Question about Sharp EL-1801P Calculator
How do you change paper in shary el1801v / - Sharp EL-1801P Calculator
Brand new just out of box and will not print
Return and exchange if is brand new as you say. Also check the way you have the paper loaded and the directions you received with unit.
Oct 26, 2015 | Sharp EL-1801V Desktop Calculator, EL1801V
Why won't my calculator power up? It worked fine Friday but I came in Monday to find it dead. No one else uses it...
A guess: the lamp was off, so did not experience the power surge, but the calculator was on and the power supply was fried. It might just be a blown fuse in the power supply, so one could open the case (voiding any warranty ;-) and look for a soldered-in fuse.
Sep 08, 2014 | Sharp EL-1801V Desktop Calculator, EL1801V
Dremel User Manual
i would advise you to contact the company making them and ask if they can send you the users manuals, in my experience they will send it too you.
Nov 09, 2013 | Drills
Trying to put in a new paper roll
Turn off the Sharp EL-1801V.
  • 2 Cut the end of the replacement paper roll for a fresh edge and to ensure a smooth feed. Do not tear the paper roll, as feeding a torn paper roll can cause a paper jam.
  • 3 Insert the cut edge into the paper opening on the back of the Sharp EL-1801V. Hold the paper roll so that the edge being fed into the machine is coming from the bottom of the roll. Turn the power on.
  • 4 Press the "Feed" button until the paper is fed through the unit. Lift the metal paper roll holder up. Slide the paper roll onto the paper-roll holder.
  • Read more: Directions for Replacing the Paper Roll on a Sharp EL-1801V ' eHow.com http://www.ehow.com/how_7294657_directions-paper-roll-sharp-el_1801v.html#ixzz1eNqkJA8g
    Nov 21, 2011 | Sharp EL1801V Scientific Calculator
    Trying to replace the paper roll on a sharp EL1801V
    1 Turn off the Sharp EL-1801V.
    LOOKING FOR MANUAL
    http://files.sharpusa.com/Downloads/ForHome/HomeOffice/Calculators/Manuals/cal_man_EL1801V.pdf
    Oct 07, 2010 | Sharp EL1801V Scientific Calculator
    Door shelf support broken
    Hi Shari. Yes. Go to any hardware store, or a home depot or lowes. Go to the adhesives isle. What you need is an epoxy adhesive that will work on plastic. There are different ones that will work so read info on the containers to find the appropriate one. One I use a lot with success is called JD WELD.
    May 03, 2009 | Fisher and Paykel Active Smart E522B...
    Brother Intellifax 1270e question
    I am trying to delete unprinted faxes in memory. No manual came with the fax machine and I do not want to waste paper and ink printing what, I know, are junk faxes. Please e mail me at m.bazely@look.ca
    Thank you,
    Miriam
    Jul 18, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
    Leaking toner
    Make absolutely sure you are using new OEM Sharp supplies for this machine. I sell OEM and generic, and I always have trouble with generics leaking in Sharp copiers. Also if the drum unit has toner backed up in the waste channel, it will leak out.
    Apr 04, 2007 | Sharp AL 1631 Copier
    Sharp EL-1801P Calculator Logo
    26 people viewed this question
    Top Sharp Office Equipment & Supplies Experts
    Anthony Karuku
    k24674
    CheckitRight
    CheckitRight
    Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
