HP Pavilion dv9010us. Has lost ability to get an IP address for the wired NIC, wireless NIC, and for an add-on D-Link USB wireless NIC. I've installed new drivers. Still nothing. I had been able to fix this by rebooting, but now nothing has worked, including HP's help which is now talking about restoring the computer to original factory settings (which would lose all my programs and take 2-3 days work to set up again and I'm still not sure it would work). Is this hardware or software problem? How do I fix?
  • 3 more comments
  • David English Jun 24, 2009
    Tried netsh resets. Still no network access. Both wired and wireless can find the router, but do not obtain an IP address, subnet mask, gateway, etc. I only get system generated IP addr & subnet mask. See "Status" & "details" below. I get the same results whether using the nVidia nForce wired LAN controller, the Broadcom wireless controller, or a new external D-Link wireless NIC (just different IP adresses, but all starting with 169.254...).
    I now have an additional problem--Diagnostics Policy Service will not run when I click on "Diagnose & Repair." It is set to "Automatic" in the Services window, but when I click on "Diagnose & Repair," I get the msg that I have to start it manually. When I do, it starts and then stops with the msg that it will not run b/c there is no demand for its service. I assume that one of the netsh resets I executed messed up something in the registry so that my request does not interact properly with Diagnostics Policy Service anymore.
    So, is this a software issue, or could it be a hardware issue? For background, the first time I had any problem (last week), I was able to restore network frunction by rebooting, maybe twice. But that no longer works. Hope you have some answers.
    David English
    v\:* {behavior:url(#default#VML);}
    o\:* {behavior:url(#default#VML);}
    w\:* {behavior:url(#default#VML);}
    .shape {behavior:url(#default#VML);}
    Normal
    0
    MicrosoftInternetExplorer4
    /* Style Definitions */
    table.MsoNormalTable
    {mso-style-name:"Table Normal";
    mso-tstyle-rowband-size:0;
    mso-tstyle-colband-size:0;
    mso-style-noshow:yes;
    mso-style-parent:"";
    mso-padding-alt:0in 5.4pt 0in 5.4pt;
    mso-para-margin:0in;
    mso-para-margin-bottom:.0001pt;
    mso-pagination:widow-orphan;
    font-size:10.0pt;
    font-family:"Times New Roman";}
    I just discovered that networking works in Safe Mode including the Internet. (Computer is able to get normal IP address, mask, gateway, etc from router.) But I still have the same problem in normal mode.
  • David English Jun 25, 2009
    At someone's suggestion, I tried suspending my ESET firewall and that enabled the Broadcom wireless NIC to obtain an IP address. It did not allow the nVidia nForce wired NIC to do so. However, after working with ESET to upgrade to the latest version of their software, I was able to get ALL NICs working--the on board wireless, on board wired, and the D-Link external USB wireless NIC.
    I had previously checked ipconfig and released and renewed (renew did not work until firewall issue was resolved). The results of the ipconfig /all was exactly the same as the jpg results posted in my original question.
    I had also tried restoring the Vista to an earlier restore point and then to my earliest restore point. Neither of them worked b/c ESET (firewall) was still running.
    I am still left with a non-functioning "Diagnose and repair" command. I get the msg that Diagnostic Policy Service is not running and to click to open the Services window and start it. When I open Services, I find that DPS is set to "automatic," but is not started and I cannot get it enabled to work with "Diagnose and repair." This seemed to happen after I had run various netsh resets. Any ideas how to get it corrected?
    Thx.
    David English
    See added comments. Both wired & wireless NICs came with and are internal to the laptop and have been updated to latest available drivers.
    Issue was firewall.
    If you can help on "Diagnose & repair" issue, that would be great.
  • David English Jul 01, 2009
    I could not start them b/c "Start" was grayed out. I set them all to "automatic," but that did not work. I can live without this if necessary.
    Thx for your suggestion.
  • 13,433 Answers
To start the service, right click on its name and select Start.
Make sure the following are started, the repair should work.
Diagnostic Policy service
Diagnostic Service Host
Diagnostic System host.
Ones all 3 are turned on try and see if the repair function work.
Posted on Jun 26, 2009
  • Ekse Jul 01, 2009
    thats odd, are you signed in as the administrator? well let me know if you need anything else.
  • 508 Answers
Call the manufacturer of the wireless card the software may not be microsoft certified!
Posted on Jun 25, 2009
    President:
  • 392 Answers
First thing go to device manager and just check for the network adapters, if any yellow mark is there or not. If not then the hardware is working quite fine...
1. Did u recently update any drivers of ur wireless devices. 2. Did u stop any wireless services accidentally,
go to command prompt and type ipconfig/all ... then u will find any IP addresses for the listed network adapters.
Please clarify the above points and let me know... so that we will get the exact problem.
Posted on Jun 24, 2009
  • M.Jeevan Chaitanya
    M.Jeevan Chaitanya Jun 24, 2009
    The problem is that in the normal mode one of the wireless services are not starting or any .ini files are not initialising , for that to Restore your system as mentioned below
    But first of all before restoring your computer please try these
    Step - 1:-. Goto Start/run and enter "msconfig" (without the quotes) and press enter .. then system configuration utility will open and then check for the "general" tab in that select Normal Startup and then click Apply and restart your system. This may solve your problem. If not go to Step 2 mentioned below.
    Step- 2:- goto Start/Run and enter "services.msc" (without the quotes) and press enter, this will open a tab. In that look for Right side pane and scroll down till you see "Wireless Zero Configuration" in that check for the "status" whether it is started or not , if it is not started and "startup type " is not " Automatic" the right click the "Wireless Zero Configuration " tab and then select properties in that click Start option and then change the startup status to automatic.
    If the above also doesnt work then try the step-3. this will definitely solve ur problem .. before trying this step , remember the approximate date when the devices worked for u properly in the normal mode.
    Step-3 : Restore your Computer to an older date.
    Fot this to do Go to Start/all programs/accessories/system tools/ system restore
    then select the option "Restore my computer to an earlier time" and then proceed to next , then in the calender shown on your left pane click the bold date when ur devices worked properly and select next and proceed.. then your system will be restarted and opens in the normal mode with all the services running.
    Good luck ..
    Please rate my answer to get me paid for the service done... Thank u ....
    President:
  • 1,952 Answers
As one of the affected, I can tell you these laptops are a PITA with broadcom wireless chips and also the RTC problem. So now it comes out that something on the MOBO is fubar, no kidding. People have been saying for months that the BIOS is not APIC compliant considering that everytime I try to set the RTC I get a total kernel hardlock HP Pavilion dv9010us. Has lost - icon_mad.gif . The new b43 wireless drivers don't work with the brandnew 2.6.24 patched kernel. These two system series are probably responsible for 90% of all problems on forums with wireless stack. And HP refuses to fix their broken hardware/firmware.
    Genius:
  • 1,689 Answers
Hi davden,
the issue on your computer is that the TCP/IP (Internet Protocol) has been disabled or uninstalled or corrupted.
here are the best solutions to the problem.
Enable
Reset
or
Reinstall TCP/IP
http://support.microsoft.com/kb/299357
http://support.microsoft.com/kb/315236
http://www.mpitech.com/docout/howto_install_tcpip_on_windows.htm
http://www.petri.co.il/reinstall_tcp_ip_on_windows_xp.htm
http://www.netstumbler.org/f48/disable-enable-tcp-ip-command-prompt-13203/
http://answers.yahoo.com/question/index?qid=20080113204458AArDDgR
hope these helps.
regards,
voodoo
Posted on Jun 23, 2009
I need to add an IP address to a Kocera 1320d that has been hooked up as a USB printer, how do i do this?
You can print a status page by pressing for 5 seconds the green button and see what IP address has the printer. Then you can modify it through your PC. The most important is that you have a NIC (network interfade card), because this printer (FS-1320D) comes from Kyocera without a NIC. Unless your printer is already intergrated with a NIC.
Aug 21, 2014 | Kyocera FS-1320D
Tip
Set up a Wireless printer on your Router for use with a wired PC
First install the Wireless printer driver using the Wizard by connecting either the Ethernet cable to the router during the install process when asked this will set up your wireless laptop with the correct printer port based on the Wireless Node Name it will also use the printers inbuilt MAC address. This is standard install and will work for all your Wireless PC's however if you have a Wired (ethernet) PC connected to your Router this process will not work a wireless port will not work with a wired computer.
Follow my 3 steps below to set up standard IP ports for Wired PC's also connected to your Router.
STEP 1: Find your MAC address for the wireless printer (all types of Network Cards will have one so this is no different) this will either be found under the LCD control panel or may even be printer on the bottom of the printer or Print server if it is seperate set this MAC address with an IP address as a reservation in your admin panel of your router 192.168.0.10 in this example.
You can normally enter your Router this using 192.168.0.1 typed in your browser (not the search engine) as all routers are different check here for your make and model http://www.routerpasswords.com if you can't find the MAC address try using ipconfig /all from them command prompt it will be the physical address aka the MAC address
STEP 2:
Install the Printer as a USB printer port by connecting the USB cable to the PC you want the wired printer driver installed on when finished go to the printer driver properties for the driver you have just added, click the port tab and click add standard IP port as shown below, then disconnect the USB lead this is only required to make sure the correct inf file is used on the driver install and connect your Ethernet cable from you computers NIC to a spare RJ45 socket on the Router.
STEP 3: To check that the Printer has the correct IP address then test using the tracert OR ping command for the IP address that you have reserved on your router, this is a necessary step otherwise when the lease expires it may take another IP address and your Printer driver will not work unless your printer has the reserved address, it will throw a printer error.
c:ping 192.168.0.10
(this example shows a Standard TCP/IP Port for a Brother DCP-340CW)
Also check in your routers admin panel to see if the Wireless Printer is set up with the correct IP and MAC address, if you still can't find it eliminate your known MAC addresses from all your network cards the one left will be your Printer Server NIC in your Wireless Printer.
If you have setup the incorrect IP and or MAC address you will get this window when you try to add the TCP/IP port
That's it try a test print and you will see it burst into life.... Happy Printing
on Dec 02, 2009 | Office Equipment & Supplies
How to connect hp pavilion to brother mfc9560cdw without router
This model Bother printer has a 10baseT LAN connection and can be connected to your LAN network and to your HP laptop via the wireless router. Connect a LAN cable from the printer to the wireless router.
To print from your HP laptop, check the IP address range your wireless router issues to your wireless network, it maybe 192.168.1.*** then configure the brother printer with a fixed IP address with the same IP address range but higher address eg. 192.168.1.10 so it does not clash with any other IP addresses.
Next install the Brother printer driver normally.
Then configure the Brother printer Properties.
Click Start - Printers and faxes - right click on the Brother printer - click Properties - Port tab - click Add Port - Standard TCP/IP port -
Port Name eg. 192.168.1.10
Printer name eg Brother
Click OK
Then do a TEST print if it does not work then the IP address is probably incorrect.
Jul 07, 2012 | Brother MFC9560CDW AllInOne Laser Printer
Wireless security enabled and lan not able to work together
Try to set up an IP reservation for your ethernet using the MAC address of your NIC, this way the router can't steal it for the WLAN.
Mkae sure that if the router is run as a DHCP server that there are suffcient on IP address range to allow extra PC's to be leased an IP address.
I suggest that you disable in WZCSVC on both your wired PC and wireless PC and use the laptops own NIC connection software and the routers WEP or WPA-PSK to allow you to connect your wireless
Dec 14, 2009 | D-Link DI 514 Wireless Router (DI-514)
How to add a HP Pavilion DV4000 to a wireless network?I already have two computers (Vista) running on the network, this HP has XP?
open network connection
right click on wireless network connection and open properties...
select internet protocol (TCP/IP) and open properties...
obtain ip address automatic and dns automatic
and after that connect
Aug 28, 2009 | Computers & Internet
Vista ultimate 32 not connecting to wireless
169.254.x.x IP suggests that your NIC is not communicating with the DHCP server of your Router. Try disabling/enabling the NIC card and in the TCP/IP properties, make sure that the IP address is configured as "Bobtain IP address automatically"
Also try installing the latest drivers for your NIC card.
May 13, 2009 | Trendware TRENDnet 4-port Switch - 54 Mbps...
NIC problem
What kind of card? Wireless? If so, the computer's IP address must be configured to the same range as the router, and the router must be configured to accept incoming connections from your computer.
Oct 27, 2008 | HP Pavilion dv1000 Notebook
Wireless connection works but no plug in connection
The wired nic in your laptop will have a separate ip address than your wireless nic. I suspect you either have the router not set to hand out ip addresses, the info it is handing out is wrong, or you may have a static ip set. Did you ever have the laptop working on the wired nic?
Try disabling the wireless connection, plug up the cat 5 cable, open a dos prompt and type;
ipconfig /all
Notice the information. Now unplug the cable, enable the wireless connection and do the same for the wireless nic. The ip address should be different, but everything else should be the same. Let me know what you find.
Oct 12, 2008 | D-Link AirPlus DI-524 Wireless Router
Problem with Fast Ethernet NIC and Broadcom WLAN adapter
you need to dissable dhcp in the router and manually assign ip address as dhcp automatically changes your pc's ip address, for example if your router ip address is 192.168.0.1, then you go online with your notebook first it will get 192.168.0.2, then the next pc online will get 192.168.0.3, if you go online with the pc first it will get the 192.168.0.2 instead
Aug 29, 2008 | HP Pavilion dv1000 Notebook
Computers & Internet Logo
116 people viewed this question
Alun Cox
David Payne
David Payne
