Question about Briggs & Stratton Garden
I have a craftsman lawn tractor. One of the rocker arms came Loose.I need to know what the gap is.it is a model31p777 Type 03481 code040610ze
Valve gap model 31p777 type 0348e1 code 040610ze
    Sergeant:
  • 406 Answers
Should be a sug but not tight four thousants at top dead center and no pressure on the valve stem..on the feeler gauge..good luck..
Posted on Oct 14, 2014
  • 22 Answers
SOURCE: oil change
hi,the engine uses sae 30 oil,takes about 1 litre of oil,you can get this from most garages or mower centres,hope this helps
Posted on Apr 08, 2009
  • 57 Answers
SOURCE: lawn mower troubles
You must first remove the cover assembly which houses the starter pulley. Pull the old rope completely out until it no longer moves. Hold the starter pulley and remove the old rope. Try to wind the starter pulley spring tighter if possible. DON'T LET GO. The starter rewind spring must be wound before installing the new rope. After winding the spring, thread the new rope through the cover and into the hole in the pulley. Tie a good knot in the end and let the rope wind slowly into the housing. Once you have this done, replace the cover, get the proper length of rope, thread it through the handle, tie a knot in this end and your ready to go.
Posted on May 19, 2009
panilling9
  • 284 Answers
SOURCE: I have a OLD Craftsman lawn tractor 36'' Drive belt diagram ?
go to sears.com click on parts and enter your mod#
Posted on May 26, 2009
panilling9
  • 284 Answers
SOURCE: Need Lawn Tractor Manual-Craftsman
try sears.com
enterlawn and garden section
click on parts
enter your mod#
Techjoel
  • 79 Answers
SOURCE: Diagram for Lawn tractor instalation belt
managemyhome.com has many manuals for yard machines/mtg lawn tractors.
The information you need may be generic and therefore almost any manual may help re-install the belt. This manual is for the 660-679 series. Once at the site you can check different model numbers for one that may be closer to the machine you have.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0403122.pdf
Good luck,
Techjoel
Posted on Jun 05, 2009
No valve movement on 320 John Deere lawn tractor.
the jd 320 lawn tractor is fitted with a 2 cylinder water cooled vertical shaft Kawasaki engine
parts numbered -j59051 and , I 59051 show it as a gear driven cam shaft
I would be looking for the rocker arm bolts loose /stripped, bent push rods or the key or the key that drives the crank gear has sheared
May 02, 2017 | Cars & Trucks
Engine starts but back fires through carb. exahaust valve rocker arm was off of the pushrod. pushrod is not bent neither is the valve. does it have a hydrualic lifter?
Did you change the oil there maybe gas in it if float stuck on carb. also if rocker was off the valve maybe sticking in the valve guide sometimes you can clean with out taking all apart with carb cleaner
Apr 09, 2016 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Need valve lash setting
.004 to .006 on both intake and exhaust. Keep in mind it has a compression release on the cam shaft exhaust valve side so if it is to tight it will not allow the exhaust valve to shut and will burn out with time as well as power reduction. Too loose will make it hard to turn the engine over,sounds like a low battery. I have had two of the Intec engines that the stud that the rocker arm pivots on pulled out of the engine head a little at a time and drove me crazy until it finally pulled all the way out. I would adjust on Mon, Wen, Fri .
Mar 12, 2016 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Undefined
Order new Rocker Cover gasket for your Engine Code located at top of motor nameplate)
Drain Oil. 3 pints SAE 30
Remove OHV rocker cover 4 bolts carefully and remove rocker cover and toss old gasket. Clean rocker cover with a clean rag and set aside. Fetch standard feeler guage which has a .003" and a .005" available.
Exaust valve .005" is the top one and Intake .003" is the bottom.
First check the gap between the rocker arm and valve tip.
If they need adjusting then you will need star driver to slightly loosen the center star screw then use a 10mm or 3\8 ( i think )
To slighty adjust the outter bolt until its almost tight to feeler guage then at same time while holding the outside bolt, tighten the stardrive center until tight. It will still pull it in a bit is why I say "almost tight".
You will need to reinstall new OHV rocker gasket around the rocker pan, set the top 2 bolts to help align and you might need to shift the rocker cover upward while bolt it down so the bottom edge is high enough onto motor. Do not over tighten. Aluminum is soft. You may use some "weakest" loc-tite product but I never do.
May 10, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Rocker arms are loose
Adjust your valves. Go to Goggle adjust valves b&s 19.5hp
Sep 08, 2012 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
My 24 hp 42 inch craftsman lawn tractor starts fine but continually backfires when running, plugs are dry and carbon free, air filter clean, any ideas on what I can do?
Yes I would figure out who made the motor, B&S, Kawasaki, Kohler, Tecumseh are common. Go to their website, find your engine model number and get the valve clearances. Find a mechanical person in the neighborhood, avoid brothers-in-law, and give him a 12 pack of beer to adjust the valves for you. I think you will find your mower runs way better, backfiring will be gone. After 100 hours or 3 or so years you will note most of those companies recommend an adjustment. You most likely have a 2 cylinder and there are two small rocker covers near the spark plugs, Pull off the covers and the rockers will be exposed. Adjusting the gap between the rocker and the valve takes some skill and understanding of where the pistons are in relationship to the valve train and doing it wrong can be expensive. I know there are many videos on youtube if you want to take it on yourself.
Sep 13, 2011 | Craftsman 42 in. Precision Cut Plus 24hp...
Runs fine when blades not engaged, engaging blades causes engine speed to be reduced. Engine speed increases to normal when blades not engaged, or when motor not moving. Sounds as if mowing through very...
If it has a B&S engine, and many do, try this. Remove one spark plug at a time and start the engine. If it runs with one plug, but not the other, then you have a dead cylinder. That is why it seems to run OK so long as no load is on it.
I have had 2 different mowers with B&S engines which bent the valve push rods on the left (as the driver sits) side of the engine causing the problem you speak of. And if you google this issue you will find that I am not the only person who ever had this scenario.
If you have the OHV type engine you can pull off the little valve cover, next to the spark plug, and see the rocker arms and the push rods behind them. Replacing them is about as easy as it looks, however setting the gap between the top of the valve and the rocker is best left to someone who knows what they are doing.
Sep 10, 2011 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Craftsman lawn tractor 917.271060w/kohler 15.5 hp engine cranks but backfires thru carb and wont start.
my 15 hp kohler engine backfired while i was using it, now it wont crank and backfires thru carb
Oct 10, 2010 | Craftsman Garden
Timing 17.5 hp mower
i don't think it's a timing issue, i think the valves need to be adjusted a little tighter - if the rocker arms are too loose, the valves don't open enough and compression builds up, fighting against the starter
Sep 25, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Push rod loose
Hi
Very possible that the valve is stuck open and piston could have hit valve causing it to bend at the head. This would cause valve not to close completely. Would have to remove head and remove valve and most likely replace intake valve.
Apr 09, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
53 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
