Question about Kichler Hardware & Accessories
How to wire a Kichler K-15PB300SS transfer with more than one run?
I need to add a second run to an existing transformer and not sure how to wire the 2nd connection. Any help would be greatly appreciated, I cannot seem to locate a manual, thank you!
2 Suggested Answers
jeltey
  • 44 Answers
SOURCE: wiring connections for Kichler 900w transformer
You need to connect one wire from each cable to one of the com terminals. The other wire from each cable has to connect to a tap terminal. The tap terminal you use will depend how many lights and the length of the cable. For short cable runs like 25' use tap 1 50' tap 2 100' tap 3 more than 100' tap 4. you may need to connect all three cables to the same tap terminal. If you turn it on and one string of lights is dimmer than the others move the tap connection from that wire to a higher number. The tap terminals send out a little higher voltage the higher the tap number. The obect is to get the same light output of each light compensating for the voltage drop of the cable. This is a lot of info so I hope this answers your question. If you need more help let me know.
Posted on Dec 04, 2008
Just install a lyric round thermostat on both floors.He did not add a 24 v transformer to the first floor, he used the existing transformer on my hot water heater that controls the two zone valves.
Can't say it is correct but a 40 va transformer (which is most common) should be just fine. Why did he not use the existing hot wire for the old tstat?
Feb 21, 2017 | Heating & Cooling
Just need help wiring up a transformer. 15PR200 SS
1) Copy following link for available resources for Kichler 15PR200 pro-series 200 watt transformer with selectable voltage output:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Power-pack
2) Add comment and describe how many watts, and what gauge wire you are connecting to transformer.
Feb 09, 2013 | KICHLER TRANSFORMERS - PROFESSIONAL SERIES...
Need a diagram of a Kichler 15E120BK
Installation appears to hook over a nail.
If you're trying to get inside the mechanism, I suspect the unit is sealed and non-repairable.
Dec 29, 2012 | KICHLER TRANSFORMERS - PROFESSIONAL SERIES...
How to wire
Following manual has different wiring diagrams:
http://waterheatertimer.org/pdf/Kitchler-transformer-wiring.pdf
Kitcher wiring with boost transformer: 120Volt
Black hot from breaker connects to Black Line wire
White neutral from breaker box connects to wht (COM) wire
Output to light is shown.
http://waterheatertimer.org/images/Kitchler-wiring-1-1000.jpg
Kitchler wiring with block terminals. 120Volt
Bare ground wire connects to GRD terminal
Black hot from breaker connects to 120VAC PRI terminal
White neutral from breaker box connects to COM PRI terminal
Output to lights is shown.
http://waterheatertimer.org/images/Kitchler-wiring-2a-1000.jpg
Additional resource:
http://waterheatertimer.org/How-to-set-timers.html
Jun 28, 2011 | KICHLER TRANSFORMERS - PROFESSIONAL SERIES...
I have a kichler 15pl300 where it does not transform from 120 Volts coming and it does not want to send out 12 V on the other side. The 120 volts has confirmed for be live.
I have been unable to locate manual for Kitchler low voltage products.
The troubleshoot page says check on-off switch, and put black tape over photoeye for two minutes, but does not elaborate on what to do.
1) Kitchler e-mail and contact information:
TechSupport@Kichler.com
Mailing Address
Kichler® Lighting
7711 East Pleasant Valley Road
P.O. Box 318010
Cleveland, Ohio 44131-8010
U.S.A.
2) Kitchler troubleshooting page has nothing:
http://www.landscapelighting.com//portal/faqs_page/portlet_landscape_faqs/cms/begin?portlet_landscape_faqsresource=/OpenCMS/sites/landscape.com/faqs/Faqs_Main_Page
Add a comment and say what you discover for others with Kitchler problems.
Open following link for Intermatic/Malibu troubleshoot:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Jun 07, 2011 | Kichler TRANSFORMERS - PROFESSIONAL SERIES...
Wiring connections for Kichler 900w transformer
Nov 02, 2008 | Kichler TRANSFORMERS - PROFESSIONAL SERIES...
Hardware & Accessories Logo
47 people viewed this question
Top Kichler Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Kichler Hardware and Accessory Expert? Answer questions, earn points and help others
