Question about As Seen On TV Finishing Touch Hair Trimmer
Bolens 25B-521A765 how to replace edger blade
The line that I'm looking for came as stock supplied when I bought the trimmer.I can't believe that Bolens doesn't have a scource for replacement line. Help. Gene
Genuine MTD 791 181460B Reel Line Assy McCulloch Ryobi Troy Bilt Bolens OEM
Reel and Line Assembly
Bolens String Trimmer Spool 791 153577B
the spools come with line already installed,they are all for bolens,line is generic,you buy your own line,there are 2 different sizes,and a bunch of types,like round or star,you buy generic line because bolens wont make any money if they sold "BOLENS" line.
Jul 11, 2015 | Garden
Where can I get an edger blade
any home improvement store that sells lawn equipment
May 17, 2014 | Mtd 25B-520D200 CA Gas Lawn Edger
Cranks easy runs good on idle but does not rev up under load
Clean or replace carburetor, or clean exhaust side of cylinder behind muffler.
Oct 01, 2013 | Mtd 25B-520D200 CA Gas Lawn Edger
What holds pully on shaft for lawn keeper blade
I have an old model Lawn Keeper gas edger with a 2HP Briggs and Stratton engine. It uses a 30" fan belt to drive the cutting blade and both pulleys have an alllen head set screw holding the pulleys to the shafts. The pulleys are cast aluminum and the set screw and shafts are steel so I find need penetrating oil and heat to loosen the set screw in order to push the drive pulley further on the shaft to make room to replace the drive belt.
May 17, 2012 | Mtd 25B-520D200 CA Gas Lawn Edger
Edger will start and runs but sputters and runs slow.
This is related to the diaphragm between the tank and the carburetor part number 495770 you can purchase from a shop like www.arcolawn.com and replace it very easily.
Best wishes
Joe
Feb 13, 2011 | Mtd 25B-520D200 CA Gas Lawn Edger
Is the nut for blade removal right hand?
on blade removal it is opposite. Lefty tighty, righty loosen
Mar 29, 2010 | Mtd 25B-520D200 CA Gas Lawn Edger
Need to replce cord
Hi
The instructions in the following link refer to lawn mower but in my experience the mechnisim is the same :
http://www.cockeyed.com/lessons/mower/mower01.shtml
hope I helped you
Have a great day
Jul 19, 2009 | Mtd 25B-520D200 CA Gas Lawn Edger
As Seen On TV Finishing Touch Hair Trimmer Logo
56 people viewed this question
Top As Seen On TV Health & Beauty Experts
Tom Chichester
Are you an As Seen On TV Health and Beauty Expert? Answer questions, earn points and help others
