Question about Mitsubishi WD-65638 65" DLP HDTV
How can you fix white dots on note 2 phone? - Mitsubishi WD-65638 65" DLP HDTV
How do I remove white shining dots on the screen?
The DLP chip is starting to go bad, and unfortunately the only fix to have it replaced.
Jul 31, 2015 | BenQ MP522 DLP Projector
Fix for white dots on HL-T6176S samsung tv
Yea, you must get the parts or service from a Samsung authorized warranty or repair facility. The white dots are a defective video engine and it must be replaced and some other parts, sometimes, need replaces as well. No fun but a good DIYer can do it.
Feb 10, 2015 | Samsung Televison & Video
The projector has several white dots on the screen. how can i fix it, it started with a few white dots then every time i used it, it doubles and doubles until it became many dots.
I have the same problem. I think we need a class action!
http://s1231.photobucket.com/upload/albums/m3231/?location=projector+spots
Oct 06, 2010 | BenQ MP511 Projector
Canon iR 4570 Error code E00007-0000
it might just be a power spike in which case your machine just shot an error while it protected itself...
try the following...
press additional functions
press 2 and 8 at the same time
press code error
press copier
press function
press clear
press error
press ok
press reset
if that doesn't work then call a tech.
May 19, 2010 | Canon ImageRUNNER 3570 Copier/Printer
WHITE DOTS IN MY SAMSUNG TV HDTV
the white dots our dead pixles im afraid the only way of fixing this is buying a new display, if you contact samsung and let them no they should be able to give you the price of a new display.
Thanks
Mar 10, 2009 | Televison & Video
No picture
Hey man whatsup, I see very faint star like dot patterns, they shift around. This happens while using both cables.
Jun 24, 2008 | Microsoft Xbox 360 Console
Can I Have my razr repaired
Then you should take the phone to a repair center and have it fix for a fee.
The white dot on the back of the phone is to safeguard the manufacturer from malicious damaged or use by the customer.
So if it is red that means if had to come into contact with liquid , moisture or water at sometime.
Apr 29, 2008 | Motorola Mobility RAZR V3
Problem
oooh doesnt sound too good! but my phone got a bit wet and stuffed up quite a bit so last night im my room on the shelf, i took out my sim card, battery, back cover and left it open to get some fresh air. and now it works fine:) goodluck you might want to try that but yours was alot wetter than mine!
Nov 23, 2006 | Motorola Mobility V265
Mitsubishi WD-65638 65" DLP HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
