Question about Robot Coupe MP 450 Turbo VV Mixer
How do i open the 450 turbo
How do i get the handle off
My Kitchen Aid Pro5 squeals when it's running. I may have overheated it when mixing bread dough. It seems to be running okay. It just makes a very high-pitched noise now. What can I do to fix this?
Get a Copy of the Repair Part List of your model from Kitchenaid.com.
Most likely it is the Worm Gear (17) grinding at low speed the Worm Gear Follower.(19)
You don't have to replace it now, but it is best to open the Transmission Housing and
inspect all the gears conditions. Clear all the grease to expose them. The Bevel
Gear (21) sits right on top of the Worm Gear Follower. (See Repair Part List)
If its teeth look sharp and all metal shiny, then that is the source of your noises.
Eventually, all the teeth will be chewed away and the planetary assembly will stop turning.
Jul 01, 2011 | KitchenAid 450 Watts KM25G0XWH Stand Mixer
Robot coupe 350 faulty switch how to dismantle
take out the side grills, and then remove the 4 screws (torax) remove the rubber covers (4) 4 on the handle, and also remove the screws...two shell parts come apart, and voila, there is the swich...good luck
Jul 20, 2010 | Robot Coupe MP 350 Turbo Combi Mixer
Can you tell me how this class b, type hcm- 450,
The same way any electrician would wire a three phase piece of equipment. With proper sized 3 wire w/ground romex.
May 26, 2010 | Hobart Food Mixers
Hello, i just put a cup of coffee into the microwave and now the door latch does not allow it to open, any suggestions?
your going to have cold coffee . when you closed the door it prpbably broke the latch ear.. you may have to remove the shell and relace it from inside and the replac handle . ****
Jan 09, 2010 | Food Mixers
Hobart 450 chopper mixer
Im a hobart service tech and repaired these units often,the seal job is a pain in the ***.Everything has to be torn apart.Forget manuals hobart doesnt give them out but i can step you through it.
Jun 06, 2008 | Hobart A200 Stand Mixer
H-600 Turn Handle slips, bowl does not go back down
Does the handle seem to move easier?there is a shear pin on the handle and if it breaks the bowl wont move.Another thing to check is remove the silver plateon the front of the mixer there are 2 possibly 4 screws,when you remove this plate you will see a long screw about 3 feet long.turn the handle if the screw doesnt turn that pin may be broken.let me know.
Mar 18, 2008 | Hobart H600 Stand Mixer
Speed control not work - constantly on high
The resistor will have failed. The A701 replacement is a 450 ohm 15W or 20W wirewound resistor. The capaicitor also can fail if the resistor has gone. It is a mains capacitor 0.1 microfarad. The modern mains capacitors are better to use than the old electrolytic type that were originally in the mixer.
Jan 01, 2008 | Kenwood KM800 Major Classic Stand Mixer
Robot Coupe MP 450 Turbo VV Mixer Logo
Top Robot Coupe Food Mixers Experts
eyecam
Ravi
Mister Danger
Are you a Robot Coupe Food Mixer Expert? Answer questions, earn points and help others
