Question about RCA Silo Digital LTSL3220 32 in. LCD TV
Whats silo flat screen code - RCA Silo Digital LTSL3220 32 in. LCD TV
I have a Silo 32 inch and the red light is blinking, but when I turn the TV on it's suppose to be green so I don't know what's wrong with it
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Jul 12, 2016 | Silo Televison & Video
TV Code silo tv comcast remote
I accidentally used my LG remote to turn off my SILO tv and it worked. Then I checked to see if it could control the volume and it did!
So, I programmed my cable remote to my SILO tv with an LG code and voila! I hope you have the same luck.
Aug 08, 2013 | RCA Silo Digital LTSL3220 32 in. LCD TV
SILO TV REMOTE CODE DIRECTV
Aug 13, 2012 | Televison & Video
Programing Comcast remote
Download the user manual to your comcast remote from net. It will have all details.
May 02, 2012 | RCA Silo Digital LTSL3220 32 in. LCD TV
I have a a Silo 42'' HDTV and the menu keeps on popping up
Mine had the same problem. If you go into the menu --> Parental control, type in default code ( 0000 or 8888) --> Then check the front panel lock to make sure it is on
This should fix it, it worked for mine.
Jul 22, 2011 | RCA Silo Digital LTSL3220 32 in. LCD TV
The Tv Menu keeps popping up on my new SILO LTSL4267F tv
Hi, Try pulling the plug for 1 hour this will reset some things to default.. If this does not fix, go see a repairman.
Jul 19, 2011 | RCA Silo Digital LTSL3220 32 in. LCD TV
Why doesn't my silo tv has sound?
Let verify first to narrow down to where the problem can be. First, make sure the MUTE function is not activated, then check the on screen sound set up menu to make sure the speakers are not set to OFF. If the setting is OK, then attach the powered PC speakers to the Audio Line out RCA jacks (Red and White) to see if you can get the sound there, if you do, then the problem can be in the power amp circuits, if you do not get the sound at RCA jacks, then the problem can be in the sound processor circuit. Please post back what you find. Typical LCD flat panel repair will cost $150 and up plus parts.
Parts: www.shopjimmy.com
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Jul 22, 2010 | RCA Silo Digital LTSL3220 32 in. LCD TV
ILO 2600 SILO LCD COLOR TV
my tv is doing the same thing i am fighting with wal mart right now my tv was only 1 year old on day i tryed to turn it on and it would not so im trying to get to the biottom of it right now call this girl named lalasha at 479 204 6805 she might be able to help u
Aug 04, 2008 | iLO 2600 Television
RCA Silo Digital LTSL3220 32 in. LCD TV Logo
73 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
