Question about Kenwood KAC-8104D Car Audio Amplifier
I have the kenwood kac-8104d amp and it lights up and everything, but it doesnt power my subs hooked up to it. I have no idea why because theres power going through andd the amp is turning on. Any help?
    President:
  • Kenwood Master
  • 1,114 Answers
Check your RCA's from the amp to the deck, make sure it's on an output not an input on an aftermarket deck,and the input, not the pass thru on the amp. If you have it hooked up to a factory deck, you've opened a whole new can of worms! If its a factory Deck; Post the make and model of the unit if you can find it, as well as the vehicle year make and model. I get as much info as I can on it and walk you thru the details. If it's aftermarket and you've checked the above, post the make and model of the deck and I'll do the same. Hope this helps
Posted on Jun 24, 2009
Kenwoood kac-7202 redlight/no output
you blew the output Ic's (amps one or more ) you can fix this by replacing the output IC's
Jan 29, 2014 | Kenwood KAC-7202 Car Audio Amplifier
The amp.
check power fuse make sure it's not blown and gettin proper 12 volts if all connections are properly fixed maybe get it checked out
Jun 06, 2010 | Kenwood KAC-8104D Car Audio Amplifier
Amp is not operating at full potential also red portectant lite comes on kenwood kac-8104d
make sure all your wires you are using to connect the amp are 4 gauge check your ground make sure its drilled threw thick metal scuff off the paint that its grounded too and check how you have your subs wired see what ohm there wired in the you can get more power out the amp in 2 ohm then 4 ohm
Mar 31, 2010 | Kenwood KAC-8104D Car Audio Amplifier
Which are the differents diagrams to wire two sub dvc 4 ohms
I guess this Amp is stable down to 2 ohms. 500 Watts X 1. Unfortunately there is no way possible for you to present a 2 ohm load to the output of this amplifier. Here are your options.
Speakers in series with VC in parallel = 4 ohm total Z
Speakers in parallel with VC in parallel = 1 ohm total Z (not good)
Speakers in parallel with VC in series = 4 ohm total Z ( Whats the point)
Speakers in series with VC in series = 16 ohm total Z ( Whats the Point)
So your best option to maximize power transfer from your amp to your speakers would be option 1. (Z = Impedance)
Dec 13, 2009 | Kenwood KAC-8104D Car Audio Amplifier
Amp lights up, but no power to outputs.
channels mey be burned....does the amp smell like burnt electronics
Nov 07, 2009 | Kenwood KAC-8104D Car Audio Amplifier
What does it mean when the power light blinks on the amp?
genrally kenwood amps are power hungry amps so after playing for a while if it doesnt get the amount of amperage to make it work it will shut down cus you car cant charge the battery long enough for the use of that amp so my idea is try a farad capacitor and see if that helps good luck .......tk
May 29, 2009 | Kenwood KAC-7252 Car Audio Amplifier
sounds like u r overheating and then cooling try a 12volt fan
Apr 02, 2009 | Car Audio & Video
Amp wont turn on
Double check all of your connections. I know this same problem has happened to me and come to find our that all the problem was the fuse blew that is connected between the radio and amp. Also check you battery connection. Corrosion on the power cable will also cause it to have a bad connection.
Mar 15, 2009 | Kenwood KAC-8104D Car Audio Amplifier
Kenwood KAC-8104D Car Audio Amplifier Logo
345 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
