Question about 2002 - 2008 Jaguar X-Type Tire Pressure Monitoring System TPMS Sens
Havin g difficulty removing the rear driver passanger tire
    Master:
  • 457 Answers
AFTER REMOVE LUG NUTS SPRAY IT WITH WD 40 AROUND SCREW HOLDS WAIT 5 MINS THEN EITHER KICK WITH BOTTOM OF YOUR FOOT OR USE A LARGE HAMMER AND HIT THE RIM SHOULD BRAKE FREE. WHEN YOU REINSTALL THE TIRE PUT ANTI SEIZE AROUND THE RIM ON INSIDE AND THIS WILL STOP IT FROM GETTING STUCK ON
Posted on Dec 24, 2014
    Master:
  • 710 Answers
Try harder with a bigger wrench.
Posted on Aug 31, 2014
How do I take off my spare tire from under the car
there is plug in carpet between driver and passanger seats, remove it put your range in it turn I beleave clockwise untill spear tire drops then drag it out .
Nov 23, 2011 | 2005 Dodge Grand Caravan
Rear passanger tire locked
You probably have a brake slave cylinder that the pistons have popped out of. You will have to remove the tire and brake drum to take a look. If the components inside the brake drum are loose or out of place, lift the rear end of the car up on jack stands and use the brake panel assembly on the opposite side of the car as a reference on how to rebuild and replace the damaged components on the locked side of the Caravan. You will need a slave cylinder and new brake pads because the old shoes will be fluid fouled.
Dec 28, 2010 | 2005 Dodge Grand Caravan
In my 2001 Oldsmobile Aurora water is found over a period of time in my trunk where the spare tire is. Water is also on the floor on the driver and left passanger side.
What a pain this is. Had the same problems. I fixed the trunk by removing the rear plastic insert in the center of the trunk (where the license plate mounts) and sealing it. I also looked at the trunk gasket to see if there were any issues. It seems to leak right near the center near the trunk latch and then run down into the tire well.
The water on the floor I think is water following the door gasket to the bottom and then rolling over into the car. This doesn't happen too often on mine so I haven't done anything to fix it yet.
Oct 04, 2010 | 2001 Oldsmobile Aurora
Something is wrong with my rear end.i checked the gears and they look fine but when i lift the rear end and put it in drive only the passanger side wheel turns
it is definetly a differntial issue. to see if the gears are turning properly lift car, remove the diff cover and turn the tire by hand. both tires should turn if not its time to get new gears or differentail.
Feb 21, 2010 | 2001 Chevrolet Blazer
I have a lexmark x 1180 all in one but no discs with it havin difficulty finding it
You can download the drivers from this site
Fill the fields one by one, and you will be directed to a download.
Regards, WAQAR.
Nov 26, 2009 | Lexmark X1150 All-In-One InkJet Printer
I have a ransomes 350d mower and when you rev the engine up the mower cylinders rise up on there own, and can you tell me how to remove the drive units on the wheels so that iI can get to the brakes as...
there should be a c clip around the out side of the tire push it out with flat tip screw driver or pliers some tractors have a cover over them you might have to pop it off with screw driver first to get to the rest the bakes are usually on passanger rear wheel
Jun 07, 2009 | Garden
1977 honda goldwing rear tire removal never had
Get a service manual.
there are two ways to go. both time consuming and of moderate difficulty.
My favorite is to remove the trunk, saddlebags, rear fender as a unit. Then the tire is in the open to work on. Not an easy job.
Jun 06, 2009 | 1982 Honda GL 1100 Gold Wing
Buzzing or humming rear passanger tire
Hub bearing in the right rear is the most likely problem
Mar 27, 2009 | 1994 Honda Accord
Changing low beam headlight bulb on 2005 chrysler sebring
you can change the passanger side with little difficulty however the drivers side you need to remove power cell from it's bracket and move aside in order to access light.
Nov 12, 2008 | 2005 Chrysler Sebring Conv
2002 - 2008 Jaguar X-Type Tire Pressure Monitoring System TPMS Sens Logo
74 people viewed this question
Top Dorman Vehicle Parts & Accessories Experts
yobo007
yobo007
unosuave
cgswift
Level 1 Expert
Are you a Dorman Vehicle Part and Accessory Expert? Answer questions, earn points and help others
