Question about Steele 28 Gallon Vertical Air Compressor
Steele 28 gallon vertical air compressor does it have an air filter?
Where is air filter located?
My air compressor won't build any air it is a steele products 5hp 28gallon vertical tank
two possible problems
the non-return valve at the tank on in the line to the tank is faulty or the poppet valves /reed valves in the heads have failed
if they are poppet valve s there is a very fine spring that keeps the valves on the seats and if reed valves they can split
in both cases the air is pumped from one cylinder to the other and back and so no air is sent to the tank
to get parts look for the make of the compressor on the crankcase and order parts from the manufacturer spares or dealer spares of the maker of the compressor
Sep 12, 2015 | Air Tools & Compressors
Looking for manual for sanborn B51-A24-80V1 model
PDF]Sanborn Black Max 5hp Air Compressor Manual B51 A24 80 1
intrigante35hindu.strictlyyouth.org/rzsatzo_sanborn-black-max-5hp-air-...
Jul 16, 2015 - Sanborn Black Max 5hp Air Compressor Manual B51 A24 80 1 ... Black Max Portable Air Compressor - 5 gallon Item #: 81527 ' Model #: BS0880504 ...Compressor Manual: $4.95: Buy Now: B51-AT24-80V,B51-A24-80V1.
Aug 28, 2015 | Air Tools & Compressors
My compressor never came on and its new only sound i get is a humming sound
If you do anything to it, you will void its warrenty. Best to take it back.
Dec 13, 2013 | Steele Products Steele Air Compressors
My compressor will not turn on its just maken a clickin sound every 2mins
Sounds like the thermal over load in the motor is tripping and resetting. Cut the power and try turning the motor and compressor by hand. If either is tight, work and oil it to try to free it up. If neither is tight, the motor is probably bad.
I have an 2545 E10 T-30 Compressor that wont build pressure Replaced tank check valve that was leaking but still will not build pressure can you help?
you probably have other issues along with the check valve. If this unit has a VP in the model # you may have a bad valve in either head. You will need to remove the heads to check. Another problem may be the unloader. It is located behind the front frame cover and is attached to the crankshaft. I have seen these come apart. Now if this does not have the VP in the model # you may have the following problem(s). The aux. valve located next to the pressure switch may be bad causing pressure to be put on the LP head valve located just behind the air filter threads. If this valve is closed no air can be pulled into the LP head /cylinder for compression thus the unit makes no air. The aux valve controls this valve in the LP head. I have also seen these valves stuck shut. Also make sure the air filter is not plugged. Hope this helps.
Jun 02, 2011 | Ingersoll Rand Type 30 Fully Packaged Ir...
Temperature rising
Make sure that your pully fan is blowing across ehe fins. Check and clean the air intake filter. Check the oil level.
Regards, --W/D--
Jul 16, 2009 | Ingersoll Rand Type 30 Fully Packaged Ir...
Temperature rise of compressor
check oil level may need oil and filter change radiator could also be dirty they clog up after awhile should be washed out with a hose often
Mar 18, 2009 | Ingersoll Rand Type 30 Fully Packaged Ir...
Tool side has no pressure
if there is sufficient air in the tank the regulator valve is either set to low or is stuck. if its stuck ur better off to buy a new one and replace the one u have.
Dec 04, 2008 | Campbell Hausfeld 28 - Gallon Air...
Steele 28 Gallon Vertical Air Compressor Logo
Top Steele Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Steele Air Tool and Compressor Expert? Answer questions, earn points and help others
