Question about Pride Sundancer 3 Wheel Electric Scooter
Can't remove third row seat in suburban
How do I remov e the third row seat of suburban with broken cable?
2000 chevy suburban 3rd row seat left latch locked right latches didn't lock and now won't do anything. How do I fix it?
These are cable controlled and linked remove the seat and cycle the locks and see if they move together, if not a cable has broken or come unhooked. Most of these seat backs are Val crowed so it may open right up
Aug 16, 2015 | Chevrolet Suburban Cars & Trucks
Third row seat latched on left but not right
I just ran into the exact problem with my 2004 Suburban. Once I got the seat to lay down all the other mechanisms worked as they should and I could get the seat in and out as usuall. I found this post below which explained how to get the seat down. Wish I could take credit for figuring it out on my own but I can't.
"After working on it for a couple of days here is what I did to remove the 3rd row seat.
On the rear lower right and left side there are plastic covers, if you push the seat material forward a little you can see a hole where a nut holds it on, remove the nut. On the left side pull back the plastic cover and you can see the wire and the lever that releases the seat. With my foot holding up the #1 release lever on the right side I used an open end wrench to push forward the left side lever and the seat folded down.
I then used the #2 and #3 levers to remove the seat.
To view the whole cable, open the lower seat cover, it is an overlapping plastic clip, My problem was a loose cable, similar to a brake cable on a bicycle, after fixing it I have had no problems."
To remove the nut I used an 8mm socket wrench. My problem was not a loose cable but the #1 mechanism wouldn't pull up all the way, I'm guessing because that left side locked in out of order. I pushed that left side lever down with a hard tool and had my 5yr old daughter pull up on the #1 and the seat folded right down.
Hope this helps if you havn't already gotten it fixed.
Apr 23, 2013 | 2000 Chevrolet Suburban
Cant remove third row bucket seats sequia
To recline the third row seats in the Ford Flex you should be able to press the control on the side of the seat.
------------------------obd2express.co.uk
http://www.obd2express.co.uk/wholesale/vcm-metal-box-ids-jlr-new-vcm-release.html
Nov 26, 2012 | 2002 Toyota Sequoia
2004 3rd row rear seat won't fold down using lever
Cable is broken or stretched. pick up the bottom seat and see the cable end if broken or slack from being stretched pull that cable and then the back should fold down. Ibelieve you will need to remove seat to repair the cable. the bottom seat when lifted pulls on a cable that releases the backs lock to fold down
Jun 11, 2011 | 2004 Chevrolet Suburban
How do I remove the third row seat. lever wont budge
I just fixed my dad's 04 suburban with the back seat's #1 lever not budging. It's a surprisingly simple fix: take a 5 inch flat head screw driver and as you look into the slot where the #1 handle goes, you will see a wheel mechanism that it is connected too. to the left of that wheel, you will see a hammer mechanism with a cord attached to it. all you have to do is carefully push the lever with the screw driver while gently lifting up on the handle.
Hope this helps!
Nov 24, 2009 | 2004 Chevrolet Suburban
Remove third row in 2006 odyssey
hi
its difficult to remove third row seat but either by pumping hot air to it or by sucking out the water by water ****** sponge. if its necessary to remove then better to take the car to an autorised service station
Jul 15, 2009 | 2006 Honda Odyssey
I want to make my 1999 Mercury Villager Sport into a cargo loader, with just the front seats kept and the rest of the back empty. How do I remove the other 3 seats? So far, I can't get any of them to budge...
the middle seats come out easily. There are 2 handles you have to lift up on each of the bucket seats, they are in the front of the seat down by the seat tracks. After you lift them, tilt the seat upward in the front and rotate them backward. Then lift out of the hooks. Each seat is held down by 4 hoks.
The 3rd row seat is not designed to come out xcept by a technician. It does slide forward all the way up to the front seat. It has a sliding seat track.
First, lift the T handle under the seat cushion on the left front side of the seat. This will allow you to lift the seat bottom up all the way to lcok in the full up position.
Then, lift the lever on the same side of the seat and slide the seat forward. It will stop in 4 places.
Rear -Rear
6 inches forward of that.
another two ft to the second row seating position
full frward against the front seats.
Pleae rate as fixya if this helps.
c4253aa.gif Seat —Third Row Bench Removal
sxv~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Removal of the third row bench seat requires more than one technician.
  1. Remove the second row seats. For additional information, refer to Seat—Second Row .
  1. Remove the floor mats.
  1. Lock the seat cushion in the upright position.
    1. Lift the handle to release the cushion.
  1. Move the third row bench seat to the second row position.
    • Lift the seat track release handle.
  1. Remove the two bolt covers.
  1. Remove the two seat track front bolts.
  1. Remove the four seat track rear bolts.
    1. Position the rear seat cushion floor cover aside.
  1. Remove the third row bench seat.
Mar 02, 2009 | 1997 Mercury Villager
Mounting third row seat in 2008 Suburban 1FL, LS 1500 - Fleet veh
I drive a 2008 Suburban LT and my company has a true work "fleet" suburban. The only difference between these two that I have is the back of the fleet vehicle has a thick rubber mat in the back with no seats. After removing the black mat I found that the channels and rods that the rear seats clip into are present. The third row seats are installed by clipping them in no bolts or tools are required.
Jan 20, 2009 | 2008 Chevrolet Suburban
Pride Sundancer 3 Wheel Electric Scooter Logo
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
