Question about Dell Inspiron 1000 Notebook
Laptop Goes Dead!
When the computer is on it works fine, but if the monitor (LCD) is touched (as to open or close it) the computer goes dead completely. Its almost as is the computer power down instantly, but the the LED's stay on w/o blinking. The only way to recover is to do hard power down.
  • 2 more comments
  • Daverx Nov 18, 2007
    I have exactly the same problem with my daughter's Insipid 1000.
  • Anonymous Nov 28, 2007
    yeah, i have the same problem too. Often, the screen goes blank without any movement. After these "crashes" it often takes dozens of attempts to restart the computer. Interestingly, if I remove the battery with the power off, and slam it back in, it will start after only 2 or 3 attempts. Don't get me started on the battery! :-) Since day one!... I swear its nothing but a heavy plastic facade.
  • zsfd854 Dec 05, 2007
    i am having a prolbrem with my dell inspiron 1000 aney time i move the lcd screen it shuts down i have eavon set up a 2nd monter to see if it is just the lap top screen that goes dead but both screens go blank and i haft to re start the laptop can you help
  • Bobby Simmons Jan 23, 2008
    I have the same problem as the guest has. I have taken it apart looking for loose connections and moving the cable to lcd to no avail. bloweded it out with air thought it maybe a solder ball rolling around, if it is it is under a chip and will not come out. I had it two years before it started this. after I got it back together it worked much better for about a month then started ti again. I ordered the wife a new one. hope i can keep it running long enough to transfer data etc.
  • 1,601 Answers
Sounds like a bad ribbon cable from the LCD to motherboard.
Posted on Nov 04, 2007
Dell Inspiron 1525 laptop screen goes dark
Hey Lea,
Try the steps below to see if they will resolve this issue that you are having with your computer. If this does resolve the issue you can email me. My email address is listed below in my sigfile.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Apr 13, 2013 | Dell Inspiron 1525 Laptop
HP LP2465 monitor is a secondary screen attached to my laptop. Has worked for more than a year no problem. All of a sudden the monitor has started flickering. The display is fine for 1-2 seconds then...
you did all that but the acid test.
does it fail on ANOTHER PC<
if yes,them monitor is bad.
all do that, LP2465, all do.
if the monitor passes the acid test.
then the 2nd port on this PC unstated is bad, on the unstated video card. or its drivers bad. or OS corruption.
im sure you moved the dvi cable left and right on video cards
to see if the video jack was it.? right?>
the monitor has 2 DVI ports, try both?(it auto switches inside)
this monitor is 10 years old, 2007 (oldest) carbon14 dated.
as such back then, we did not have LED screens yet.
History matters.! in all cases. of electronics.
until 2010 but some did just before only the top models big.
i read your users guide, the 2 clue2 there, are
"this extends the life of the back lamps"
ahh but page 41..... is better.
the tubes have Hg. mercury inside, BINGO FOR CCFL for sure.
CCFL all do this.
goes yellow
goes dead
goes, dime
goes blinking or completely intermittant.
all do that, even in 2 years, in presentation mode, (on all the time)
and lasting, 10 year is , kiss the tooth fairy moment,
looked in the HP parts surfer, no parts in stock related
the monitor dead is worth $20 used.
so if it really is bad, then fixing it would cost 2 times
a new monitor, $75 new.
I could not find parts for yours, anywhere, see what LCD is actually there was not easy to discover.
2010 is the end if CCLF, is all I know, unless parts support exists.
Oct 16, 2017 | HP LP2465 24" LCD Monitor
My machine starts to boot then goes dead and the power button keeps blinking on and off
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed LG monitors to get some ideas what to look for:
Post back what you see inside so we can guide you further and it will help out other people in the future also.
May 15, 2010 | LG L1915S 19" LCD Monitor
VERY Dim screen after a drop
Have you tested it with an external monitor?
I would say you either have a damaged inverter board or screen baclight lamp. Usually the inverter board fails in one of the following ways:
1. When you turn on the laptop, the screen lights up for a short period of time and then goes dark. You still can see an image but it is very dark, almost invisible and definitely not usable. When you restart the laptop, the screen lights up and then goes dark again. The laptop works fine with an external monitor.
2. Your laptop turns on but the screen remains dark all the time. You still can see a very dim image outline. The laptop works fine with an external monitor.
3. The laptop screen works fine for hours or even days, but sometimes it goes very dark as it mentioned above. When you restart the laptop, the screen works fine again.
Inverter failure symptoms are very similar to backlight lamp failure symptoms and in most cases you cannot tell which one is causing the problem until you replace either the inverter board or the backlight lamp. From my personal experience, inverter boards fail more often than backlight lamps. If you have to guess, replace the inverter first.
Mar 24, 2010 | Sony VAIO VGN-NS190J/S Notebook PC
I have a fine black line that goes across my screen I rebooted an
This is a dead row of pixels. The LCD panel itself needs to be replaced. It would be far cheaper to replace the monitor.
Sep 29, 2009 | Dell UltraSharp 1704FPV 17 in. Flat Panel...
Connecting an external monitor to acer 5720
I have had this before with my Dell Latitude C540/640. I don't know the ACER 5720 but here's a couple possible fixes for you.
1. Press the function key ( "fn" key, generally a blue key or blue lettering and usually in the bottom left corner of your keyboard) and press F8 (may be a different key on your laptop, again, not familure with the acer. The key usually has either CRT/LCD printed on it, or two monitors on it, one its just an outline of a monitor and the other is filled in. This will run you laptop through the three monitor options it has. (LCD - LCD & External - Just External)
2. Try closing and opening the lid of your laptop. Sounds a bit strange but it works sometimes for me. My guess is when you close you screen it would "dim/turn off" the LCD and re-opening it convinces it to turn the screen back on.
Hope this helps!
Jan 09, 2009 | Acer Aspire 5720 Notebook
Hi Sammy7!!
I have such iiyama AS4636D monitor. In this day purchase.
I have such problem with you.
My solution:
Desktop pc and lcd power off (230VAC or 110VAC)
Power on lcd, after early desktop pc.
This moment, when running the pc booting, press and hold you the " + " button.
In this moment come in one blue screen. May be running on the sreen short message: check or select input mode: VGA DVI 1 2 . Select your correct cable connection type.
Have a nice day! and happy new year!
Lajos from Hungary
Dec 13, 2008 | iiyama Pro Lite AS4636D (Black) 18.1 in....
Monito going to sleep
I have the same problem. Monitor states going to sleep and the pc goes dead
Jul 03, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Dell Inspiron 1000 Notebook Logo
62 people viewed this question
Alun Cox
