Question about Bunn 10 Cup Home Coffee Brewer
My bunn water coning out is warm not hot - Bunn 10 Cup Home Coffee Brewer
    Novelist:
    Scholar:
  • 166 Answers
Make sure it's getting power, and that the "vacation" switch isn't on.
If on a GFCI outlet, press the RESET button - Do Not press the "test" button. If GFCI is located upstream on another outlet, or the breaker (not uncommon), try resetting the breaker or that other outlet.
If still no joy, check that the outlet is hot by plugging something else into it. If that item doesn't work either check the circuit breaker for that outlet by moving the lever all the way to the Off position, then back to the On position. You should hear a click like a light switch.
Posted on Nov 23, 2014
5 Suggested Answers
  • 131 Answers
SOURCE: bunn commercial coffee maker plug overheats, no hot water
Most likely this is your heating element, but it could also be your main thermostat
Posted on Feb 13, 2009
seandc
  • 18 Answers
SOURCE: No coffee.....but hot water spiggot is OK.
yes there is clogged inside its either the hose or the keypad / connection of the control is corroded.
Posted on Mar 09, 2009
EsWorld
  • 1618 Answers
SOURCE: water not hot on Bunn coffee maker
Check the Hi-limit thermostat on top of the tank, then the pressure stat setting and then the inline fuse and then elements.
Posted on Mar 03, 2010
mikey270
  • 26 Answers
SOURCE: The water comes out warm
Is it still under warranty? Bunn should take care of it for you if it is. Usually if the coffee is only warm it may mean that a thermal limit has tripped. The water stays warm because the tank has a heater blanket that is wrapped around it but you aren't getting any power to the heater that is in the tank.
mike@espressomachineexperts.com
Posted on Nov 02, 2010
My warmer plate light does not work and the water in holding tank feels warm on top not on bottom,coffee is not hot enough to dissolve powderewd creamer.Why?
No warmer plate llight:
Usually means bad switch. Bunn Part no. is 20316.0001. Replacement available at link below.
Bunn Home On Off Warmer Control Switch Lighted
Note differences in switch wiring in photo below between old and new style switches.
Coffee not hot:
Make sure "Vacation Switch" is in OFF position.
Aug 07, 2014 | Retail Supplies
Bunn coffee maker, no hot water
thermal fuse is blown. it is located in the top, right rear of the machine in what is now browned tubing. you can either bypass the fuse with a jumper, or get a new part through bunn (800) 352-BUNN (2866)
Mar 16, 2013 | Bunn CWTF35
I just purchased a new a10 bunn coffee maker and it just doesn't brew a hot pot of coffee. It is warm enough to drink without cooling it like my old bunns and the cup of coffee is almost cold before you...
Plug in brewer and turn on vacation switch on side
of brewer. Allow 15 minutes for water to heat to proper
temperature. This is a quote from bunns troubleshooting page. Also it should be under warranty in which case you could go to www.bunn.com and call their service line and either have them send a tech to look at it or have you send it off for warranty repair. Hope this helps.
www.midstatebeverage.com
Nov 30, 2010 | Bunn BT10B Coffee Maker
The water comes out warm from both the coffee maker and the hot water tap. I have the BUNN VLPF series. This machine is only 4 months old and has never worked correctly.
Nov 02, 2010 | Bunn -O-Matic Corp. 2 Warmer Auto Brewer...
My bunn cwtf 15 wont put out hot water and the ready light wont turn off dustain
If your ready light is on and your water is not warm... sounds like the thermostat is too low. Inside the front panel (behind the brew basket) there is a thermostat adjustment on the left-hand side. If you turn that up your ready light should shut off. You can then adjust the temp to your desired level. (194-200 degrees depending on roast, grind, etc...)
Jun 14, 2010 | Bunn CWTF15-TC
I just get bunn VPS it is and work very good
The switches are for the "warmers" only. The brewer has a reservoir the keeps water hot and ready for brewing. When it is not re-heating water (after brewing) it has a "keep warm" heater that is low voltage and keeps it ready to go.
May 16, 2010 | Bunn VPS Coffee Maker
Water not hot on Bunn coffee maker
Mar 03, 2010 | Bunn CWTF20-3 Automatic Coffee Brewer -...
Water comes out warm, not hot
may i try and help you. you may have a machine that only makes coffee lute warm. try and warm the cups before hand.
May 04, 2009 | Bunn VPR-Black (33200.0001) 12-Cup Coffee...
Kenmore 110 Top Load Washer-cold water fills extremely slowly
No it is probably the screen that is either in the end of the hose that attaches to the machine, and/or the screen is placed so that the cone is toward the machine instead of pointing away from the machine.
If the cone is pointing towards the machine any debris in the lines would collect and eventually fill the screen cone and slow or shut off water flow.
Apr 02, 2009 | Kenmore 24032\24036 Top Load Washer
Bunn commercial coffee maker plug overheats, no hot water
Feb 13, 2009 | Bunn Coffee Makers & Espresso Machines
Bunn 10 Cup Home Coffee Brewer Logo
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
