Question about Kenmore Elite Oasis 27052 Top Load Washer
The cycle signal buzzer keeps going off. what causes this
2 Suggested Answers
  • 146 Answers
SOURCE: dryer buzzer
Depending on the model some have a separate buzzer you can disconnect and tape off the leads to it. If it is an electronic timer you can muffle the sound by taking a piece of electrical tape and covering the whole on the small black speaker attached to the timer.
Posted on Dec 18, 2007
Why won't the buzzer alarm go off at the end of a drying cycle
Search Results
    Why does my Kenmore dryer model 417.94802/94862 end ...
    www.shopyourway.com > Manage My Life > Questions
    Why does my Kenmore dryer model 417.94802/94862 end of cycle alarm go off ...washer/dryer unit I do see that it is normal for the end of cycle buzzer to go off ...Why won't my Kenmore dryer model 110.86872100 shut off at the end of the ...
    Why won't the buzzer shut off on my Kenmore 80 Series ...
    The buzzer won't stop buzzing after the load is complete. ... or turn on the timer and the dryer will start just by selecting a cycle and closing the door. ... The dryer should continue to run and at the end the buzzer should only stay on as long as ...
    FIXED The Buzzer At The End Of The Dryer Cycle Comes On But Won't ...
    www.applianceblog.com/.../21739-The-Buzzer-At-The-End-Of-The-Dry...
    Dec 11, 2010 - 10 posts - ‎2 authors
    My maytag dryer has operated wonderfully until today. All of a sudden the buzzer that goes on at the end of the drying will go on but will not shut off unless I open the door.... To test it: by-pass the push-to-start switch and see if when you turn the timer on and close the door, the ... VERY annoying dryer End of Cycle Signal
    Jun 29, 2012
    Maytag DE8410 electric dryer - End of cycle buzzer stuck ...
    Mar 27, 2011
    Kenmore 80 series, buzzer won't shut off
    Sep 10, 2005
    More results from www.applianceblog.com
Feb 08, 2016 | Whirlpool Dryers
410e buzzer keeps buzzing after switch is off
sears kenmore dryer when dry cycle is done buzzer keeps ...
It can be very annoying when the buzzer to your dryer will not shut off after the ... push to start switch as soon as I close door also buzzer keeps buzzing at end of ...
My dryer end-of-cycle buzzer will only stop buzzing when I ...
I see your dryer buzzer will only go off if the door is open. ... Dryer #11079622800: End of cycle buzzer won't stop buzzing after cycle is complete. ... sears kenmore dryerwhen dry cycle is done buzzer keeps buzzing. will not turn off unless you ...
The buzzer won't stop buzzing after the load is complete. ... The buzzer won't stopbuzzing unless you open the door or turn on the timer and the dryer will start ...
Keep Your Dryer Quiet - Instructables
Dec 14, 2015 | Dryers
How do i disconnect the end of cycle signal for Whirlpool dryer LER5636P
http://www.fixya.com/support/t25216207-disconnect_end_cycle_signal_whirlpool
go here and look at number 3 on diagram,that's the buzzer,pull the wires off and tape them so nothing touches the connectors
Oct 12, 2014 | Whirlpool Dryers
Want to disable buzzer
Hello Craig McDaniel - The buzzer signal will sound when the cycle ends and briefly every 5 minutes as it is a reminder to remove the load. For this purpose, unfortunately the buzzer signal cannot be disable. Most of this brands laundry centers and microwaves are preset to do this.
Feb 15, 2013 | Frigidaire FEQ1442ES Electric Dryer
How to shut off dryer end of cycle beep. Can u run
If the model number is correct, the dryer End of Cycle signal cannot be adjusted or turned off. The informatrion is listed on page 11 of the Owner's Manual:
http://www.managemylife.com/mmh/owner_manuals/16695/WHIRLPOOL-Laundry-Centers-L0710382?brand_name_search=LTE5243D
The only way to turn the signal off, is to remove the operator console, locate the signal (buzzer) module and disconnect the wire(s). The buzzer is listed as item 32 under the "Washer/Dryer Control Panel" parts listing:
http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Washer-dryer-combo-Parts/Model-YLTE5243DQ2/1198/0152000/W0702346/00001?blt=06&prst=&shdMod=
CAUTION: If you choose this option, make sure you UNPLUG the washer/dryer before servicing anything inside. If you disconnect any wires, make sure you cover them with heat shrink or electrical tape to keep them from coming into contact with anything else.
The washer and dryer use a common power source, but the rest of the functions operate independently of each other. You can safely run both units at the same time.
If need further assistance, please let me know. I hope this helps you.
Aug 09, 2011 | Whirlpool LTE5243D Top Load Stacked...
Can the end of the cycle the buzzer be turned off?
On the display panel under the start button is a signal indicator. If you push the button to the left of the indicator you should be able to reduce the volume and even turn it off. The button on the right of the signal indicator will bring the volume back up.
Jan 07, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Can i turn the end of cycle signal off
You certainly can. I did this on mine.
Unscrew the control panel. Start a cycle and flip open the panel. When the cycle ends, follow the sound to the buzzer. Be sure to unplug the machine before you stick your hands in there.
The buzzer is most likely a small box standing alone. There will be 2 wires leading to it. Disconnect 1 of them and securely wrap it in electrical tape. You don't want to cause a short. That should do it. You can even reattach it later if you wish. Good luck
Dec 06, 2009 | Dryers
Dryer end of cycle buzzer
disconnect the BUZZER wire from the Timer
Sep 16, 2008 | Crosley CDG6000 Gas Dryer
Kenmore Series 70 Dryer Buzzer won't stop buzzing - Model 110.96573220
  • the buzzer is located under the control panel.
  • you can unplug it.
  • unplug the dryer or turn the breaker off first
  • then take out the 2 screws on both sides of the control panel
  • bull it forward toward you and unhook it from the case
  • you should see the buzzer with two wires going to it
  • only need to disconnect one.
  •  just make sure you wrap the bare wire connector with electrical tape to keep it from touching metal.
Jun 28, 2008 | Kenmore 60172 Electric Commercial Dryer
Kenmore Elite Oasis 27052 Top Load Washer Logo
14 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
