Question about Delta Drills
Need manual for rockwell series 15-655 drill press
5 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: how to remove chuck from drill press
I just looked at a breakdown for this tool and it is not that clear. But to get an owners manual you can go to Searspartsdirect.com and type in your model number and look at the same schematici I did and also order a manual for about 7.50. Usually though on a drill press like that it would be a morse taper. Do you see a slot cut thru the spindle on both sides, if so there should be a tapered key that came with the unit. In that case what you would need to do it put the key in the slot and tap it with a hammer to remove the adaptor and chuck. Let me know if I can help further
Posted on Jan 03, 2009
rowdy45176
  • 2176 Answers
SOURCE: I need a cutaway diagram for my Craftsman 15 1/2'' drill press.
You need you exact model number and go to Searspartsdirect.com and you can view a schematic online or print one out. If you have trouble let me know and I will see what I can do.
Posted on Jan 07, 2009
  • 165 Answers
SOURCE: bent spindle in vintage drill press. Possibly
Remove spindle and take to a machine shop where they can use a dial indicator along with a press to straighten the shaft.
Posted on Feb 28, 2010
SOURCE: Bought a craftsman drill press mod. 11321370 and
try managemylife.com
Posted on Dec 27, 2010
I need a manual for a Rockwell Drill EFI-2P Series 70-120
Google (Rockwell)(EFI-2P)(manual) without parens.
Oct 31, 2016 | Drills
Does any know much about a Rockwell delta drill press model o-2140-a?
Rockwell Manufacturing Co. - Photo Index ...
vintagemachinery.org/mfgindex/detail.aspx?id=698&tab=4
02/24/2015, Jointer, 6" Short Bed Jointer, Model No. on Motor: JB82B710CW · 6" ...12/30/2014, Drill Press, Delta Rockwell Homecraft Drill Press 11-120 · 11" ...
Aug 27, 2015 | Delta Drills
Rockwell drill press 15-085
Rockwell drill press has no enough variable speed. You can't easy to assemble and use. If you want to find best drill press in 2018 go to the link Best Drill Press 2018 Top 10 Drill Press
I think it can help you.
Nov 18, 2012 | Drills
DELTA ROCKWELL DRILL PRESS SERIES 15-017 MANUAL
1. Rugged, heavy duty construction throughout
2. Exceptional Versatility
3. Famous built-in Delta "quality" features
More details about the best drill press go to the website Best Drill Press For DIY Professionals In 2018
Jan 27, 2012 | Delta Cycle Rothko Rolling Bicycle Stand
Rockwell/ delta 70-400 drill press manual
Not bad. Almost like the original.
If you find out the best drill press in 2018 go to the website Best Drill Press For DIY Professionals In 2018
It helps you to find out best drill press.
Oct 05, 2011 | Delta Woodworking Delta Rockwell 14 Inch...
Rockwell drillpress, model #15-069, S/N 1696907 How to reinstall return coil spring for down ward operating arm.
Hi wildoak1,
Welcome to fixya!
Found a forum where the guys were discussing various ways of installing the pinion return spring. Read down the page and you'll find where they start discussing it.: http://www.owwm.org/viewtopic.php?f=1&t=72586&p=507720&hilit=replace+pinion+return+spring+Rockwell#p507720
Hope this helps. If it does, I'd appreciate your vote. Keeps me working here......
Thanks,
Handie Andie
Jun 20, 2011 | Delta rockwell 15" Vs6 Drill Press...
We own an old Rockwell International Model 15 drill and tap machine. The chuck needs to be replaced. Where can I purchase one?
Click here for a site that WILL have everything you need for that old work horse. Hope you have a fat wallet.
Aug 26, 2010 | Delta Rockwelldelta 15" Drill Press...
Where can I buy an, on off switch for a model 15 floor drill press?
That can be obtained direct from rockwell, or SearPartsDirect.com
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Aug 08, 2010 | Delta Rockwell 15 Inch Utility Drill...
Removal of chuck
Harold, Have you tried looking from the top? Maybe you can put a rod into the spindle from the top and give it a tap. Al Kupchella
Apr 10, 2010 | Turner Walker-turner Rockwell 20 Inch...
Bent spindle in vintage drill press. Possibly Rockwell Press. 3 phase floor model
Nov 11, 2009 | Turner Walker-turner Rockwell 20 Inch...
Open Questions:
How fix Delta/Rockwell 15 drill press from chuck wobbling. I purchased a Delta / Rockwell 15 drill press model 15-091. The chuck wobbles. I ordered some wedges to remove chuck.jacobs #6 wedges After soaking in pb blaster I removed chuck with ease with the wedges. must have Now after looking at what is called the spindle I believe...it is wobbling. I wonder if I am looking at an arbor or the spindle? Above this piece is a threaded section that is about 1/2. I thought of maybe getting a jacobs 34-33c chuck to screw onto this. Seems like if the spindle/arbor is wobbling it still would not run straight or be difficult to properly seat it. I do know that some quills come with a slot to fit a wedge for removing the arbor. Mine does not have this. Without a proper way to remove an arbor it leads me to believe maybe it doesn't have an arbor. Seems that I am looking at the actual spindle. I need this drill press for precision work. If you know about this model.. Please Help !!!!! I am stuck. Do I need to buy a whole spindle? If it is in fact an arbor how are you supposed to remove it? I thought if it is an arbor I could take a grinder and cut 2 slots in the arbor. Then take a really thick washer and cut out a section. to make it a u shape then slide the washer into the grooves I cut out. Then use the wedges on top of that. After tapping the wedges I would think it would come free. Unless it is one solid rod with a taper at the end like an arbor usually has AKA the spindle....HELP!!!! I can't find ANY info on this anywhere. I know someone must have worked on these before.
May 05, 2016 | Delta Drills
Drills Logo
234 people viewed this question
Top Delta Drills Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Delta Drill Expert? Answer questions, earn points and help others
