Question about Mtd Garden
My mower is idleing up and down,stalling, dieing then restarting. why?
1995 MTD riding mower model #1350665g511
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 140 Answers
Contaminated fuel,dump fuel,install new fuel filter and clean carb if need be !
Posted on Sep 21, 2014
  • 246 Answers
SOURCE: lawnmower stalls out
Hello:
>>The Following is a Basic Instruction File I made for this. Any Input is Appreciated. I Usually Suggest you Check the Following in this Order for a Problem like yours. 1- Check the Gas Tank Cap and Ensure it is Venting the Tank. A Vacuum Builds in the Tank and the Gas Flow Stops or Slows (15 to 45 Minutes and if the Small Grainular Sand is in the Tank it can Take Several Days of Constant Running to Bring All the Sand Particales to the Tank Outlet Port) to a Point it Shuts Off the Engine. 2- Operate the Equipment Until it Quits (15min to 1hr). Then Immediately Check for Fire from the Plug. If the Plug is Firing, then 3- Check the Carburetor Solenoid. If the Carburetor Shut Off Solenoid has Current, then Remove the Carburetor Solenoid and Go to the Hardware Store. Purchase a Bolt of the Same Diameter and Threads. It Needs to be 3/4" Long. Put this Bolt in Place of the Solenoid. If this Corrects the Engine Problem, then Replace the Solenoid. ***NOTE: THIS IS FOR CHECKING THE SOLENOID ONLY I NEVER SUGGEST YOU OPERATE THE ENGINE WITH THE SOLENOID OUT OF THE CARBURETOR EXCEPT FOR TESTING PURPOSES*** Sometimes the Plunger is Moving, Just Not Far Enough to Allow the Gas to Enter the Jets. 4- Depending on the Model Mower, it can Also be the Pickup Tube in the Gas Tank. If No Fire, then Remove the Shut Off Wire from the Coil and Check for Fire. If Still No Fire, then the Ign Module or Coil is Bad. **Even if the Coil is New of Fairly New, it can Still be Bad.** On JD Mowers; Remove the Igniter/Module and the Coil and have the Local JD Dealer Test them.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 15, 2009
  • 143 Answers
SOURCE: mtd yard bug model - 198707 riding lawn mower blade belt size?
I dont know the belt size but if you go to mtd belts in Jackssmallengines.com you should find it. Stephen.
Posted on Aug 23, 2009
  • 2841 Answers
SOURCE: mtd riding mower: right mower blade cutting
The blade can be bent or the deck is not level. Adjust the deck and level it from side to side. Now level it from front to rear with the front of the deck 1/4" lower than the back. If after leveling it, you find it still cuts uneven remove all blades and inspect them. You will more than likely find one is bent. Replace a bent blade.
Posted on Sep 18, 2009
  • 33 Answers
SOURCE: MTD riding mower does not move forward or reverse.
this is a belt driven transmission. from the engine driven pulley going aft towards the xmission differential there is another smaller variable speed pulley, there is a long belt between these two, from the variable speed pulley there is a larger xmission pulley that sits kitty-corner to it with a belt between these two. This larger "xmission pulley" is what drives the differential and depending upon which gear you have selected, makes it go forward or reverse. Check that both belts between pulleys are on, check that pulley's hardware is completely secured (nuts tightened down) The heads of these pulley's are splined to align to the shaft(s) and if they aren't tight, they will just spin and not engage the transmission. If your battery is under the seat, remove it and you should be able to see and access the aft pulleys. If both belts are on and engaging the pulley's and the shaft is turning on the transmission pulley than you have transmission differential failure. Bet it's the belt off or pulley head loose. Good luck, hope this helps
Posted on Apr 14, 2010
suzukiracing
  • 200 Answers
SOURCE: engine hesitates and dies when hot, restarts fine, then dies agai
Check the fuel pump.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Posted on Jul 20, 2010
MTD riding mower shuts down engine when I try to engage mower deck?
I HOPE YOU CONNECTED ALL THE SWITCHES WITH JUMPER WIRES ?
Jun 10, 2017 | Mtd Garden
I HAVE A 420CC POWERMORE MTD RIDING MOWER ICAN MOWER FOR ABOUT 15 MIN AND THE MOWER WILL SHUT DOWN NO ONE CAN FIND THE PROBLEM.
if it dies when it gets hot and starts after cooling. it is boiling the fuel. move the fuel line away from the heat at the engine. maybe put some foam wrap on it. ir the coil may be breaking down at hot temperatures. be sure the fins are clean so the engine can cool itself.
Nov 10, 2016 | Mtd Garden
My mtd mower starts and runs, but after about 15 minutes, it dies. When it cools, it starts again with the same problem.
Could be the vent in gas cap. When it stalls try to open gas cap if it hisses change cap. It could also be fuel filter if fuel cap is good.
Jun 14, 2014 | Mtd 46" Dozer Blade, Fits All & Yard -...
I need a parts manual for mtd model 95178.riding lawn mower
Go to MTD website and down load a manual.
May 13, 2014 | Mtd Garden
Lawn man idles too fast
Could be a broken or worn throttle shaft,letting air in to the carb when it shouldn't !
Mar 22, 2014 | Mtd Arnold Corp RearMounted Bagger for MTD...
Bought 2 brand new MTD 3.5 HP 20 inch cut lawn mowers Model #11A - 020B352 Both mowers run until hot then cut out and will not restart only turn over with a squirt of fuel bulb then stall again. Both...
heres a few things to check, make sure that the oil is not over filled, you might have bad fuel,, and check the spark plugs on both to make sure they aren't fouled by fuel, if so,, clean the plug and regap them,
Jun 02, 2011 | Mtd Garden
Lawn mower idling up and down until it shuts off.
clean or replace your air cleaner that will fix it,I hope this helps you?
Oct 10, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Have a 1996 mtd 18.5 hp 46 inch deck riding
it sounds like the needle screw could be bent at the tip if not try turning the screw all the way in & out 1-1/2 turns & try that if i can help further let me know thanks wade
Jul 05, 2009 | Garden
MTD 12.5 HP Ride On Mower won't stay running
It could be a needle valve sticking or a mal-adjusted float but more common is a fuel filter that is restricted, once you use up the fuel in the line and float bowl it runs out and dies. A less common but easily tested issue is when the mower has run for the amount of time it begins to sputter and die, loosen the cap on the fuel tank just a bit, if it helps or resolves the issue the vent in the cap may be clogged.
May 26, 2009 | Mtd Garden
Garden Logo
49 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
