Question about Frigidaire 5000-BTU Window Room Air Conditioner LRA050XT7
Can the model 050xt7 be mounted sideways in a casement window?
My wife was advised at a Lowes to purchase this model for our house which as casement windows. I fear she got bad advise as I was always told AC could not be mounted sideways..
3 Suggested Answers
Agent Don
  • 310 Answers
SOURCE: Through the wall vs. window installation
I just purchased an alleged "window mount" air conditioner with the closest dimensions to the existing model. Do these mount as through the wall as well? My current opening = 18 x 26" the new purchase is 16 27/32 x 26.
There are 2 different types of window air conditioners – there are the window type of which will fit in a window that opens top to bottom and there is the slide in model of which the actual air conditioner will slide into a metal sleeve which is very common in apartments. In either case you need to measure the inside of the metal sleeve and then give that to the air conditioner dealer and he will know what to do and there is also a POS (point of sale) @ the store of which will also assist you in the measurement of the A/C unit – the window unit you need to measure the opening of the window itself, I hope this was helpful
Posted on Apr 15, 2008
  • 57 Answers
SOURCE: window or wall mount
The differance between a window and wall mounted A/C is the mounting system.
Window units are usually smaller BTU systems they set in the window, so you do not have to cut a hole in the wall to install it.
For a bedroom say 10 x 10 you can use @ 5000 btu it plugs into a standard 120 volt electric outlet. If the room is bigger then go bigger say @ 6000 btu or so. Take your room dementions with you when shopping for a unit. sometimes they have sizing on the side of the unit box.
Wall units are usually larger units. Like whole house 18,000 btu
they slide in and out of the case and use a 240 volt seperate circuit.
Best place to shop for A/C's are Home Depot, Lowes, Sams Club, B.J.'s, and Cosco they buy in large volumeusually give a Good deal I've seen 5000 btu units as low as $89.00
Just don't drop the unit out the window when installing it
From the second floor it will void your warranty. LOL
Good Luck Phil
Posted on May 20, 2008
Please anyone suggest me is it appropriate to choose Casement doors and windows?
The Casement doors and windows are best to to use as they are made up of UPVC which is a cost effective and long lasting. Casement doors and windows are resistant to heat, offer you proper ventilation and they are not prone to termites. So, don't think much, just go 4 dat. If you like more casement doors and design visit http://www.lghausys.com/in/product/windows/windows-doors-global-style.jsp
Oct 26, 2013 | Heating & Cooling
Casement windows, that crank outward, stick. This makes some of them impossible to close completely without pushing them in from the outside.
Don't know why this is posed in Chainsaws, but here goes. Check if the windows are 'square', meaning that there are good even gaps all around the window when it is closed. If not, the window may need to get shimmed to make it 'square' again. This is especially a problem on casement windows for bay or bow windows as they hang over the edge of the house. When properly installed, the weight of the window frame is tied into the attic rafters (on a ranch house) by wire cable so the window will not sag over time. If there is a framing support under a bay/bow window, it may need to be adjusted to bring the window back to square.
Aug 29, 2011 | Garden
Can it be mounted on its side? i have tall skinny windows
NO!!! You cannot do that you will have water everywhere!!!
Click here
This is the type you need... it is called a casement window A/C
heatman101
Jul 20, 2011 | Haier HWF05XC5 Air Conditioner
My air conditionner is not working properly. It sends cool aire keep getting code E3 What can I do to fix it Tks
micheline, according to the LG Owner's Manual for the Model Number you listed, there is no LED display on the casement window unit (please see the Owner's Manual link below). How are you getting an E3 error code? Or by chance, did you list the wrong model number? Even Goldstar, that is made by LG, doesn't show your model number.
Please advise. Thanks.
Jun 01, 2011 | Goldstar LG LC1200 Casement Air...
I am trying to rewire a 2-prong electrical plug but it does not have screws and a divider between the prongs like the ones described on the help sites. Instead the prongs flip open sideways. I have...
Please do yourself a favor and visit your local Lowes or Home Depot and purchase a quality two prong plug replacement. Using older material will cause an inferior result and is very dangerous. Err on the side of caution and use newer GUI rated materials
Apr 29, 2010 | Home
Remove base of envision lcd monitor G19LWk
The base of the G19LWK can be removed but it takes a little work. You have to remove the black plastic case that sandwich the LCD screen. First remove all the screws on the backside of the monitor. Then, at the seam of the two casement halves, GENTLY pry the front screen frame away from the display. Work carefully all around the edge of the display to separate it a little at a time and the pull it away in one piece. Next you will find that the back casement is held to the display with plastic tabs around the perimeter. Carefully pry the tabs away from the display frame to separate and remove the back casement. Now the base mounting is exposed on the backside and held with 4 screws. Remove the screws and the base will come free. Re-assemble the casement by snapping the back on first followed by re-installing the screws. Then snap the front frame by lining of the plastic tabs and pressing the frame down evenly around the display. You are done!
Jan 30, 2009 | Envision G19LWK Monitor
I purchased a used computer and trying to add more memory but have not figured how to open the casement that the computer is housed- can you help?
Depending on the brand and model:
  • if it is a laptop, the memories would be inside/under a lid/panel cover normally held in place by a screw or two at the bottom of the unit;
  • if it were a desktop, then it would have locking screws at the back, a latch or a snap on lock.
Hope this be of initial help/idea. Pls post the brand and model, back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 30, 2008 | Computers & Internet
Watch casement cover replacement
looking for a battery cover to suit model D 377 tissot men's twotimer II vintage 1992.
Jun 19, 2008 | Watches
Venting for portable air-condioners
They make special window units designed specifically for casement windows. They are taller and skinnier than standard window a/c's. They are no where near as common as standard window a/c's so you might have to look a little harder, but they are out there.
Jun 17, 2008 | Amana Heating & Cooling
Casement Window Placement of Unit Meant for Double Hung Windows
http://www.mrslim.com/Products/Category.asp?ProductCategoryID=24
Heres an option for you I'm afraid you cant install an a/c unit In any position other than upright. Theres a unit size and type for every conceivable application though. GL!
Jun 11, 2008 | Daewoo High Energy Efficiency Air...
Frigidaire 5000-BTU Window Room Air Conditioner LRA050XT7 Logo
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
