A density graph for all the possible heights between 0 inches and 80 inches is in the shape of a rectangle. What is the value of the density graph in this interval?
3 Suggested Answers
  • 101 Answers
SOURCE: Question no. 2
64 62 52 50 70 60 55 20 25 48 35 55 55 47 64 42 36 50 30 53 51 63 58 50 60 54 33 48 40 76 61 46 65 65 15 45 58 40 64 18 33 40 64 18 33 40 48 9 38 41
Highest value observed: 76
Lowest Value: 9
Standard deviation from the ungrouped data: 15.25
Frequency:
Mean: 46.94
Standard deviation from grouped data: 15.40
Posted on Oct 23, 2009
  • 7993 Answers
SOURCE: some y values in my table say error when i graph logs
That is normal behavior. The log functions are not defined if the argument (x value ) is negative.
Posted on Mar 24, 2010
Error ce40
Read this
http://www.copytechnet.com/forums/toshiba/78223-toshiba-estudio-281c-error-ce40-total-491000-a.html
and this
PRINTERCAT : Hi this is Michelle and i will be assisting you. PRINTERCAT : Error CE40:CE40] Image quality control test pattern abnormality(1) Use "Image quality control abnormal detection counter Y to K display/0 clearing (08-573 to 576)"to check the abnormal occurring condition for each color. PRINTERCAT : (2) Check "Output value display of image quality sensor / Low-density pattern (05-391-0 to 3)" tocheck if the low-density pattern abnormality occurs for each color. The values under 320 for Y, Mand C, and under 220 for K are defined as low-density pattern abnormality. PRINTERCAT : (3) Check "Output value display of image quality sensor / High-density pattern (05-390-0 to 3)" tocheck if the high-density pattern abnormality occurs for each color and identify the color whichpattern is abnormal. If the value is 630 or above, it is defined as high-density pattern abnormality. PRINTERCAT : (4) Set the values of "Image quality closed-loop control / Contrast voltage (08-556)" and "Imagequality closed-loop control / Laser power (08-557)" to "0" (Invalid). PRINTERCAT : (5) Perform "Enforced performing of image quality open-loop control (05-394)". PRINTERCAT : (6) Output the image quality control test pattern (04-270) more than one time and check the patch ofthe color identified in step (3) to see if the image is abnormal (Note). PRINTERCAT : (7) Replace the image quality sensor. PRINTERCAT : (8) Set the values of "Image quality closed-loop control / Contrast voltage (08-556)" and "Imagequality closed-loop control / Laser power (08-557)" to "1" (Valid). PRINTERCAT : (9) Perform "Enforced performing of image quality open-loop control (05-394)" and make sure it iscompleted normally. (Error [CE40] does not appear.) Then perform "Automatic gamma adjustment"( Chapter 3.5.1 and 3.6.1).(10) Clear all "Image quality control abnormal detection counter Y to K display/0 clearing (08-573 to576)". PRINTERCAT : Please note:Abnormal image:Blank print, Solid print, White banding, Color banding, White spots, Poor transfer, Uneven imagedensity, Faded image (low density), Uneven light distribution, Blotched image.''''''''''??320 or above (Y, M and C)220 or above (K)''??Under 320 (Y, M and C)Under 220 (K)Low-density pattern abnormalityCheck the transfer belt. If the cleaning is poor, correct thetransfer belt around its cleaning blade.'??To (9)''''''??Normal '??AbnormalCorrect the items related to the image.
Mar 24, 2016 | Office Equipment & Supplies
How many gallons in an 88" x 15" x 9" trough?
try this :
Instructions
  1. Measure the rectangle length, width and height. For example, 8 inches long, 6 inches wide, 10 inches high.
  2. Multiply the length by the height, then double the product. With this example, 8 inches multiplied by 10 inches results in 80 square inches, which multiplied by 2 equals 160 square inches.
  3. Multiply the width by the length, then double the product. With this example, 6 inches multiplied by 8 inches equals 48 square inches, which multiplied by 2 equals 96 square inches.
  4. Multiply the height by the width, then double the product. With this example, 10 inches multiplied by 6 inches results in 60 square inches, which multiplied by 2 equals 120 square inches.
  5. Sum the amounts from Steps 1 through 3 to find the rectangle surface area. So adding 160, 96 and 120 square inches results in 376 square inches.
1 Us gallon is 231 cubic inches
Sep 05, 2015 | Garden
Please show all of the information and answers to: The plane was purchased new in 2006; therefore, x =0 represents the year 2006. X - Axis (horizontal) = years starting from 0 = 2006 and increasing b
Translate the English into Mathematics.
W=L-5 (in inches)
P=2(L+W)=2(L+L-5)=2(2L-5)
Use distirbutive property of multiplication with respect to addition to open up the parentheses (brackets)
P=4L-10.
Set P= 50 (inches), to get 4L-10=50
Solve for L: Do it'!
Find W= L (the one you just found) -5 =
Now, with W the value you just calculated
the new length is L'=-4+3W
and the new perimeter is P'=2(L'+W)
Now your turn to do some work.
Jan 02, 2012 | Office Equipment & Supplies
Toshiba estudio 351c error code ce40
Hi
I hope that this will help you
[CE40] Image quality control test pattern abnormality
(6) Output the image quality control test pattern (04-270) more than one time and check the patch of the color identified in step (3) to see if the image is abnormal.
(10) Clear all "Image quality control abnormal detection counter Y to K display/0 clearing (08-573 to 576).
Good Luck
Regards
Apr 12, 2011 | Toshiba Office Equipment & Supplies
How to calculate the weihgt of circular cones
(1/3) x pi x radius2 x height x density = pounds
where ::
radius = radius of base in inches
density = pounds per cubic inch
height = height in inches
(or you could use feet, meters, cm, mm for radius & height and use kg for density or wahtever units you wish as long as the units are consistent)
Charlie
Feb 22, 2011 | American Standard Plumbing
3x+3/2
What is your question? Are you asking for a numerical answer or graph?
The graph should be shaped like the letter v with a point at (0, 1.5)
The numerical answer is the set of all positive y
If you're calculator does toy have the two absolute value lines; look for a button that says "abs"
Jun 15, 2010 | Texas Instruments TI-84 Plus Calculator
Some y values in my table say error when i graph logs
Mar 23, 2010 | Texas Instruments TI-83 Plus Calculator
Graph
What is n?
Press [Y=]. In the Y1= line, type [cos] [6] [ALPHA] [X] [)]
Press [WINDOW]. Enter 0 for Xmin. If n is a variable stored in memory, enter 2N for Xmax. Otherwise enter an appropriate value for Xmax. You might also want to put in better values for Ymin and Ymax, such as -2 and 2, respectively. (For a negative number, be sure to use the [(-)] key next to the decimal point and not the [-] key on the rightmost column.)
Press [GRAPH] to see the graph.
Feb 25, 2010 | Texas Instruments TI-83 Plus Calculator
Problems seeing graph on calculator....think it has something to do with limits set on window....what do I do
I take your word for it. If graph is out of range you should zoom out.
But first try [ZOOM][6:Ztandard]. If you still see nothing, press [WNIDOW] and set XMIN=-100, XMAX=100, YMIN=-100, YMAX=100.
Otherwise you must know a few things about the behavior of the function you try to hraph
1. If X is always positif, set XMIN=0
2.If X is always negative, set XMAX=0
3. If Y has only positive values, set YMIN=0
4. If Y has only negative values, set YMAX=0
You can also calculate Y for X=0. Let Y(0) be that value. Then you try to have the Y-Values centerd around it: YMIN=Y(0)-10 and YMAX=Y(0)+10.
Hope it helps.
Oct 22, 2009 | Texas Instruments TI-84 Plus Calculator
Write a system of linear inequalities whose solutuion region forms the given shape a rectangle
Hi wnhrtlywanda,
You can try this:
K>y>0, L>x>0, where K and L are any constants.
If you need a rectangle that is not parallel to the axes, use the formulae for the rotation of the axes and replace the small x, y in the above inequalities with the following values
x = XcosA - YsinA; and y = XsinA + YcosA
where capital X and Y denote the new x and y after rotation, A is the angle of rotation measured anticlockwise from the x-axis.
I sincerely hope this helps.
Oct 06, 2009 | The Learning Company Achieve! Math &...
Computers & Internet Logo
69 people viewed this question
David Payne
David Payne
