Question about GE Profile Harmony WPGT9360E 4.0 Cu. Ft. King-Size Washer with Stainless Steel Basket
Touch screen not working GE Profile WPGT9350 washer
My machine will power on, but unable to use the touch screen or any of the buttons, like home, back, help buttons, everything is lit up just will not let me set my cycles or anything? Unsure what to do or if there is anything to do?
  • 1294 Answers
SOURCE: ge profile won't drain
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Jan 29, 2008
SOURCE: GE Profile Washer leaking underneath during spin cycle
its your outer tub it has a hole in it
Posted on May 13, 2009
  • 30 Answers
SOURCE: Agitator problem
Check to see if any thing is under the agitator. If not then maybe the bearings going out or other part of machine . Besure the cap is tighten so agatator don't come off. Check for ware on agatator top to the tighting nut.
Posted on Jun 02, 2009
TheMobilian
  • 8220 Answers
SOURCE: Ge profile model wpgt9350 washer. Started for
That is a tough one. Be nice to have manual would it not?
Profile Washer Manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Sep 20, 2010
blueextc3221
  • 15935 Answers
SOURCE: GE WPGT9350 CP profile washer. 7 yrs old. Lost all
What board did you replace?
Posted on Nov 19, 2010
My tablet is froze on talk back. Unable to turnoff the talk back nor can I turn off tablet.
Android? Press and hold the Power Button and the Volume Up button until you see the Android logo.
iPad? Press and hold Power button and the Home button until you see the Apple logo.
/or
There are two ways to unlock your device once TalkBack is turned on:
Two-finger swipe up from the bottom of the lock screen. ...
Explore by touch to find the Unlock button at the bottom middle of the screen, then double-tap.
Turn on TalkBack - Android Accessibility Help - Google Support
https://support.google.com/accessibility/android/answer/6007100?hl=en
Jun 17, 2017 | Cameras
All Screen elements lit
Remove power from board by unplugging the wire harnesses and replacing than again. See what happens.
Sounds like the board is locked out some how..possibly there was a power surge/failure during your absence.
Can only guess at this time.
Oct 19, 2013 | GE JSP34 Electric Kitchen Range
My iphone 3gs screen went white. looked up solutions online and it said to push the sleep/wake button and the home button for at least 10 sec. i did, however the red slide bar NEVER shows up??? so i cant...
Hold the power button for 3 seconds and without releasing the power button, push and hold the home button and continue holding both buttons until you see the apple logo, once the phone goes off, if it doesn't come back on by it's self, then just power it on as you normally would.
Aug 29, 2010 | Apple iPhone Smartphone
I put a lock on my ipod and i cant remember it
Restore the phone using iTunes and a PC, follow these steps HOW TO RESTORE
- Make sure the phone/touch is on. The phone/touch must also be docked or plugged in to your USB cable.
- Press and hold the Power and Home buttons on the phone until the screen shuts off.
- Release the Power button immediately. Keep pressing the Home button.
- You should see a number of horizontal lines invade the now-off screen, and it will be slightly disturbing. If you just see just flat blackness turn your phone back on and try again.
- Your computer will recognize an "Apple Restore (DFU) Device". Open iTunes and it will complain about needing to restore.
- Now just restore and everything will be back to normal.
Jun 10, 2010 | Apple iPod touch
The phone rings but I am unable to answer. I
if your unable to answer the phone, just hang up and wait for another incoming call or press the power button
Oct 13, 2009 | Google Android
Touch pad always lit up...
Yes, if the leds are all lit and no respnse, then your board in the top counsel is faulty. Have you haad any power surges recenlty.? Power surges sometimes mess up computer boards. But yeah, it sounds like its bad tho. There should be led light on unless you start pushing buttons. Have you hit the "off" selection. If nothing turns off the led lighting, it sounds like the board might be bad...hopefully this helps
Jul 31, 2009 | Maytag Neptune MAH5500B Front Load Washer
Screen is lit, but blank, no apple and does not respond to anything but turning it off and on.
Have you tried this? Hold down the 'Home Button' now also press and hold the 'Power Button'. Keep holding down both. It will prompt to power off but ignore this. The I Phone will reboot and do a reset which will not lose any information stored on unit. Once you see apple logo release buttons and it will take a few minutes to load up and hopefully everything is back to normal? It clears most common software faults which can occur if unit is continously on for long periods of time. Hope it helps.
Apr 18, 2009 | Apple iPhone Smartphone
The dry button is lit, no other buttons will respond to touch.
try to unplug unit for 30 min if this doesnt reser then change the module/control board.let me know what you think
Mar 17, 2009 | Maytag 24 in. DWU9902 Built-in Dishwasher
Iphone Freeze
My iphone froze up today, it just gave me a half lit screen and I couldn't even turn it off, nothing would work.  I held the home button and power off button at the same time for several seconds and this seemed to make it worse.  I did the same thing again, and it restarted the phone.  Nothing lost except for 3/4 of the battery life for some strange reason.  All is good, my phone is back!
Dec 11, 2007 | Apple iPhone Smartphone
GE Profile Harmony WPGT9360E 4.0 Cu. Ft. King-Size Washer with Stainless Steel Basket Logo
356 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Marvin
Marvin
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
