Question about Kitchen Appliances - Others
Replacement parts Sunbeam Air Conditioner sca102rpc1
The "motherboard" for the circuitry on the top of the AC unit is broken. How do I obtain a new one? Dandwriter1@juno.com
22yooper
  • 828 Answers
SOURCE: replace contactor
On single phase your incoming power lines go to L-1 & L-2, the lines to the compressor go to T-1 & T-2. With A/C current it does not matter which one goes to which side as long as the line goes to the L side and the compressor power lines go to the T side. As long as the coil voltage is correct any contactor will replace the original.
Posted on May 29, 2008
  • 3422 Answers
SOURCE: air conditioner window unit {Hampton Bay}
You can get the parts from the below sites:
www.searspartsdirect.com
www.partstore.com
If you need anymore help let me know.Please don't forget to rate or accept the previous premium solution.
Posted on Jun 22, 2008
SOURCE: Heating element broken - need help sourcing a replacement
Visit this site. Send them a msg and ask it the heating element for another model number might fit yours.
http://www.thegourmetdepotco.com/store/store_partaccess_index.asp?ManufacturerID=46&CategoryID=49
Posted on May 07, 2009
SOURCE: Sunbeam KY-25/Y fan problem
I have a sunbeam ky-25 portable a/c that needs new exhaust fan but I can't find one
Posted on Aug 07, 2009
SOURCE: Memorex CD Clock Radio # 2863. Broken latch .. will not hold down top cover
Also have the same problem, clock sat on the night stand for a couple of years. Wife took into work to play CD's at the Christmas Party and the latch failed.
Think we may have used it once or twice as a CD player.
The black latch was easy to remove, justed open up the radio and pushed in the ears on the latch and it slipped back up into the CD compartment.
Will see if I can find something to repair it. Looked like the side cracked and a housing lost some of its side.
Posted on Dec 20, 2009
Sunbeam air conditioner 7500 btu model sck 7500dr, not cooling anymore what can be the problem
It could be a number of things. Compressor could be finished, a clogged metering device,a dirty condenser, low or no refrigerant (freon), blocked return air register. Bird's nest in the unit's condenser(in the rear), broken conductor, blocked or restricted liquid line, inoperable condenser fan or just about anything.Just replace it.
Aug 21, 2013 | Sunbeam Heating & Cooling
How to Replace broken fan on frigidaire air conditioner FAL125M1A1
Most of these AC units that are small in BTU size, under 15k, can't be repaired because most manufacturers don't have replacement parts available. Contact Frigidaire first.
Jul 30, 2012 | Frigidaire FAL125K1 Air Conditioner
MY AC KNOB IS BROKEN, HOW CAN I GET THIS PROBLEM FIXED
If it's just the plastic knob that's broken, go to the following link to find one like yours.
http://www.appliancefactoryparts.com/airconditioners/sunbeam/sunbeam-knobs.html
Or check your Owners Manual concerning how to get replacement parts.
Thanks for choosing FixYa.
Aug 10, 2011 | Sunbeam SCA052MWB1 Thru-Wall/Window Air...
Error code E1 and E2
E1 error - Indoor room temp sensor defective. Replace it.
E2 error - Indoor coil sensor open. Replace it.
Hope helps.
May 03, 2011 | Sunbeam SCA102RPC1 Portable Air...
The tube on the external bucket going to the unit is broken where can i buy a replacement part
use this model number for a whirlpool 10,000 btu portable ac
ACP102PR0 a very similar unit.
great online parts outlets:
appliancepartspros
repairclinic
sears parts or
pcapplianceparts
May 21, 2010 | Danby Portable Air Conditioner
Sunbeam Model No. SCK 14200 DR no cooling...
Un plug a/c from wall and remove the screws from the electrical compartment of the unit and locate the thermostat, remove the 2 wires of the thermostat and use ohms meter to check the part for continuity, if you dont have continuity with t-stat turned down below room temp., replace thermostat.Good luck.
Mar 05, 2010 | Sunbeam SCA103RWB1 Room Air Conditioner
My portable a/c continues to leak water from the bottom when in use. I have a hose attached to the spout in the back, but it still leaves a puddle and almost nothing drains out the back. It's a sunbeam...
It sound like the coil inside could be dirty. I have had the same problem with air handlers, when the coil is dirty or the filter is dirty it creates a back pressure and causes the condensation to drip off away from the condensation pan. Try accessing the coil on the inside see if it is dirty, if it is clean it lightly with soapy water and a brush and be carefull not to bend the fins on the coil. If it is clean double check the condensation hose and inlet for the hose for foreign matter.
Aug 12, 2009 | Sunbeam SCA102RPC1 Portable Air...
Sunbeam KY-25 portable air conditioner not working.
Mine works but with a bad exhaust fan, want to sell yours?
Apr 26, 2009 | Soleus KY-25U Air Conditioner
Sunbeam floor air conditioner KY25/Y
Mine is cooling but I have a broken fan. If you're not going to use it sell it to me please. contact me at yenks@hotmail.com
Apr 25, 2009 | Heating & Cooling
Kitchen Appliances - Others Logo
26 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
