Question about Casio Exilim Cameras
700r4 transgo optional stick shift instructions
2 Suggested Answers
rustfarmer
  • 5438 Answers
SOURCE: Are 700r4 valve bodies replaceable?
Overdrive is actually the torque converter going into lock up mode. This is controlled by 12+ volts being supplied through a brake switch (which kicks it out when you hit the brakes) which can easily become knocked out of position or adjustment, then through a connector on the outside left of the transmission which could have been damaged or left disconnected, then through a pressure switch in the transmission which only closes when pressure is detected meaning the trans is in 4th gear, then to a solenoid which when energized provides fluid pressure to the converter clutch valve located in the valve body up until about 1997, and after is located inside the trans front pump. The solenoid in the trans often fails, but I would check all fuses, then the brake switch which you should adjust so that it is depressed until the brake pedal is pushed down.
Posted on Dec 12, 2014
If ur familiar with 700R4. The transmission is still good. What the problem is and they all do it. Remove the front pump and replace the front clutches and it will go into O/D
Dec 12, 2014 | 1987 Pontiac Firebird
My 700r4 won't shift from 1st gear what do I need
First, make sure the fluid is full, engine warm and idling and car in park. If the fluid is good the most likely problem would be the governor sticking. It will need to be taken out and cleaned and re-installed.
Oct 14, 2014 | Cars & Trucks
I'm having a issue with my transmission on a 2004 venture, when it gets up to normal operating temperatures. Whwn the van shift from first to second and then from second to third, there tends be a clunk or...
The problem is probably a bad Electronic Pressure Solenoid (EPC). Have the computer scanned at a dealership or a transmission shop to verify this. The code will probably be a P1811. The P1811 code sets because the transmission takes longer than 0.65 seconds to shift, then the computer commands maximum line pressure to make the car shift as fast as possible to avoid burning the clutches. Replacing the EPC is an expensive job, however, you can install a shift kit to speed up the shifting, and probably fix the problem. The shift kit is available from a company called TransGo. If you go to www.transgo.com you can look up a distributor in your area. The kit you will need is the SK®4T65E. Installing the shift kit is pretty easy for the 'shade tree mechanic'; if you can change your own transmission fluid, you can most likely install this kit yourself.
Dec 17, 2010 | 2004 Chevrolet Venture Passanger
I took my 700r4 transmission out of my 88 chevy caprice because i had performance done to engine. is it a smart idea to hook a 400 transmission up to it
I would stick with the 700r4 and have it gone thru and maybe have a shift kit installed. You may have to change out some things putting in a 400.
Jun 08, 2010 | 1988 Chevrolet Caprice
I am wondering which transmissions will fit a 1997 GMC 2500. The truck currently has a 4l80E trans that is bad. Will a 700R4 fit?
Unless you want to do a lot of work i would find another 4l80E or rebuild yours. 700r4 is not electronic shift and you have no connection for the shift cable. And if you get a electronic 700r4 (4L60E) The plugs are completely different and you would need to change the whole engine harness and ecm.
Jun 06, 2010 | 1997 GMC Sierra K2500
2003 lincoln LS
usually shift kit makes for harder shift also verify engine is well tuned.
Apr 21, 2010 | 2003 Lincoln LS
What transmission is in a 1990 corvette?I think it is a 700r4?and if yes will any 700r4 fit ?
No there are different 700R4 transmission, well that not quite true. The 700R4 had many jobs to matted to Corvettes to SUVs, the internals are where the differences were in the 700R4 such as the servo's and boost valve which can be easily replaced. Best thing to do is to got to a Transmission shop that can build a transmissions for your Corvette or buy a replacement 700R4 for your year of Corvette. That is why the shift points and firmness are different in a Corvette then a Cadillac while they both have 700R4 in the 1990's. Be bad for a Corvette to shift like Grandma's Cadillac going to play dingo. Good luck and hope this helps.
Dec 15, 2009 | 1990 Chevrolet Corvette
I havea 1989 chevy pickup with a 700r4 trans it is shifting from overdrive to drive while driving dow the road
FIRST CHECK TRANSMISSION FLUID LEVEL.IF FLUID LEVEL IS GOOD. YOUR PROBLEM COULD BE THROTTLE CABLE IS BINDING OR OUT OF ADJUSTMENT.YOUR GOVERNOR IS DAMAGE OR MISSING PARTS.YOUR OIL PUMP PRESSURE REGULATOR VALVE OR TV BOOST VALVE STUCK OR DAMAGE NOW .IN THE VALVE BODY.STICKING LINE BIAS VALVE TV LIMIT VALVE MODULATED TV UPSHIFT OR DOWNSHIFT VALVES.OR A STICKING THROTTLE VALVE PLUNGER.STICKING OR STUCK 1 -2 2 -3 3 -4 THROTTLE VALVES OR PRESSURE REGULATOR VALVE.THE SPACER PLATE GASKETS DAMAGE.ALSO THE 2 -4 SERVO ASSEMBLY ACCUMULATOR DAMAGED.THE 2 - 4 BAND BURNED OR ANCHOR PIN NOT ENGAGED.
Aug 31, 2009 | Chevrolet C1500 Cars & Trucks
1988 G 20 TRANS shift problems
get it serviced as the valve body might be sticking from lack of use!
Jul 18, 2009 | 1992 Chevrolet G20
1998 chey pickup truck 700r4 tranny shifts fine when cold
try some transmedic .put a little in tranny .try to take out some fluid add it in dont over fill transmission .put about a half of bottle in it. it wiil loosen those stuck shift valves.
May 05, 2009 | 1998 Chevrolet C1500
Cameras Logo
26 people viewed this question
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
