Question about RTO Cycling
My neighbor gave myany ideasson a 110 cougar atv told us last time he rode it was a year ago , of course we had to clean out the carb and fuel filter etc and added gas changed a burned out fuse which did crank and lights wprked but now the fuse burned out again...a
    Habit-Forming:
  • 40 Answers
Sound like a short. Follow and check all wiring for rot, cuts, nicks etc.
Posted on Jun 18, 2014
  • 255 Answers
SOURCE: I have a Cannondale R600 and the gears won't shift
Something corroded in place - the most common thing is that if the bike were left out in the rain, water got in the shifting cable and the cable siezed in the sheathing. Sometimes they can be freed, but usually it requires a cable replacement. Your local bike shop can do this for a fair price.
Posted on Nov 25, 2009
JayduttDave
  • 99 Answers
SOURCE: My 110 chinese atv starts and idles ok most times,
There might be a problem in a air combition chamber and air filter just check it and clean it with the proper tool like bush for air filter and petrol kerosene disel or oil for air fuel combition chamber. Now your bike will smooth up on throttling up.
Posted on Jun 04, 2010
dbdrive2011
  • 12 Answers
SOURCE: 50cc mini atv wont start
do a compression check if its under 100 psi could be piston rings are bad or leaking gaskets.
Posted on Mar 31, 2012
talentedfox
SOURCE: spark problems with 110 atv
this is the wireing diagram for my 200cc atv, not sure of the make and model yet ,,,,, LOOKS LIKE A FALCON OR RAPTOR,KAZUMA LOL.
kill switch ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, black wire with white stripe wire
kill switch ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, green wire
kill switch ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, light blue wire
starter button ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, red/yellow wire
starter button ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, light blue wire
remember their are 2 light blue wire,s so please check , so if its not the 1 from the kill switch then it must be the 1 from the starter button ect.
solonoid ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, left hand side thick red wire to battery
solonoid ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, right hand side thin green/yellow to red yellow starter button.
green form the kill switch to the green on the fuse box
green and red to battery
so 3x red wire to the battery pos and 1 wire for the negitive which get grounded to the frame
3 x red wire with the extented wire wich i used was blue to battery positive
1 x blue wire thats the extended wire join to blue wire the to battery
1 x yellow/green wire to ground on battery
1x red from starter motor to right hand solonoid,
and thats it atv should run ,,,, the only problem i have now is the spark from the spark plug hmmmmmmmmmmmmm
Posted on Aug 18, 2012
SOURCE: does anyone know how to set the idle on the 110 atv
Not sure about that particular one however if it has been sitting for a while or has a bad fuel filter the low speed jet in the carb is probably clogged. Your local lawn mower shop should be able to fix for much less than the motorcycle shop.
Posted on Oct 29, 2012
2007 Polaris 500 X2 EFI, won't idle and coughs back through intake when throttling down
Hey Aaron,
When was the last time you gave this atv a major tune-up..A Professional carb cleaning, a new air filter, a new spark plug..? This should clear up your issues,
Jun 16, 2017 | ATVs
I have a artic cat 250 atv 2007 model. it starts cutting out at about half throttle
Odds are it's the carb. Start with a clean air filter and box, check and make sure your plug is good. Pull the carb and disassemble and clean with carb cleaner. Blow it out with air, check all air passages. I summarized this of course. 90% of the time it will be crud in the carb.
Apr 02, 2017 | ATVs
Sportsman 90 idles wont rev
Replace spark plug (gap correctly),Drain all fuel, replace fuel filter, replenish tank with fresh fuel, do a thorough readjustment of the carb settings (last resort - remove and rebuild carb)
Feb 17, 2015 | Polaris 2008 Sportsman 90
My tomahawk 110 atv will not start. I have rebuilt carb , replaced spark plug and it cranked and ran fine until I opened it full throttle and then it started sputtering and diedand now Iit will not re
You need three things to make any gas engine run, in this order double check make sure you have proper timing set, spark and fuel. Could be bad gas or a bad ground from motor to frame.
Dec 02, 2014 | ATVs
Does not want to idle
Hello Anom,
I do need more information to truly help you. Has the ATV (??..engine size, carb, fuel inj., year,??..etc.).. been sitting for a while...the carb is probably in need of a simple cleaning (all internal passages), a new spark plug, clean/treat or replace the air filter will probably get it running!
Please post more info.
Thanks, Steve
Apr 06, 2014 | Suzuki ATVs
Why wont my 110 cc pocket rocket start has spark light compression
air filter is clogged or you need to clean the carb make sure you have good carb compression and that your gas is running threw the lines properly
Jan 19, 2013 | RTO Quads 125cc Full Size Adult 4 Wheelers...
Bike has not been rode for over a year finally got it to start easy, but while I had the air cover off I shut it down because gas mixed with oil was being pumped out the breather hose on rear cylinder
YEAR,MAKE,MODEL??
Plus,...if the bike has been sitting for a long time,it is possible to have water in the fuel tank. So i wouldnt rule out gas just yet. Most likely it is fuel mixing with oil,and the carbs are going to have to be taken off,cleaned,floats set,and synched. And of course,drain old fuel and replace with new fuel. It would also be a good time to change the plugs,and oil while your at it.
Sep 23, 2012 | Motorcycles
I just got a 98 ninja 250. It sat for the last 6 months to a year but ran well before it was parked I'm told. Now it wont stay running without the choke on. Any ideas?
Hi and welcome to FixYa,
The carbs would need to be pulled down, soaked in cleaner and thoroughly cleaned specially the idling jets. The air filter would also require attention, either check/clean or replace. Of course the gas has to be replaced, the tank checked/cleaned with attention to the fuel filter/petc0ck assembly. Check the fuel hoses and the vacuum line for signs of cracks, split ends.
Good luck and thank you for asking FixYa.
Apr 03, 2010 | 2008 kawasaki Ninja 250R
2006 Honda Shadow Aero starts but won't idle.
check fuel level, u may need to check the flow of petrol to it,,Also if that does not solve you may need to service the carb and check fuel filter,air filter etc...
Aug 31, 2009 | 1999 Honda VT 1100 C3 Shadow Aero
Yamaha xs750 starting problem
You need you carb cleaned, air filter cleaned or replaced, and new spark plugs.
I bought XJ750 years ago, not running, cleaned the carbs, installed new spark plugs, and rode her for 5 years
Aug 22, 2009 | Yamaha TX 650 A Motorcycles
Cycling Logo
Top RTO Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a RTO Cycling Expert? Answer questions, earn points and help others
