Question about Toro Electric Ultra Blower/Vac 12 Amp
HOW LONG IS MY TORO WARRANTY - Toro Electric Ultra Blower/Vac 12 Amp
I have a Toro lawn mower that I purchased last year, it was working great until one day I was using it and advance for the propell stopped working. Also I noticed the mower will not roll backwards. Please...
I know this may sound too simple, but Toro warranties their mowers for 2 full years to the original owner. Go to www.TORO.com to find your nearest servicing dealer. They should be able to repair your mower at no cost to you.
This sounds like there is possible an internal transmission failure on your mower.
Nov 30, 2010 | Garden
I bought a Toro rear wheel drive lawnmower last May.I have never had any problems with it until now. the left rear wheel sticks. With the power off, I can roll it a little and it will stick and then I can...
The gear drive is probably just a little dirty. You can clean and lube the gears by pulling of the rear wheels and then remove the rear drive gears. Clean them and the axle and reinstall. Be careful to reinstall in the same direction as was removed. A smearing of axle grease in the axle and inside of the drive gears should take care of this.
Also remember that TORO mowers come with a 2 year warranty. Go to www.toro.com to find your nearest servicing dealer.
Nov 04, 2010 | Toro Lawn Mower With Toro Power Tools
My toro lawn mower is hard to start in cold weather. (40 to 50 degrees), I have an auto-choke. mower was bought in spring of 2010.
This is covered by the Warranty. Take it to a local dealer like www.arcolawn.com and have the thermostat replaced.
The first generation thermostats are known for sticking.
Good luck
Joe
Nov 01, 2010 | Toro Lawnmower 20099 Mower Mowers Lawn
I have 6.5 hp toro mower and the self propelled wheels quit working. I need to know how to fix it - THANKS
Not sure which model you have, but the rear wheel drive that I have, 20070, transmission goes out every year. Toro had a real bad design on that transmission and they know it. They made a change in 2009 models to try and eliminate the problem and also give a lifetime warranty on the transmission. Model years 2006 thru 2008 has a single bearing on a half shaft and the torque of the drive belt is too much for that single bearing. I am on my second replacement and had an extreme conversation with Customer Service. Go past the first level, "Sorry It's Out of Warranty" to supervision and let them know about their product and insist they repair it. This has been going on for a month for me but I think you have to push these manufacturers to do what is right.
Oct 04, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Proline 400 blades fall out of engage
if your unit desengages have the clutch gap checked. also you should check for shorts in your safty wiring. the other would be a bad switch. finely your under warranty this my be warranted.take it to a toro dealer or call one to make sure
Sep 07, 2009 | Toro Co M/R Blwr/Trmmr Rear Bag Kit
My toro blower stopped working after only 10 minutes
Hi, normally when an electric motor smells of burning the damage is done, if it's new you need to get it fixed under warranty, trying to repair it yourself will void warranty
Aug 30, 2009 | Toro Electric Ultra Blower/Vac 12 Amp
I need to replace my drive assembly on my Toro model 20071. How do I go about it?
WHere is a toro dealer that does warranty repair work in Jacksonville, FL?
Jul 01, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Electric Ultra Blower/Vac 12 Amp Logo
83 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
