Question about Briggs and Riley Garden
How to start briggs and stratton pressure washer that has not been started for long period of time?
    Problem Solver:
  • 7 Answers
Take carburetor off, remove carburetor bowl, there is 1 bolt under the bowl that holds it on. If it looks gummed up, has brown and or gummy deposits it needs to be soaked in carb cleaner, paint stripper also works well. Let it soak for a few hours and check it. Also the bolt has 1 hole in the center of the end of the bolt & 2 holes on the sides of the bolt. Push a sewing pin or some other object that will fit through the holes to clear them out. Adter all that rinse the carburetor out with water, then blow out with compressed air, especially all holes.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_a3dac712db4ca1a6
Posted on Jun 22, 2014
Editor925
  • 285 Answers
SOURCE: Pressure washer with no pressure
Are you priming the water lines before you switch on the power?
i.e. with power OFF, hook up hose and turn hose on (doesn't need to have much hose pressure), then take your spray gun or attachment and pull the trigger and allow water to flow through the system (at hose pressure obviously). You might need to gravity feed it if its not flowing through...
But you will generally only get pressure once all the air is removed from the lines and the pump is pushing water only... Once you have water flow and lines are primed, switch on pump and see if that solves it.
Posted on Mar 17, 2009
SOURCE: 2200 psi husky briggs and stratton pressure washer
After a long none use, I tried to wash my driveway and powered on the washer,it did, but when i tried to engage the power washer by pressing the wand lever, it did not engage. What can I do to get the power washer working?
Posted on Jan 30, 2010
SOURCE: how to change oil in a pressure washer
From the manual CleanShot 2050 Briggs and Stratton
Change Pump Oil
1. Drain engine oil and fuel from pressure washer
2. Use an 8 mm allen wrench to remove black pump oil cap between high pressure outlet and garden hose inlet.
3. Tiltl pressure washer to drain oil into an approved container until it drips slowly from pump.
4.Tilt pressure washer in opposite direction and empty premeasured pump oil bottle into same opening (a small funnel may be helpful) [THIS IS WHAT THE MANUAL SAYS-NOT CLEARLY WRITTEN IN MY OPINION OR WRITTEN BY SOMEONE FOR WHOM ENGLISH IS A SECOND LANGUAGE]
5. Install black pump oil cap and tighten firmly.
6. Set pressure washer in upright position. Add fuel and engine oil.
From the engine manual use synthetic 5w-30, 10w-30 from -20 degrees F to temperature of 100 degrees F.
Change oil after 5 hours of operation initially. Before tipping to drain oil, remove fuel from fuel tank by running until tank is empty. Remove oil cap and dipstick and tip engine. Keep spark plug side up. Or remove drain plug from the bottom of pressure washer with a ratchet and square extension and drain oil from bottom. (fuel does not have to be removed)
Posted on Apr 22, 2010
SOURCE: Need to know where oil
I have the same model...... it should be just underneath the unit.... it will look like a square head recessed. I used the ratchet set extension and it fit just right. I literally had to tilt the darn thing upside down to find it. Then once it was loosen a bit, I put the machine upright on the wheels again, and slip a plastic pan underneath as I finished unscrewing the oil plug, Out came the black goo.
Posted on Sep 26, 2010
kel1guy2002
  • 3740 Answers
SOURCE: my pressure washer a briggs and stratton 550 won't
Hi and welcome to FixYa. I am Kelly
First off make sure the oil is full in the crank case.
Remove the spark plug and check for spark with the Engine on / off switch ON.
If there is good spark then turn off the fuel and remove the float bowl by unscrewing the bowl nut.
1) Remove all of the debris from the float bowl. It must be very clean.
2) Clean the bowl nut. This to must be very clean.
3) In the threaded area that the bowl nut screws into there is a Brass fuel jet. You must make sure that the pin hole of the jet is free of obstructions. I use a round toothpick broken in half. Use it like a scraper and clear the pin hole of the orifice. DO NOT force the toothpick into the orifice hole. It will break off and clog the orifice. Spray carb cleaner downward into the brass tube in the carb throat making sure that the carb cleaner passes through the jet orifice.
4) Use a spray paint can lid to catch fuel and turn on the fuel. Fuel should flow enough to fill the spray paint can lid in 8 to 10 seconds with the float hanging down. Raise the float gently to the level position and make sure fuel flow stops. (If you are not getting fuel to the carb remove the main fuel line at the carb and check fuel flow.) I.e fuel selector lever on and off. Poor fuel flow here = clogged fuel tank outlet port of debris in the fuel shut off valve area.
5) Install spark plug fuel lines and float bowl.
6) Attempt start. It should start. If it does not start squirt a small amount of fuel into the carb and try a start. Just respond here with symptoms. I.e have fuel.. have spark / fuel in carb throat = brief start or no start.
There is more that can be done.
Thanks for choosing FixYa,
Kelly
Posted on Nov 08, 2010
How start small engine that has not been started in long time?
Hello, First check oil level and make sure it is full. Then take out air filter and clean, then take out spark plug and make sure the gap is correct according to your users manual. Add fresh gas, choke and start.
May 17, 2014 | Briggs & Stratton 020272 Elite Series...
My 5.5 hp Briggs & Stratton pressure washer won't start and gas leaks out of the air intake after several attempts on trying to start.
sounds like it's flooding . it could be a spark problem it could be that the carb needs to be rebuilt i would check for spark first you could also run a compression test on the engine . also keep in mind some times if your pump is clogged it will not let your engine start and will be hard to turn over .
Oct 27, 2013 | Briggs & Stratton Garden
Craftsman 2500psi 2.3 gpm briggs and stratton pressure washer wont start
if it is still within the warranty period , take it to an authorized service agent for a check
if not I would be looking at the fuel system ( water in the carby) or wires to the stop/.start switch
May 17, 2017 | Craftsman 2500 PSI Briggs & Stratton...
The firwt time this year I tried to start my Briggs Troybilt Pressure Washer, it will not pump gas. I spray gasoline in to the carb and it starts for a moment. I spray gas in the cylinder, and it fires for...
If you left gas in it over the winter, particularly with the ethanol blends, the carb's probably all gunked up. You'll likely have to pull the carb, clean it and rebuild it.
Jul 06, 2011 | Briggs & Stratton Briggs Stratton 2550...
I do like to know if this washer is good enough for my business as a used car dealer? Briggs & Stratton Murray 020456 2400 PSI 20 GPM 190cc Briggs Stratton
We power washed houses for years with a 2400psi machine. The machine weighed about 90 pounds. 1 strong man could pick up the weight, but usually it took 2 men to unload it from the trailer.
A small machine can advertise 2400 psi ... but that is for 3 square inches at a time. The heavier machine shoots a 10" or wider swath of 2400psi.
We ran our machine twice a week for years. We had a honda engine. I'm sure the briggs engine is good. I wouldn't buy a used machine... unless the price was low and it started on first pull. Electric starter on your power washer might be a repair-waiting-to-happen because it is constantly exposed to water and dirt.
Oct 19, 2010 | Briggs & Stratton Murray 020456 2400 PSI...
Briggs & Stratton 2500 Power Washer Loses Pressure Time to Time
If by "a few minutes" you mean 180 seconds, I really don't know what to say. But if you mean 5-10 seconds, you probably are experiencing air in the water line or normal engine warm-up behavior when the choke has been set to full lean too soon.
May 23, 2009 | Briggs & Stratton 020324 3700 PSI Pro...
Just bought a new Briggs Stratton 6 75 pressure washer. i put in a half a tank of gas in the tank and it started up. i ran the pressure washer until it was out of gas. put more gas in now it will not...
assuming you tried choking it when you tried to start it, verifiy its getting gas,if not tap lightly on the bowl of carburator. if it is getting gas, check for spark
May 02, 2009 | Briggs Stratton 020273 Elite Series...
Garden Logo
43 people viewed this question
Top Briggs and Riley Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Briggs and Riley Garden Expert? Answer questions, earn points and help others
