Question about E-Machines eMachines Desktop PC
A305 keeps rebooting
Similar issue, I can not get to the desktop. I can get to windows recovery giving me the option to start in safe mode etc.. none of those work; they all show Microsoft Corporation and status bar for about 3 minutes and then blue screen of death before it starts the same thing over again. I have tried the recovery disc, that does work and also tried the startup menu with no luck.
Any thoughts?
    Problem Solver:
  • 16 Answers
You could have a few different issues.
1. You have a driver issue. Try running windows repair from Microsoft install disk.
2. Possible power supply issue.
3. Bad hard drive. Possible bad sectors. Nothing to do here but replace hard drive.
Try disconnecting all hardware in system except hard drive and video card. This will include network cards and any other peripherals. Try to boot up.
Posted on Jun 23, 2009
Restore my emachines w3507 back to factory settings how do i do it
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. To perform a system restore, follow these steps: 1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
or
It is possible for the Windows operating system on your eMachines computer to have a critical failure. If the operating system on your eMachines computer is failing, you can use your recovery discs to restore your computer. Recovery discs come with your purchase of an eMachine, and contain your operating system and all your basic drivers. You can recover your eMachines W series in about an hour.
Turn off your computer and press "F8" to enter the BIOS menu. Tab over to the "Boot Sequence" or "Boot Order" menu. Move your optical drive to the top of the list. Press "F11" to exit and save changes. Insert your recovery disc into your optical drive, then restart your computer. Press any key to boot from disc. Select the "Full Recovery" option from your recovery disc menu. Allow the recovery procedure to complete. Hope this helps.
Dec 28, 2012 | eMachines W3507 PC Desktop
Gateway GT5404 Recovery Disk
You could have provided an operating system ?
Enable VGA mode
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. Select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive You should have no input while chkdsk utility is in progress any input might further damage your computer also Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file. Type the following command and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions. Hope this helps.
Dec 11, 2012 | Gateway GT5040 PC Desktop
My dell won't reboot. Goes to a screen that says windows error recovery, and gives me two options.1. resume windows normally or 2. launch startup repair. I tried the 2nd one and nothing happens. It...
"Step 1
I would suggest you to boot the computer in safe mode and check if you can boot to the desktop and post back the result. To boot to the desktop in safe mode with networking keep tapping F8 key during restart. Once you see the option to boot in safe mode with networking select it and press enter.
Access the link to know more about how to boot the computer in safe mode:
http://windows.microsoft.com/en-US/windows-vista/Start-your-computer-in-safe-mode
Step 2
If you are unable to boot to the computer in safe mode, you may try to perform a system restore from Windows Recovery Enviornment (WINRE Mode) to an earlier date and check if it helps you fix the issue.
If you have Windows Vista disk you may try to perform a system restore using Windows Vista disk:
a. Insert the installation disc.
b. Restart your computer.
c. If prompted, press any key to start Windows from the installation disc.
Note: If your computer is not configured to start from a CD or DVD, check the information that came with your computer. You may need to change your computer's BIOS settings. For more information, see BIOS: frequently asked questions.
d. Choose your language settings, and then click Next.
e. Click Repair your computer.
f. Select the operating system you want to repair, and then click Next.
g. On the System Recovery Options menu, click System restore and select the date when the computer was working fine.
If System Recovery Options is a preinstalled recovery option on your computer:
a. Remove all floppy disks, CDs, and DVDs from your computer, and then restart your computer.
Click the Start button, click the arrow next to the Lock button, and then click Restart.
b. Do one of the following:
• If your computer has a single operating system installed, press and hold the F8 key as your computer restarts. You need to press F8 before the Windows logo appears. If the Windows logo appears, you will need to try again by waiting until the Windows logon prompt appears, and then shutting down and restarting your computer.
• If your computer has more than one operating system, use the arrow keys to highlight the operating system you want to repair, and then press and hold F8.
c. On the Advanced Boot Options screen, use the arrow keys to highlight Repair your computer, and then press ENTER. (If Repair your computer is not listed as an option, then your computer does not include System Recovery Option as a preinstalled recovery option.)
d. Select a keyboard layout, and then click next.
e. Select a user name and enter the password, and then click OK.
f. On the System Recovery Options menu, click system restore and restore the computer to the date it was working fine.
After running the system restore check if you can boot to the desktop normally.
Access the link below to find more information about system restore.
http://windows.microsoft.com/en-US/windows-vista/What-are-the-system-recovery-options-in-Windows-Vista
http://windows.microsoft.com/en-US/windows-vista/What-to-do-if-Windows-wont-start-correctly "
This guide should help you out
Aug 24, 2011 | Dell Inspiron 1545 Notebook
I had it wiped from a virus a month ago. It hasnt been working very well since, it keeps shutting down, i keep restarting it and keeps shutting down. I have just left it alone shut off for at least two...
Attempt to restart the computer to get it to start up normallly.
If this does not work then you may have to install new windows to correct the issues the virus may have caused.
May 14, 2011 | ASUS Essentio Desktop with Intel Pentium...
It turns into blue screen with white texts and from below, its says terminating (memory-something) and has a countdown... and reboots itself. computer: Compaq Presario PC SR5050NX
Its probably saying memory dump and the countdown. This is mostly encountered after some kinda change on the pc. It can be new hardware, software or just plain windows update. Lots of times it ends up being a corrupt driver. Try to boot in to safe mode and see doe sit still do same thing. if not than you know it is software related and you can do system restore. To boot in to safe mode on reboot keep on tapping key F8 and choose safe mode. Once in safe mode if it works go to start, all programs, accessories, system tools and choose system recovery. choose like a week back and click next and this will do a restore to when pc was working, fine. If you cant boot into safe mode it is possible it has issues with hardware and this should be checked out by a pc repair shop. Another option you can try if same mode dont work try to do same thing on boot keep on tapping key F8 and instead choosing safe mode try choosing Last Known Good Configuration. this is similar to restore. Hope this helps.
Apr 17, 2011 | Compaq Presario 2200 (292600-004) PC...
I have received a Blue Screen Error but I do NOT have the XP disk
if you cant get online on your pc you're gonna need to go to someone else's and download a windows boot disk from the ms website then boot your pc from that, choose recovery console then repair boot partition.
Feb 28, 2010 | Microsoft Windows XP Professional for PC
I brought my hp about 2 years ago it worked for about a month now im trying to fix it but when it comes on it goes to the screen where it asksstart windows normally how do i reboot
You can choose to start windows normally and it should bring you to regular desktop. If not to reboot you actually have to shut it off by holding down power button until it shuts off. If still issue try to boot in to safe mode by pressing F8key on boot up and keep on pressing it till advanced start up comes up. Once in safe mode try to run virus scan to see is there any viruses. Also in same menu there is safe mode with networking if you choose this one you can do updates since it will allow you to go online even that you are in safe mode. This might resolve the issue.Hope this helps.
Jan 16, 2010 | HP Compaq Presario SR2150NX PC Desktop
I use toshiba satellite A305-S6872 laptop would not load OS
you will most likely have to go into the recovery console to fix the problem or even re-install.
The other two solutions are to either boot up in safe mode to correct the problem by trying to revert back to a saved well working time, or take out pci cards and reboot always taking out another pci card until you find the problem.
if nothing works, re-install or fix in recovery console. <<< or >>>
BEST Solution
at re-install, choose repair windows.
Aug 24, 2009 | Computers & Internet
Will not boot Windows XP
When your computer is rebooting, push the F8 key. It will change your start up options and you will see disable automatic reboot on system failure. You can they see the error and continue research on the problem.
May 05, 2008 | Sony VAIO VGC-RA840G PC Desktop
E-Machines eMachines Desktop PC Logo
105 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
