Question about Onkyo receiver HT-RC260 User Manual
No radio siginal but ok on cd - Onkyo receiver HT-RC260 User Manual
How do I program emergency siginals in my area
To check your area for what frequencies you need please go to www.radioreference.com. Click on Database, choose frequency database. Then click on your state, and then your county. When you scroll down the page it will show your frequencies and systems.
May 25, 2015 | Uniden BC95XLTB Nascar 200-channel Compact...
Radio working CD stuck in safe mode Vauxhall vectra 2001 put code in 6 times still CD will not work radio OK
You must be using the wrong code
Post radio make+model plus all the letters and numbers on the label on the casing to see if the code is available
Feb 20, 2015 | Car Audio & Video
After sigining in to netflix, not abe to play a movie
can you play Youtube or iPlayer ok? If you can get in touch with Netflix
Mar 10, 2014 | Computers & Internet
Busy siginals
Change to channel 2? Or give us more details on the problem.
Dec 28, 2013 | Audiovox GMRS-602PK 2-Way Radio Walkie...
2006 ford f150 will not start
if you could have a dirty fuel filter.not expensive.not getting gas.
Mar 18, 2013 | 2006 Ford F-150
Installation of XM radio.
Depends if you are using an aux cable to plug it directly into the front of the cd player, then no you don't, or if you use casette hookup you don't. If you are trying to tune it through the radio station you may have to, they do broadcast through the air but if it's a newer model within the last few years the siginal isn't hardly strong enough but may still work you can try it , the older ones had stronger signals and you didn't have to, They started making them weaker so they would not broadcast into your house so they could make more money selling the home docking units for them.
Oct 06, 2009 | Car Audio & Video
Installed new radio, now radio works but no instrument panel lights. Turn siginal, shift light, 4x4 light and all other work, just no gauge lights. I did notice a dimmer positive wire that was not used...
I would try jumping power to that wire and see if they turn on. That is most likely the problem. I would just jumper it to a power source again after in the same manner that is was before.
Jul 22, 2009 | 2000 Chevrolet Silverado 1500
Sony CDX-M600R car radio CD: Radio does not work, CD player OK and all other funtions OK. When in radio mode can hear white noise but no transmitions. I have the same problem. No sound on AM section and FM...
Don't know if you have an external antenna or one mounted in windshield but you should be able to find the coaxial heading towards the back of the radio. Make sure that it is plugged into the radio.
Jun 01, 2009 | Sony CDX-M600 CD Changer
I had this before with my unit, I did a system reset by holding down the reset button for about 5 seconds - all back to normal then.
Apr 15, 2009 | Sony Car Audio & Video
Onkyo receiver HT-RC260 User Manual Logo
13 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
