Question about Kryptonite Kryptoflex 1218 Combo Cable Bike Lock
How do I reset combination of ravx combo key x10 bike lock
3 Suggested Answers
snowghost1
  • 784 Answers
SOURCE: I locked my bikes and went on an extended
if you have forgotten the combo, then the only way to figure out the combo is to 'progress' the lock,, do this by starting at 0000 then 0001,0002,0003 and so on all the way through until the right combo is reached, trying to open the lock at every number. now what will help in the speed of this is if you can at least remember the first number or two,, say that you set the combo to a birth year ( 1977 ) ---- then all you need to do is start at 1900,1901,1902,1903,1904 etc..( just an example ). but a four digit combo will take about 1 1/2 to 2 hours to figure out.
c...
Posted on Jan 25, 2011
  • 9 Answers
SOURCE: I have a kryptonite bike
the preset factory combination is 0014
Posted on Jul 11, 2011
Reset combination lock
The cable lock should come with a small pronged key used to change the combo, if you lost the key you can try getting a replacement from HP.If not you will need to cut the cable and buy a new one.
Nov 18, 2011 | Computers & Internet
I found 2 Kryptonite combination cable locks out of a storage box and do not remember there combination! Both are open! Is there a way for me to reset combination while there open? Thanks Denys
Probably not. But a simple solution for this is to turn the numbers and listen for a click when the tumbler locks into place. You' should be able to get the combination from both locks by doing this.
Aug 07, 2011 | Kryptonite Kryptoflex 1218 Combo Cable...
I lost the instructions and don't know how to unlock using "original code" and how to create a new code
try all zeros Kryptonite locks come preset to zeros once unlocked there is a small lever inside were it locks together pull it down and set your new combo then push it back up
Oct 17, 2009 | Kryptonite Kryptoflex 1218 Combo Cable...
I dont know how to open the lock its brand new????? They failed to give me instructions when they attached to the bike
My new lock didn't come with any instuctions. I followed the link above and located the "bike locks" heading. I found that the question:
- I have a Kryptonite resettable combination lock and can't find the instructions for resetting it. How can I change the combination?
contained a pdf titled :
- Resettable Combination Cable
(red reset buttons inside)
which is not the cryptoflex 1218 but is compatible anyway.
dont hurt your fingers trying to depress the nodules as the diagram says though. to my chagrin i discovered that they will turn easily if you just push them around into place.
here are the instructions:
To set your own combination
Your new lock is preset to open at 0-0-0-5 at the factory.
1. Open the lock by aligning the opening combination
number to the Guide Points and pull out the Lock
Post. (Figure 1)
2. Push down the two Reset Buttons simultaneously
with thumb and forefinger, and turn counterclockwise
until it comes to a stop. (Figure 2)
3.You are now ready to turn the dials to set your
secret combination, such as a phone number, birthday,
etc.
4. After setting your secret combination, turn the
two Reset Buttons again by Thumb and Forefinger
clockwise until it comes to a stop and back to its
original position.
5. Verify your new combination before using your
lock. Insert the Lock Post all the way into the Locking
Port but do not turn the dials. Pull out the Lock Post.
Your lock is ready to use.
6.The reset operation is now complete. Repeat
steps 1-5 anytime you wish to change your secret
combination.
Oct 11, 2009 | Kryptonite Kryptoflex 1218 Combo Cable...
Schwinn bike lock
Try 0000, as it allways is a four digit combination !
Mar 18, 2009 | Locks & Locksmithing
Resetting combination bike lock
Try rotating locking device 180 degrees and hold it down and set combo to 0000, then let up on locking bar. That should clear the old combo. To reset, rotate the device 180 degrees and hold down while inserting your new 4 digit code and then release it.
Jan 31, 2009 | Mongoose Toys
Resetting the combination
The reset works when the current correct combination is set on the front. If you forgot the combination, you can go to the www.masterlock.com and download a PDF to request a combination from the factory to open it. It requires a notarized form & takes 6+ weeks. In the end, it is probably easier to buy a new one. When resetting the combo, I accidently scrambled it as I flipped it over. And did not know the combo. The reset button would not work. I did some guess work around the setting and got it to release again.
Jan 08, 2008 | Master Lock 5400d: Portable Select Access...
Kryptonite Kryptoflex 1218 Combo Cable Bike Lock Logo
214 people viewed this question
Top Kryptonite Cycling Experts
luminos8
Level 1 Expert
ray gallant
Tom Chichester
Are you a Kryptonite Cycling Expert? Answer questions, earn points and help others
