Question about Muratec Mfx-2550 mfx-2550
Problems after replacing drum
Continuing telling replace drum
From meter counter how can I remove code m2 of minolta 6001
stop 0 stop 1 , counter, clear the drum and developer. ARE YOU REPLACING THE DRUM AND DEVELOPER,
The copier works on the counter clear the counter and not replace the parts that counter is monitoring and you will have codes and image problems the counters tell the copier parts are new and to adj assigned voltages as required.
Nov 20, 2015 | Minolta Office Equipment & Supplies
WHY OUR MACHINE Di2011 DEVELOPER AND DRUM ARE BRAND NEW. BUT STILL BRINGS PROBLEMS E.G SERVICE CALL AND MACHINE TROUBLE SHOOT.
Was the counters cleared first? for the drum and developer, has to be done because the machine uses the counters to tell the copier what voltages to apply to certain assemblies. If not done causes codes and image problems. That is also how the copier has a new drum and developer, after the drum and developer where replaced was Toner Density procedure run. And no prints copies or faxes where received after the developer was replaced and running the Toner Density procedure, and any did get ne developer and start again. Must disconnect network cable and fax cable before changing developer also.
Jul 01, 2014 | Konica Minolta Bizhub c203 Copier
CAUTION MAINTENANCE CALL (M2) CALL SERVICE
Replace the developer and drum/cleaning blade. Also reset the counters after replacing parts then run F8. resetting the counter with out replacing the above items cause image problems. The copier uses the counters to determine voltages on the drum you tell the copier drum is new and it is still old will cause problems.
Sep 18, 2013 | Minolta bizhub 180 Black and White Copier
LG Direct Drive drum not spinning
What is the model number of the unit?
Nov 29, 2012 | Washing Machines
My xerox workcentre 7328 has just flagged for replacement of the toner drums. Can I still print until they arrive?
By default, after the drum counter has lapsed you still have several thousand copies left before it will actually cease copies. There is no risk or danger to your equipment by continuing to run jobs, it's just a service message alerting to replace the drum soon.
-David.
Nov 03, 2010 | Xerox Office Equipment & Supplies
How can I replace the Canon IR3100CN Drum unit.
Hi, yes it is drum RELATED error, but before changeing the drum, clean the drum sensor. When you remove drum unit, inside of copier in drum unit place, from left side, uperr in the middle you have small sensor - Clean it!
Then try again.
If not tell me the exact error code eg. E 020 - 01A2 or?
It may be problem also in developing units.
Apr 26, 2010 | Canon iRC3100 Printer
It says I need to replace my drum soon, is that right?
Hello Dothanson,
Your machine will tell you that the drum needs to be replaced after a certain number of pages printer (roughly 12000)
This is the expected yeild of the drum.
However this does not mean you have to change your drum right now.
The drum does not have a measure volume like the toner cartridge.
This means the machine can only estimate when the drum is finished.
If you are not experiencing print quality problems, you do not need to replace the drum.
Mar 25, 2010 | Brother MFC 8440 All-In-One Laser Printer
Grinding grumbling sound upon start up , continuing at a quieter sound during the cycle, loud and grumbly during shut down
Hi.
f you get a very loud noise coming from the machine, and this noiseislouder when it spins faster, then it is often because of a problemwith the drum bearing.
The drum bearing is bad, probably drum bearing spider had broken.
On a front load the drum bearing is located at the back of the drum.
To replace the part you take apart machine, undo the belt and depending on the model you may need to remove more parts.
You can find parts and diagrams for most models here.
Nov 13, 2009 | Maytag Dryers
Printing Problems with an HP LaserJet All-in-One
This sounds to me like a fuser issue or something may have gotten caught on the toners photoreceptive drum...check the toner first, if not replace the fuser...
May 08, 2008 | HP PSC 1315 All-In-One InkJet Printer
Replace drum
1.Power off the printer.
2.Open the top cover.
3.Press and hold the gray oval button on the operator panel below the indicator lights
4.While continuing to hold down the button, power on the printer.
5.The lights on the front panel will flash twice, then release the button.
The drum counter should now be reset. End of procedure.
Nov 05, 2007 | OKI B4250 Led Printer
Muratec Mfx-2550 mfx-2550 Logo
23 people viewed this question
Top Muratec Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Ben
Ben
Are you a Muratec Office Equipment and Supply Expert? Answer questions, earn points and help others
