Question about Casa Vieja Probe White Ceiling Fan
Casa Vieja Turbina fan
Remote doesn't work on low
Buffalo12980
  • 625 Answers
SOURCE: Casa Vieja Probe II Ceiling Fan
look on the side of the canopy there should be a slide switch. if moving this switch has no effect, then either the switch is faulty or the connections to it may have fallen off.
Posted on Aug 22, 2007
SOURCE: casa vieja probe ceiling fan
one of the wires had disconnected and this seemed to cause the problem.
Posted on Feb 16, 2008
Nickstar19
  • 417 Answers
SOURCE: Casa Vieja Intrepid Remote Control Sensing Problem
you need the same sensors in the remote as the one ur using now the old sensors will not work
Posted on Jul 05, 2008
  • 70 Answers
SOURCE: Casa Vieja ceiling fan
sounds like the pull cord switch i dont thunk you will be able to find a replacement proberly cheaper to buy a new celing fan
Posted on Jul 25, 2008
SOURCE: Remote Control
I had the same issue. I had to replace the remote control reciever located on the fan and that did the trick.
Posted on Jun 16, 2009
I have haier split air condition Hsu 18ck03 When power supply off and comes back i manually switch on from remote.i want it auto on
Your air conditioner is not a inverter model(your model is it a low cost model )and doesn-t work automaticlly when the power is off
Aug 01, 2013 | Mitsubishi Mr. Slim MXZ30TN Air...
Fan only runs on slow speed
The receiver in the fan housing may have failed.
Apr 20, 2017 | Hunter Dryers
Turn on but remote doesn't work
I would try new batteries first. If that doesn't help then replace the remote with a universal unit that you can program to work with your TV.
Nov 13, 2012 | LG 42LC2D 42 in. LCD HDTV
94 full size blazer keyless remote doesn't work.
Does the spare remote work? Have you tried to reprogram it? These remotes are very cheaply made and prone to key pad failure. To program the remote click this LINK, if that doesn't work buy anew one on eBay for cheap.
Jun 13, 2012 | Cars & Trucks
My Maestro IR remote no longer works after 10 years
The infrared (IR) LED / remote may have stopped working. Since it emits IR light when used, you won't be able to actually see the light with the ***** eye. This makes it difficult, but not impossible to determine if the LED / remote is working or not. You can see if it works by pointing it a night time security camera - the type that has it's own built in IR LEDs to light up the area and does not need visible light to shine on the area (some video cameras can also "see" this light when playing back video taken of an active IR light source). Either record or have someone watch the display while pressing a button on the remote and aiming at the camera. You should be able to do this in broad daylight it will look like a flashlight shining into the camera.
If the LED in the remote is proved to be functioning, the IR receiver in the switch, or some other internal part of the switch may have failed. Since the receiver doesn't light up - there's no way to determine if this is the case without actually replacing the switch. It doesn't matter really, as there are no user replaceable parts in the switch - it either works, or it doesn't.
Ultimately, the best way to troubleshoot will be by replacing components with known good types. Use a battery that tests "good" on a tester, in a new or known to be good remote, used on a new or known to be good switch. You'd would deal with the situation by swapping only ONE component at a time. Once you change the device that allows to circuit to work, replace the new components with the old - except to last one; as this was likely the component that caused the failure.
Try taking the remote to a Home Depot, Lowe's or other similar store with a display of these switches. Do what you need to do to your remote to see if you can control any of the switches/ lights.
Apr 13, 2012 | Electrical Supplies
Touch buttons on this remote control do not respond, except sometimes if you press it really hard.
What you describe is common when the batteries are about to go
dead. Low battery power means low infrared transmission.
Try new fresh batteries and see whether the problem goes away.
If it doesn't, then the remote may have to be replaced. The
buttons wear out in time; especially if they are mashed real hard
during their lifetime.
Aug 29, 2011 | Televison & Video
My dvr freezes. i have picture and sound but unable to change the channel or anything dealing with the dvr. i have to manually push the system info button on the box then select done with the remote. ...
Believe it or not, this could be a simple battery problem in your remote. When my battery is low in my remote, some buttons will work and some not. I'd try replacing the batteries in the remote first. If that doesn't work, I would guess that you need a new remote. Sounds like your DVR works fine manually, so chances are that's not the problem.
Hope this helps.
May 14, 2011 | DISH Network DVR-625 DTV Receiver /...
Remote does not work unless I am in the garage. Outside the door it will not work.
hello emar... check to be sure that the little wire antenna is hanging down from the back of the garage door opener motor. Then check it. If it still won't work from outside, install new batteries.
If that doesn't do it, remove the new batteries and use the eraser end of a common pencil to clean the battery contacts inside the remote. then reinstall the new batteries and try it again.
May 04, 2011 | liftmaster 83lm Billion Code 3-button...
Casa Vieja Probe White Ceiling Fan Logo
57 people viewed this question
Top Casa Vieja Dryers Experts
Stan Ford
Tom Chichester
Bill Boyd
Are you a Casa Vieja Dryer Expert? Answer questions, earn points and help others
