirements.
Nov 19, 2017 | Vector VEC1047BD 750 Watt Power Inverter
Battery spills acid, and the engine will not start again after I turn the engine off. I always have to use the jumper cables in order to get it going.
Hi,,,your regulator/rectifier is at fault,,it is overcharging the battery and making acid come out,,you will also need a new battery as the one you have is cooked.
Mar 29, 2011 | 1997 kawasaki VN 800 Vulcan Classic
I have a motormaster 1750 inverter hard wired in my semi truck, I had the inverter turned off, I replaced all 4 batteries started the truck smelt something burning and now the breaker on the inverter...
Recommend (1) open the inverter (with battery power disconnected) - and inspect incoming cable between the power switch and the battery cable entrance. Possible that a wire overheated and shorted on the input cable.
Next (2) if problem cannot be located, go to http://search.harborfreight.com/cpisearch/web/search.do?keyword=inverter and replace it with at 2000 watt inverter for 130 bucks.
Dec 29, 2009 | Electronics - Others
After spilling soda on my laptop it turns on and works fine for 1 hour, then screen goes black. I cleaned keyboard fine. Problem is there always. I have to wait for laptop to cool down(fans work fine),...
A soda spill will do this every time. As the Notebook recovers I doubt that the inverter board as gone. But the suger from the soda could be melting and causing a short. The only real solution is to completely dismantle the notebook and clean it with white spirit or similar. It will help if you can download disassembly instructions first! PS Try not to use it for too long without cleaning it.
Oct 29, 2009 | A.B.S . ABS MAYHEM G3 Eclipse R70 NoteBook...
Dew Alarm
Many times dew sensor stops giving moisture signal if hot air blows in open cassette compartment for 3-4 minutes from distance through hair dryer.
and some times dew sensor needs to be replaced to stop giving dew signal.
Dec 14, 2008 | Video Cameras
QUEMEX Auto Islamic Azan Clock With Qibla Direction Qac-801 Silver Color Logo
35 people viewed this question
Top QUEMEX Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a QUEMEX Audio Player and Recorder Expert? Answer questions, earn points and help others
