Question about KitchenAid Refrigerators
How to a replace my KitchenAid bottom-Mount, Built-In refrigerator gasket replacement
  • 5 Answers
SOURCE: My KitchenAid KBRS22K bottom mount refrigerator is
the problem here is the defrost element is not coming on, the problem is the control board in the fresh food compartment is defective and not telling the element to defrost. Therefore your cooling coils are impacted with ice which keeps freezer cold, and sensor in freezer says everything is ok and therefore sends nothing to refrigerator. Replace the defrost control board, Thaw out the cooling coils in freezer, and your back in business
Posted on May 20, 2009
  • 56 Answers
SOURCE: Replaced control board Kitchenaid KBFA25erss refrigerator
should be on the serial plate
Posted on Jul 03, 2009
  • 4793 Answers
SOURCE: motor still running after gasket replacement
it will take at least 24 hours for the freezer to settle down to the correct temp -18c.the water is the frozen condensate that builds up inside the outer door over a period of time and should be allowed to drain away when you do a full 48hour defrost once a year....frost free means frost free where there is an air flow.....
Posted on Jul 21, 2010
Testimonial: "just what I needed to know"
  • 1891 Answers
SOURCE: Is it possible to replace
most the handles will inter change . you will need the model # of the other frig in order to get the ones you like . but keep in mind they are not inexpensive . I looked up one of these pt # 2316868 stainless handle and are sittind down! they are $ 101.93 each . . and you need 3 .. hope this helps mm feed back pls
Posted on Jan 20, 2011
Kitchenaid dishwasher door leaks out bottom middle of door when it goes into drain mode?
You probably need to check the door gasket for proper sealing and maybe replace it if the dishwasher has been in use for awhile
Oct 13, 2012 | KitchenAid KUDI24SE Built-in Dishwasher
My freezer on the french door model is freezing over. All of my food has what appears to be snow. Why
warm air is somehow leaking into the freezer or a common problem with bottom mount doors is they get left open and that's what happens,check the gasket or the door was left open.
Apr 11, 2011 | KitchenAid KBFA25ER Bottom Freezer French...
Kitchen aid top shelf warm
  1. check gasket
  2. check the light switch on top of the refrig. section. If then pushed the switch turns the light off, but the light is still on with the fridge door closed - door needs adjustment.
Oct 13, 2009 | KitchenAid KSS48QM 48" Built-In...
Kitchenaid bottom drawer freezer is making frost or ice flakes inside. Why?
If frost is front towards door then the seal is not sealing well . Use a hair dryer on portion which is not touching cabinet . Also check for split somewhere on gasket & if found , replace gasket . If frost on the rear wall of freezer , then a defrost problem could be starting in which the fridge section would be warming up . However , bottom freezers are known for their gaskets not to seat properly .
Jul 19, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
My KitchenAid KBRS22K bottom mount refrigerator is eight years old. Was working fine, but now the refrigerator does not cool, but the freezer stays cold. The fan seems to work and the coils have been...
May 19, 2009 | KitchenAid KBRP20EMSS Bottom Freezer...
Door gasket failure
DIY absolutely. Easy job with replacement part just re-thread the strip into the grove to replace.
Apr 30, 2009 | KitchenAid Superba Architect KSCS25INSS...
Over temperature alarm on KitchenAid Superba Refrigerator
Remove the screws from the bottom grill cover. Use a vac brush to clean out that area. You should also pull the frig out from the cabinet and vac behind.
Also, you can go on kitchenaid.com and download a product manual to replace your lost manual. Click on customer care and select "Locate Manuals & Guides."
Mar 31, 2009 | KitchenAid Superba 21.6 cu. ft. Top...
Refrigerators Logo
13 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
