Question about Sony ICF-SW77 AM/FM/SW Radio
Replacement telescoping antenna
Where can i get it?
I NEED A ANTENNA FOR MY SOUNDWORKS RADIA 720
That type of telescopic radio antennae are generic, so not specific to a particular brand. Check out this page. Get the same length and take not of the fixing. Any good electronics shop in your nearest city will also sell them.
replacement telescopic radio aNTENNAe Google Search
Aug 17, 2017 | Audio Players & Recorders
How can I buy a new antenna for model sony cfm-165tw
Many boombox antennas are attached by a small screw through the pivot point. This is usually a #1 Phillips screw. Some do not have a swiveling antenna; for these you have to remove the back of the case to get at the attachment screw. Keep the screw; it's guaranteed to fit when you attach the new antenna.
The hard part is finding a replacement. If you have the pivoting/swiveling antenna, the Radio Shack 28" Replacement Telescoping Antenna 270-1405 ($5.99 online) will probably work. You might even be able to use it for a non-pivoting antenna that telescopes into the inside of the case.
Jul 22, 2014 | Sony Boombox Am Fm Tv Weather Band...
Replacement Telescopic Antenna
See if this fits the bill. Otherwise stop in at a radio shack store. They sometimes have these n stock.
BuyTraxxas
Mar 01, 2014 | Radio Communications
Broken antenna mast, Electric antenna motor seems to still be working . would like to replace mast onlly if possible.
Normally this can be replaced only with the assembly as the moving antennae is a sealed piece and goes into the unit with a flexible nylon tubing to push up the telescopic antennae.
So I think that the mast alone is not marketed but it can be salvaged and replaced from a faulty one.
Sep 29, 2010 | 1992 Mercury Grand Marquis
Telescope antenna cut apart Where I can get a new?
HELLO
You should be able to get a new telescopic antenna from any good electronics store (including online) and it is very easy to change.
All you need is a screwdriver kit with a choice of bits. Take out the screw, pull out the old antenna and you will also find 2 brass washers as well.
When you replace the antenna, put it in place then fit one brass washer at either side (it may be a bit tricky - I always use a jewellers type screw driver at this point) and when all is aligned put the screw back in and tighten it up!
JOB DONE!
Oct 16, 2009 | Sony ICF-SW7600 AM/FM/SW Radio
My1993 Mazda RX7 anteena is stuck in a up position
try some wd-40 on the antenna shaft sections and move up and down to lube antenna shaft if you find it manually telescopes hard, then if that wont help its the gear box thats stripped out and you need to replace
Oct 07, 2009 | Mazda RX-7 Cars & Trucks
I need to sawder the antanna back on is there a certain way
if the telescopic antenna is broken you cant solder it, but you can buy a replacement antenna,some scanners have an antenna that just screws into the circuit board through a hole in the top of the case,or you can get a telescope antenna that will attach to antenna jacks on the back of the set if it has those, which im sure that model does. Antenna jacks came come in several types , one is called a BNC which just pushes in and turn about half a turn to lock in place,also some scanners have the type of jack like the back of a car radio, with those you just push them in and you can find telescopic antennas with the auto type plug at a 90 degree angle that will work fine.If you need more help let me know
Jan 07, 2009 | Uniden BC350C Base Scanner
Sony ICF-SW77 AM/FM/SW Radio Logo
52 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
