Question about Breville BOV800XL 1800 Watts Toaster Oven with Convection Cooking
How do I replace control pcb assembly in BOV800XL
2 Suggested Answers
azisme
SOURCE: My Breville BOV800XL doesn't have any power.
My BOV800XL did the same thing. Of the three parts you mention the thermal fuse is by far the easiest to test and in my opinion the most likely to go out first. Check it with a meter. If you have trouble locating it read the FixYa solution for "The Breville BOV650XL will not power on." Check it for continuity like you would any fuse.
I found replacement parts at ereplacementparts.com. The thermal fuse assembly was $23 when I checked. Or you could just replace the actual fuse portion of the assembly with a comporable fuse such as http://www.mcmelectronics.com/product/NTE8213. Basically you need a 216*C thermal fuse. These can be had for less than $2 plus shipping. Buy a few just in case.
I just ordered my fuses today so I can't report on the success of my repair, but I am confident the new fuse will solve the problem.
Posted on Nov 07, 2012
Breville smart oven no heat or convection fan. LCD and controls working and can hear the oven clicking on.
The fan probably operated on the heat... I would tackle the THERMOSTATS, heat elements (at least 2) and/or fuse first.
My favorite supplier, appliancepartspros, struck out on Breville
(never-mind) I'll add a couple of credible ones at the bottom.
Sears parts is a good information source... but very pricey ($$$$) for the EXACT SAME PARTS you can get elsewhere...
If you can determine from your OWNERS papers which part you want to try first... get the operating parameters... and and check with a volt meter (ohms scale... power OFF)... for continuity on the FUSE, heaters & thermostat.
There is a possibility your control board (PCB) is at fault... it seems to be getting scarce... Turn it over and look for a burned/broken solder joint.
http://www.ereplacementparts.com/breville-bov800xl-smart-oven-parts-c-116052_116061_116092.html
In any case... get three prices...
In the event that PCB is the issue I do recommend LOOKING TO SEARS because of their parts support and warranty...
Good luck (finding the FUSE).
Breville BOV800XL Smart Oven Parts
Parts and Accessories
Sears Appliance Parts
Mar 04, 2016 | Breville The Smart Oven Convection Toaster...
I have a Brevelle 800 toaster oven that starts, but does not heat up. What part needs replacing?
There is a thermal fuse that breaks power to the heating elements if it gets too hot (somewhere around 173 C. I replaced mine with an identically rated fuse and it was good for a week until I tried to cook twice in succession. I then replaced the fuse with one that trips at around 190C and it's been good for 4 months now. The fuse costs about $6 on ebay (shipping included) and takes about an hour to replace.
Jul 18, 2014 | Breville BOV800XL 1800 Watts Toaster Oven...
What part needs to be replaced when the lcd and controls work but no heat?
Most likely suspects in this scenario would be the heating element or the temperature sensing rod. Not sure what the sensing rod setup on this oven looks like, but it is generally a few inches long, similar diameter to a charging cable for your phone, attached to the back wall of the oven and sticking out directly toward the oven door. If it goes bad, the oven may think it has reached the set temperature and turn off, but generally, it is the opposite (it allows the oven to get too hot). My guess is heating element, but the sensor generally costs a lot less to replace, though maybe not with a small toaster oven. Good luck!
No Heat; Controls, LED work fine
I have the same toaster oven and it developed the same problem.
There is a thermal fuse with a 172C trip point. I replaced it with a new part and it worked fine for another week. I replaced it again with a fuse with a 192C trip point and that's been working for a couple of months now. Some pointers for replacing the fuse.
1) you need a Philips screwdriver with an 11" (30cm) shaft to get at the screws behind the control panel.
2) you only need to take off the feet and open the right side (looking at the toaster from the front).
3) The thermal fuse is in a white flexible plastic tube, held in place with a metal bracket.
4) You can pull the old fuse from the wire clamp using 2 pairs of plyers. I re-used the same clamps to connect the new fuse to the existing wires.
5) Replacement fuses can be found on EBAY for about $1.50 (includes shipping from Hong Kong)
Feb 06, 2014 | Breville BOV800XL 1800 Watts Toaster Oven...
Breville beeping too loud
The beeping sound is annoying and mostly unnecessary. Unfortunately it can't be turned off. The only way to "fix it" would be to remove or disable the Piezo buzzer. I tried doing this, but disassembling the oven to reach the pcb control board ,where the buzzer is located, is complicated. You can take the top cover off using a Philips screw drive. But reaching the pcb board is tedious. So I gave uP and reassemble it. If someone has a better idea or method , please share. This is a great oven except for the annoying beeping. Even my dogs are afraid because it is the same sound that my invisible fence has and they think that they are being warned.
Mar 28, 2013 | Breville BOV800XL 1800 Watts Toaster Oven...
Aug 30, 2012 | Breville BOV800XL 1800 Watts Toaster Oven...
Price and availability of main control PCB for Black & Decker TRO360
HI .I AM AN ELECTRONIC TECHNICIAN AND I CAN REPAIR YOUR PCB .PLEASE CONTACT ME AT andrew788@yahoo.com
Nov 07, 2007 | Black & Decker TRO360 Toast-R-Oven Toaster...
Breville BOV800XL 1800 Watts Toaster Oven with Convection Cooking Logo
370 people viewed this question
Top Breville Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Tom Chichester
Raviteja
Are you a Breville Toaster Oven Expert? Answer questions, earn points and help others
