Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
Ge cafe refrigerator cscp5ugx EXPRESS CHILL leaks
Won't Chill or freeze. The thermostate was replaced.
Did you change the thermostat or the thermistor? Thermistor is probably your problem.
Jul 24, 2015 | GE Profile PSW26P Stainless Steel Side by...
Water Dispenser on GE Profile Bottom Freezer Refrigerator Not Working
When you press the water dispenser button, do you hear a noise like water is trying to come as usual. If so then your problem might be frozen chill water tank or failed chill water valve. If you don't hear the regular noise then the problem might be with the dispenser unit.
Nov 26, 2013 | Star Manufacturing GE Profile PFSS5NJX...
I have a GE monogram side by side refrigerator and water has started collecting in the "express chill" drawer at the bottom of the refrigerator side. It appears to be collecting in the "ceiling" of th
water into the fresh section or just on the floor around freezer or fresh food door. I also cannot take all credit for solutions in the area of refrigerators leaking water. Every person contributes their own experience so those that have should also be rewarded for their own efforts. I am pretty sure you are having a defrost by CouponDropDown">drain blockage problem. Most defrost every eight hours and over a period of time the drain line that comes down from freezer into a cup like object top middle and back of the fresh food section. If blocked by gunk or ice you will see trails of liquid leaking down the rear wall of fresh food compartment until it reaches the crisper drawers.This is not always the same with every model as you may see frozen ice flowing down ther rear wall of freezers on side by sides. Here is an example Click here=> Whirlpool Leak Photo taken by TechnicianBrian He has been around a good bit and deserves credit for his contributions. Here is another way to make this look more si mple in clip below. TechnicianBrian.com And in this photo are several parts listed in photo group #1 were it is most likely running down the wall=> MagicChef CTB1921AR fresh food section. If you still have questions please ask and rate me if I was able to explain this well enough. Every refrigerator is made different so these are examples only. The key is to find if ice or just gunk has blocked you defrost drain. Unplug and then remove the rear panel in back of freezer. We need to see if the water is overflowing the condensate drain tray or if the blockage is in the turn the drain leads down back of your refrigerator. Much more on this page=> Leaking Refrigerators! This is a common tip so I will be placing this post and add as we go new ideas listed in Sea Breeze Tips Section. If you run into any problems along the way of repair please let me know, Thanks, Sea Breeze
Mar 31, 2013 | GE Monogram Side by Side Refrigerator
I have a ge cafe with the water dispenser inside and the water is freezing in the tube
Check to see if the "water tank" is freezing in the lower back of the refrigerator.
Nov 24, 2012 | General Electric Cafe CSS25USWSS Side by...
Both freezer and refrigerator stopped cooling. Electronics on and both setpoints set below normal temperature. Express chill gets fans going but no cooling.
the compressor must be check it's either the freon is low and need to be replace or the compressor is weak..
May 10, 2011 | GE Refrigerators
GE Profile Side-by-Side Refrigerator gets to too cold
turn the temp setting up to40 then check in a couple of hrs
Nov 20, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerator top light not on and refrigerator getting hot. Bottom express chill works.
try to clean all dust and pet hair out of coils there located at bottem or back of fridge. make sure there are no obstructions for air flow the coild expell heat. and unpluging for 3 or so hours may help if you resently moved the fridge.
May 04, 2009 | GE Profile PSW26P Stainless Steel Side by...
Is there a reset for this brand of GE Profile PSS26MSW
is there a reset for the computer on the back of a ge profile refrigeraton and if so where would it be
May 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
New fridge not cooling
Check the warranty, call the company.
Jul 16, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
