Question about Krups 203-42 Electric Blades Grinder
How open bosch grinder? - Krups 203-42 Electric Blades Grinder
I need a user manual for bosch model 0601347271 angle grinder
For Bosch Angle Grinder Operating/Safety Instructions 1347A, 1348AE I suggest check this link (under image)...
User Guide link: Bosch Angle Grinder
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice weekend.
Nov 18, 2011 | Saws
I have a Bosch 7-1/2"
I could be a bad plug or a frade power cord. Whith the grinder unplugged make sure the grinding wheel turns by hand. If it does it could be a bad on off switch or the brushes in the motor could be worn.
Mar 10, 2011 | Bosch Saws
Worn gears
I would just buy a new one.
parts could cost almost as much.
don't forget the rest of the grinder is just as worn out too
Jun 24, 2010 | Bosch 1375A 412Inch Angle Grinder
How do I open my Bosch MKM 6003 coffee grinder? I can't pry it open and it doesn't have screws!
you should just a little rotate down part of the device. after that it can be taken off.
Dec 17, 2009 | Bosch MKM 6000 Electric Blades Grinder
Manufacturers instructions for a 5" bosch angle grinder
Since most manufacturers require a valid model number to obtain a owner's manual, I can't give you the direct link for your 5" grinder without that information.
However, here's a link to the Bosch web site and their manual section where you can enter in your model number and get a free download of the manual you can save on your computer or print out.
I suggest you set up a new folder on your PC titled "household items" and save a copy titled "Manuals" etc. so you will always have a copy for future use and reference.
http://www.boschtools.com/Service/ProductServices/Pages/ManualsandPartsDefault.aspx
I hope you find this Very Helpful and best regards!
Oct 09, 2009 | Bosch 5" Small Angle Grinder
Bosch angle grinder stopped cold when tapped lightly
Yes, if you have taken the handle halves apart (unplug tool first) check with your meter thru the blades on the cord to the switch contacts and then lock the switch in the on position and check across the switch and then remove the brush caps and brushes and check thru to the brush holders, if at any time you lose continuity then that would be your problem. Let me know if I can help further.
Mar 09, 2009 | Bosch 5" Small Angle Grinder
How do you take a bosch coffe grinder apart?
Using a screw driver or the old butter, pry off the bottom piece.  Be careful though, getting it back together is really tricky if you don't pay attention to where all the parts go.
Feb 05, 2008 | Bosch MKM 6000 Electric Blades Grinder
Krups 203-42 Electric Blades Grinder Logo
44 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
