Question about Dryers
Kenmore He 3 electric dryer takes two cycles on high to dry clothes. We've cleaned out the exterior vent. Thinking we should try to remove the ffront kickplate to see if there is a clog where the lint trap feeds into the hose. Is this the right avenue? (Any advice on removing front plate would also be helpful. VERY handy hubby struggling with it for some reason.)
  • 5,911 Answers
Yes, this is the avenue you should be following if you have already confirmed the external exhaust ventilation to be clean. Make sure you have the dryer unplugged before servicing anything inside the unit. There is still live voltage present, even with the unit turned off.
The front kick plate is removed by loosening the screws under the bottom front edge. With the screws removed, the panel will drop down, then come off. After you remove the kick plate, open the dryer door and remove the lint screen (you will need to do this in order to remove the air blower fan housing). With the lint screen removed, locate the screws on the blower fan housing. Remove the screws and remove the blower fan housing to access the fan. Blow out any lint accumulations and verify there is nothing caught in the fan that will prevent it from turning.
You're on the right track. The majority of all dryer heat related problems are attributed to poorly installed or clogged ventilation. Cleaning the vent ducting and dryer interior can drastically improve performance. If you have further questions, or need further assistance please let me know. I hope this helps you.
Posted on Jun 23, 2009
  • 351 Answers
You need to clean the vents and lint trap and etc....and i would need the model number to tell you which route to take
What does my Maytag Bravos 300 quite series electric dryer take so long to dry clothes?
Those sensor bars can become faulty and that is probably the problem. Try cleaning them off with a clean rag. Good Luck!
Sep 08, 2014 | Maytag Dryers
Kenmore 110.66902690 electric dryer does not dry completely
Dear Barry,
Try 2 things.
One, be certain the clothes are very dry coming out of the washing machine.
If the washer leaves the clothes wet ( like the belt might be slipping), it can take the dryer forever to finish drying the clothes.
You can tell by hand-wringing them.
You should not be able to get any water out of them by hand-wringing after they have spun dry in the washer.
Two, try running a load with the vent hose unhooked off the back of the dryer.
If this fixes the problem, you are having a "clogged vent" issue somehow.
Be blessed.
Apr 16, 2013 | Dryers
Why isn't My Kenmore Heavy Duty 70 Series Soft Heat Extra Capacity Electric Dryer drying clothes on any one cycle?
One possibility: Air flow! Make sure that the lint trap is cleaned before each cycle. You likely need to thoroughly clean out the vent piping out the back of the machine- a buildup of lint in here can also restrict airflow.
Sep 04, 2012 | Kenmore 659 Electric Dryer
Doesn't dry fast
The first thing I will ask is this: does it take several cycles to dry? if so, its most likely the vent and not the dryer especially if it vents on the roof...I would say to be sure, remove vent off of rear of dryer and try a regular load of clothes...if they dry with hose off...your vent is clogged and needs to be cleaned..the screen on the roof vent usually gets clogged with lint...
Nov 28, 2010 | Kenmore Elite HE4 Electric Dryer
We have a Kenmore 400 Series dryer. It heats up but our clothes is not getting dry. We have to cycle it twice to get our clothes dry on high heat. Any idea why it would take 2 cycles to dry?
This was the out vent of my dryer... If it gets this bad... open up the dryer housing and clean inside too. Also make sure the intake is free of lint.
Aug 23, 2010 | Kenmore 74602 Gas Dryer
Takes too long to dry or keeps running when clothes are dry
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
May 07, 2009 | Kenmore Elite Oasis 6809 Electric Dryer
Dryer takes too long to dry a load
Have you checked the lint screen? pull the lint screen out and remove the lint then hold flat and pour water on it. Does the screen hold the water or does the water flow through? If it holds water, then you must actually clean the film that has coated the screening material. Use dish soap and scrub lightly then rinse clean. and check again.
Apr 02, 2009 | Kenmore 62872 Electric Dryer
My kenmore electric dryer takes 3 times the normal time to dry clothes. It does eventually dry them though. I'm just using way too much electricity.
90% of drying complaints are due to problems with the vent. Try disconnecting the vent and run one load through it.If it dries properly clean out or replace your vent
Mar 06, 2009 | Kenmore 84052 Dryer
Extremely low drum heat but setting is on HIGH.
Electric (Kenmore - 60931) dryer takes forever (several cycles) lately to dry clothes set on high heat (actual heat in tub feels low though). There are no obstructions in the venting and the 240 volt connection is fine. The timer rotates the dial (timer motor working). Help!!!
Sep 15, 2008 | Zanussi TC7102W Electric Dryer
Kenmore Electric Dryer 68731
If still heating, clean out vent and check for kinks. Also, REMOVE PLUG FIRST!! Remove back and remove four screw holding filter duct assembly at bottom left. Pull duct toward rear and reach into bottom of duct and remove lint. Also, wash out filter screen.
Nov 17, 2007 | Kenmore 659 Electric Dryer
Dryers Logo
152 people viewed this question
Top Dryers Experts
Marvin
Marvin
