Question about Microwave Ovens
PANASONIC INVERTER MICROWAVE MODEL NN-T695 WILL NOT START ERROR CODE K6 SHOWS ON DISPLAY
THE SETTINGDS START TO WORK BUT THE OVEN DOEES NOT RUN
4 Suggested Answers
SOURCE: Panasonic Microwave inverter oven model,
10 Amp fuse blown inside oven.
Posted on Apr 19, 2008
SOURCE: My NN-T695 Panasonic microwave oven starts up for
I'm having the same problem with the same model microwave. It has taken hard use for a long time, but now it will (sometimes) start and then stop after a second or two. I think it's a loose connection, because a couple of times I got it to work by rapping on the back or side.
Posted on Sep 26, 2010
ercupa190
  • 12223 Answers
SOURCE: i have a panasonic microwave oven model # nn-h965wf which has a bad inverter board. how do you replace it
if your unit is attached to the kitchen your need to use the screwdrive for to loose and remove the microwave.
2)proceed and open the carcase and see the screw inside of the board
3) caution can be there to due the magnetron (valve electronic), and proceed to unscrew with screwdriver and take out the board.
4) proceed in contrary sense.
5) Proof., remember you must to unpplug the power before to do anything.................. CAREFULLY.
Posted on Jul 11, 2012
Will not start but timer works
Yes indeed it could have a blown fuse but be careful your dealing with 120 volts.
Good luck
Apr 06, 2014 | GE JES1344SK Microwave Oven
Oven will not start timer works but oven will not run
If the timer counts down but nothing else works, it usually is a bad secondary interlock switch. Opening the door while the unit is in cook will ALWAYS cause this failure. Switch needs to be verified as bad and replaced.
Aug 29, 2013 | Frigidaire Microwave Ovens
Blue m industrial oven
Check your air limit switches, confirm that they are working and that there is enough air pressure going to the switch.
For industrial furnace oven service go to www.delta-h.com
You'll find tips and oven repair advice.
Aug 13, 2012 | Microwave Ovens
Bosch combination oven/microwave HMG 8220GB start button doesn't work
This is a door switch problem, one of the door switches has malfunctioned preventing the microwave oven from running.
May 14, 2012 | Bosch Microwave Ovens
6 year old Panasonic 1250W High Power Inverter Microwave Oven (Model NN-S954WF) Manufactured May 2004 has completely died. Wondering what might be the problem and is it fixable or should we just get a...
These early inverter microwaves blew their high current power transistors quite regularly. These high current power transistors are quite expensive to replace, and if one blows, there is a likelyhood of others blowing. As the microwave is over 13 years old, I'd suggest getting a new one. Inverter technology in microwaves is now a mature technology, resulting in reasonable prices and much improved reliability.
Nov 12, 2017 | Panasonic NN-S954WF Microwave Oven
How do I get my Panasonic Inverter microwave out of demo mode? I think my toddler might have hit something to put it in demo!
Hello Two options to try: a) Press the Clock / Timer button 3 times b) Unplug, wait a few seconds, then re-plug to power up with the factory settings. You will need to reset your clock and any favourite settings.
This should work with all Panasonic Microwave models.
Good luck
Aug 10, 2010 | Panasonic NN-H275 Microwave Oven
Microwave starts to work then cuts out after a problem I had.
MICROWAVE RUNS ABOUT 5 SECONDS AND SHUTS OFF AND SMOKE FROM UNDERNEATH CABINET
Apr 15, 2010 | Bosch HMT9626GB Microwave Oven
Microwave Ovens Logo
49 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
